Some info for the e-beginner www.ezonemag.com -> FAQ http://www.wattflyer.com/forums/forumdisplay.php?f=3 -> [sticky] Magic numbers for modelers... and -> [sticky] Everything You Wanted To Know About Electric Powered Flight Vriendelijke groeten Ron
Oneofsharp,
In the future I hope that FlyBrushless.com can help answer your question. However so far the site only has motor data from Dr Kiwi entered and I don't believe any of them are big enough for what you need. For now Ron is correct and your best chance to get an answer is in the Glow to Electric sub forum. Quote:
War Machine,
So far Dr Kiwi and MicroDan are the only ones who have added test data to the site. I don't think either of them have tested any NEU motors. Anyone who signs up on the site can submit motors and test data. So as soon as someone comes along and fills in that gap they should show up. Robert Quote:
1. The site is currently down, hopefully it will be back up and running this evening. I suppose this is the price you pay for free web hosting. I will start looking for a new host today.
2. I found the formulas for calculating efficiency (Pout/PIN), but I wasn't sure if this was something worth display for each prop/voltage combo or not. I could work on generating a graph to show the curve based on the available test data. If nothing else I could find the peak efficiency from the test data and display that at the top of the page. Thanks for the ideas guys, Robert |
Yes, I suppose one could have another column with Pout/Pin for every motor/prop/voltage, but anyone who really wants to see this Pout/Pin efficiency for a specific combo can always plug the numbers into www.badcock.net or Drive Calc...
I think this would be "gilding the lily". |
FWIW, my suggestion is to design the new site to do only one task, but to do that one task very well. When one tries to do a dozen things at once, what usually happens is the quality of each one drops.
Perhaps the thing to do is to spell out exactly what the goal of the new site (flybrushless.com) is. So far, the site is a database of motor measurements, so presumably the purpose is to make all this data available to any interested party from one single location. Are there other goals for the website other than being a database of measured values? As Robert has suggested, adding some sort of search capability is one way to make any database more valuable. I'd suggest having the ability to search for motors within a certain Kv range and within a certain range of motor currents. So for example, it would be nice to be able to search for all motors with Kv between 700 and 800 rpm/V and able to handle 35 amps burst current draw. (Yes, burst current is not very well specified, but it's all we've got!) Once the search returned (hopefully) several motors, it would be nice to have ways to narrow the pack. Weight is an obvious one (and automatically takes care of efficiency - a lightweight motor that can handle lots of power HAS to be efficient, otherwise it would overheat and be damaged). Price is another obvious one, but since that is a moving target, it would be an onerous task to keep the database up to date. Finally, it's nice to know about other websites that have attempted to do similar things in the past. I know of at least two: First, "the great motor test" is a database of motor measurements, now many years old and gradually becoming obsolete. Here's a link to this database at flyingmodels.org: http://www.flyingmodels.org/motortest/index_e.htm Second, Peak Eff: http://www.peakeff.com/ (The creator of this site is an RCG member, username "mattay" if I remember right. Edit: sorry, it's actually "matttay" with three t's.) PeakEff also includes several tools for searching and visualizing database content. One thing to investigate might be whether Robert and Matttay might perhaps join forces and both jointly improve one website, rather than having twin sites that both attempt to do somewhat the same thing? -Flieslikeabeagle |
You have some good points about the site trying to do too much. There are quite a few items I want to get done left on my list. Improving the search is one of them.
As for the other sites thanks for pointing them out to me. I knew about "the great motor test" and tried emailing the guy who runs the site about including those motors in my site. I still have not heard back from him yet. I didn't know about Peak Eff, I will take a look at it and try and talk to mattay about it. Robert |
Robert, I misremembered the username "mattay". Turns out it has one more "t", it's actually "matttay". And here's a post in which he (afaik) first introduced Peak Eff:
http://www.rcgroups.com/forums/showthread.php?t=572159 -Flieslikeabeagle |
Second, I do have suggestions - I wrote a software tool (WebOCalc) to help with exactly the task you've undertaken. Please post to the current WebOCalc thread (and shoot me a PM if I don't show up to help you right away!) and I'll do my best to help you pick power systems for your models. You might also find the answers you want simply by reading through the thread and then heading over to my site to use WebOCalc.Link to the current WebOCalc thread: http://www.rcgroups.com/forums/showthread.php?t=930018 -Flieslikeabeagle |
The website is back up and running. For now its will only work if you include the www.
So http://www.flybrushless.com |
| Thread Tools | |
| Discussion combining data for different brands of motors | derway | Power Systems | 3 | Oct 29, 2006 11:23 AM |
| Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. | Steven Chao | 3D Flying | 0 | Aug 29, 2005 02:10 AM |
| motor/prop test bench | txzagi | Power Systems | 9 | May 08, 2002 04:36 PM |
| motor/prop test bench | txzagi | Fuel Plane Talk | 1 | May 06, 2002 06:48 PM |
| Where to Get Service for Jeti Phasor Brushless Motors? | GoEFlight | Vendor Talk | 2 | Jan 09, 2002 11:34 AM |
