This thread is privately moderated by Dr Kiwi, who may elect to delete unwanted replies.
Old Apr 14, 2012, 05:09 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
I see....for me is the matter of faster climb out,the rest the plane is just souring
Ben
FASTBEN is offline Find More Posts by FASTBEN
Old Apr 14, 2012, 05:26 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Gotta love that EagleTree system! Mine's telling me things I would've never dreamed. Of course, some of what it reveals is rather baffling too! *LOL* I get about as much fun out've reading & analyzing flight data as I do out of flying the planes! Seems almost 'wrong', in a way -- color me nerd.
StarHopper44 is offline Find More Posts by StarHopper44
Old Apr 14, 2012, 07:21 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Well, then I am a nerd too then! Agonizing over the numbers and details is a happy time for me too!
Jack
jackerbes is offline Find More Posts by jackerbes
Old Apr 17, 2012, 02:13 PM
davearl313 is offline
Find More Posts by davearl313
Joined Feb 2012
No email for activation
Registered for use of this site under the login of "davearl313", have yet to receive an email for activation. Can anyone help!
davearl313 is offline Find More Posts by davearl313
Old Apr 17, 2012, 07:18 PM
rgoble is offline
Find More Posts by rgoble
rgoble's Avatar
Dayton Montgomery, Ohio, United States
Joined Sep 2004
PM Sent.
rgoble is offline Find More Posts by rgoble
Old Apr 18, 2012, 12:21 PM
Earthbound Skyhound
Joined Jun 2011
oops....nevermind...
Old Apr 28, 2012, 08:22 AM
Earthbound Skyhound
Joined Jun 2011
I read something today from an instruction sheet that seems to contradict something I was told earlier, re # of poles in a BL motor.
The instructions say, "Usually the pair number of magnets on rotor is poles. If you count 14pcs magnet on the rotor shell, then you should select 7 P(Poles)", which presumably translates simply to, "Number of magnets is twice the number of poles".
True or not?
Old Apr 28, 2012, 10:06 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Not correct, but then again, it is not what they meant. This is what it should say:
"You should select 7 Pairs"
Motormagnetpoles always come in two's, statorpoles (the teeth) always come in three's.
See these motor animations and simulations, very instructive:
http://www.rcgroups.com/forums/showt...ght=anim+simul
Controller max.rpm. limit depends on computer processing power on board. The limit is specced for 2-magnetpole motors. Say a controller can handle 140krpm . It can do that for a 2-magnetpole/1-pole-pair motor. It can handle 70krpm for a 4-magnetpole/2polepair motor ... and it can handle 20krpm for a 14-magnetpole/7polepair motor. To the controller, there's no difference between those motors, controller does not care about number of magnetpoles. But people do care about rpm. to calculate the correct rpm, the user must enter a number.
So, to 'know' the actual shaft rpm the motor is running at, the ESC must divide the electrical rpm by seven, that's the number that particular manufacturer wants you to enter.
Originally Posted by wazoo22 View Post
... I read an article somewhere about ESC programming vs. number of poles, but can't remember where.
Max. rpm table, per make/type/#magnetpoles
http://www.bavaria-direct.co.za/models/motor_info.htm (RCG user skylar)
-> ESC Max. RPM Limits
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
• Get a life ... get a Watt-meter!!! •
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 02, 2012, 10:53 AM
Earthbound Skyhound
Joined Jun 2011
Thanks Ron....but many (most?) of the links on that reference page are not working. I see the thread is a bit long of tooth now (old)....perhaps an update would be worth the while if you refer to it regularly, if the resources are still available?
Old May 02, 2012, 11:12 AM
Joined Feb 2001
Animations
Outrunners are inrunners turned inside out, that's all
http://townbiz.com/animations/2-pole_bldc.html (star connection is missing)
http://townbiz.com/animations/4-pole_bldc.html (star hook-up in green)
Simulations
Old May 02, 2012, 11:41 AM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
It'd be nice to know where these simulations come from to give credit to the sources, eh? Also, to know if the images can be copied and used in other venues.
A Useless Geek is offline Find More Posts by A Useless Geek
Old May 02, 2012, 03:01 PM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
check this out http://www.rcgroups.com/forums/showthread.php?t=1638287
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old May 02, 2012, 07:47 PM
Chicagoland
Joined Oct 2008
Um...there are no links to simulations in that thread. Why do you want us to go there?
Old May 02, 2012, 08:26 PM
Jack
USA, ME, Ellsworth
Joined May 2008
To acquaint us with a radical new building technique, he is making airplanes out of some kind of wood! No foam at all as near as I can tell...
Jack
Old May 03, 2012, 04:44 AM
Chicagoland
Joined Oct 2008
Yeah, this guy was so proud of his effort he posted all over the place begging people to come look at his build thread. Ahh, to be newbie and have absolutely no sense of shame...
Discussion combining data for different brands of motors derway Power Systems 3 Oct 29, 2006 11:23 AM
Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. Steven Chao 3D Flying 0 Aug 29, 2005 02:10 AM
motor/prop test bench txzagi Power Systems 9 May 08, 2002 04:36 PM
motor/prop test bench txzagi Fuel Plane Talk 1 May 06, 2002 06:48 PM
Where to Get Service for Jeti Phasor Brushless Motors? GoEFlight Vendor Talk 2 Jan 09, 2002 11:34 AM
