This thread is privately moderated by Dr Kiwi, who may elect to delete unwanted replies.
Old May 24, 2012, 06:33 PM
miller red is offline
Find More Posts by miller red
sw michigan
Joined Aug 2010
No email link
Hi, my email did not contain a link to register, now what?
miller red is offline Find More Posts by miller red
Old May 24, 2012, 07:12 PM
rgoble is offline
Find More Posts by rgoble
rgoble's Avatar
Dayton Montgomery, Ohio, United States
Joined Sep 2004
I sent you a private message to try and figure out the problem
rgoble is offline Find More Posts by rgoble
Old May 24, 2012, 08:40 PM
sw michigan
Joined Aug 2010
I sent you a pm back. I still can't get in.
Old Jun 02, 2012, 12:24 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Dr Kiwi,
Have you given any thought to testing the Ammo 1015 used in the micro GP F-86?
Ksqm
ksqm is online now Find More Posts by ksqm
Old Jun 02, 2012, 01:41 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If someone could lend me one (in August) I could look at it.. on Tuesday we're away for the summer...we'll be on an island in Maine, and I can't run my Zurich Power Supply without electricity!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jun 03, 2012, 12:57 PM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
Originally Posted by Dr Kiwi View Post
...I can't run my Zurich Power Supply without electricity!
Spoken like someone who doesn't appreciate Blue Grass!
Q: How many Blue Grass pickers does it take to change a stage light?
A: None. That durn thing's electric, didja know that?
A Useless Geek is offline Find More Posts by A Useless Geek
Old Jun 05, 2012, 04:33 PM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
I don't see the test data on a Turnigy G10. What kind of info you need on it? Amps per manufacture or what it actually pulls with a prop? Just wondering cause I have one and can tell u what it pulls with a 11x7 prop. Thats about all I got on it though. : )
JoshB is offline Find More Posts by JoshB
Old Jul 08, 2012, 09:25 AM
amin2904 is offline
Find More Posts by amin2904
amin2904's Avatar
Joined Jan 2012
Hello
I'm going to buy HYPERION SNIPER 3D model.
Please help me.
This engine is suitable for this aircraft?
http://modeliran.com/1389-03-11-08-5...x_2215_25.html
PROP = 10*4.7
THRUST = 950 grm
amin2904 is offline Find More Posts by amin2904
Old Jul 08, 2012, 01:51 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I can't figure out the weight there at your link.
You can look at the data here: http://www.flybrushless.com/motor/view/82
And see the thrust, as long as you can use a prop that has more thrust than half of the weight of the plane (0.5:1 thrust to weight ratio) you should be OK.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jul 08, 2012, 02:53 PM
amin2904 is offline
amin2904's Avatar
Joined Jan 2012
thanks jack
Old Aug 02, 2012, 10:12 PM
Sackie is offline
Find More Posts by Sackie
Sackie's Avatar
Steinbach, MB, Canada
Joined Nov 2004
Hi there, I have a built up Fly Baby, scratch built from RCM plans, and it weighs about 416g without battery, the battery weights 109g (a 1300 Mah 3 cell LIPO). The Motor is a Super Tigre 400 (max current 13A and max draw 18A) with a Super Tiger 20A ESC. What I need to know is which prop should I use for this airplane. The recommended range is a 9x3.5SF - 11x7SF, but I an not going to be flying 3D with this lovely slow and stately aircraft. Definately cannot use anything larger than 11 in as there may not even be enough clearance for an 11 when flying off of a grass field.
Any suggestions welcome.
Sackie
Sackie is offline Find More Posts by Sackie
Old Aug 03, 2012, 07:30 AM
Jack
USA, ME, Ellsworth
Joined May 2008
That should be a 150 Watt continuous or so motor, I'd think a good prop for it would be the Great Planes PowerFlow slow fly props in 8 x 6 or 9 x 4.5. I'd mount that on the tapered cone style prop saver prop adapter if it can be used on your plane.
The GP slow fly props are not easy to find a a LHS, I find them on eBay though and at good prices. More info here on fitting the prop saver and also on the Thera-Band prop saver bands:
http://www.rcgroups.com/forums/showthread.php?t=1419378
Similar sized GWS slow fly props would be OK too but they will not handle the power or RPM anywhere near as well as the Great Planes props do.
Jack
Old Aug 23, 2012, 01:02 PM
DRaero is offline
Find More Posts by DRaero
Joined Aug 2012
Large Scale Static Thrust Data needed
I started a thread trying to compile data for the larger electric systems.
http://www.rcgroups.com/forums/showthread.php?t=1717696
I am looking for a slightly different analysis, but DrKiwi could add the info into his database as well.
DRaero is offline Find More Posts by DRaero
Old Aug 24, 2012, 07:17 AM
rgoble is offline
rgoble's Avatar
Joined Sep 2004
If you have any luck getting that data please feel free to add it to www.flybrushless.com. If you have a lot of data in excel form and don't want to input it manually then you can send it to me and I can import it in bulk for you. That's what I always do for Dr Kiwi's data.
Old Aug 24, 2012, 07:30 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Sackie
I think you will find the 11" props are for 2s packs and the 9" props for 3s packs.
hoppy is offline Find More Posts by hoppy
Discussion combining data for different brands of motors derway Power Systems 3 Oct 29, 2006 11:23 AM
Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. Steven Chao 3D Flying 0 Aug 29, 2005 02:10 AM
motor/prop test bench txzagi Power Systems 9 May 08, 2002 04:36 PM
motor/prop test bench txzagi Fuel Plane Talk 1 May 06, 2002 06:48 PM
Where to Get Service for Jeti Phasor Brushless Motors? GoEFlight Vendor Talk 2 Jan 09, 2002 11:34 AM
