This thread is privately moderated by Dr Kiwi, who may elect to delete unwanted replies.
Old Nov 11, 2010, 06:39 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Red seems to be the standard color for EMP versions... HXT are purple, Aeronuts are light-blue, Turnigy are gold or silver and there is a dark blue Alpha variant too.......I think they are exactly the same motor, from the same factory... only the anodizing is different!
What about this from Puffin in the UK: Ray-Pelikan????
And the Alpha from Nitroplanes.
And Aeronuts!
Turnigy!
HXT!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 11, 2010, 07:04 AM
Heliosupersix is offline
Find More Posts by Heliosupersix
Joined Nov 2010
I wonder which one has the best quality control ?
All I want is 4 within say 5% of each other, but 50% has got to be unacceptable.
Does it follow the more you pay the better matched they will be?
Heliosupersix is offline Find More Posts by Heliosupersix
Old Nov 11, 2010, 07:18 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I doubt it... since they all come from the same place! Now if you switch to AXI, Hacker, Plettenberg, MicroDAN....then you will probably get 4 close to the same.
Old Nov 11, 2010, 08:36 AM
Joined Nov 2010
Ok Thanks
I do like my AXI's
Old Nov 19, 2010, 10:04 AM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
HelioSS, you need to invade the power system subforum and cast about for motor recommendations. You are bound to find guys who have already gone through what you are doing and can give you a hand. I wish I had known how good a source the folk here are a couple of years ago before I spent an unnecessary couple of grand at Grayson, Hobby King, etc. trying to find the right motors, servos, speed controls, yada yada. A little bit of searching can reduce or outright eliminate a whole buncha spending. Eh?
A Useless Geek is offline Find More Posts by A Useless Geek
Old Nov 20, 2010, 10:40 AM
Joined Nov 2010
I can't say Hi Usless Geek....Oh I just have
You're nearly on the money here....I am actually pretty good at selecting what I want it is finding something representative of the origional spec that eludes me. Quality control is non existent so it's a complete lottery what you end up with, kinda frustrating.
Old Nov 20, 2010, 12:13 PM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
I do too, as well as the Monster motors from HobbyPartz and Lighning motors from Skyshark RC and many others. If you compare the motor stats with the EMP motors and the bells, not end bells and the shaft diameters, weights and the like, it certainly appears they all come from here.
http://www.xingyaohua.com/web/en/index.asp
Ken Myers is offline Find More Posts by Ken Myers
Old Nov 20, 2010, 01:17 PM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
Originally Posted by Heliosupersix View Post
. So I built a rig with a digital spring balance which could be raised and lowered by turning a screw perpendicular to but 1cm to the side of the motor shaft. I put a small ruler with a hole drilled at 1cm on where the prop would be and connected it to the digital balance.
Comment invited.
Jon
Jon
Please post a diagram or photo of your test set-up.
peterangus is offline Find More Posts by peterangus
Old Nov 20, 2010, 01:23 PM
Chicagoland
Joined Oct 2008
I disagree that it's a complete crapshoot. Once you've tried certain things from the various vendors (I use HK almost exclusively now) you find out what's good, reliable, repeatable, and available. There are a few motors, ESCs, batteries, and servos that I get from HK that are the same good stuff every single time I get them. Armed with that info I can reliably build planes that will perform to a predictable standard every time as well.
As I said before, the trick is finding the good stuff without spending your kids' college tuition to do it. Sure, E-flite is great stuff, but the motors cost anywhere from 2 to 5 times what an equivalent unit from HK costs. I can't afford the luxury of that dependable level of quality, so I wasted a few bucks (!) finding out what I could rely on. If you use this board the right way you can find out for nada.
Old Nov 20, 2010, 02:16 PM
peterangus's Avatar
Joined Dec 2003
Jon
Further to my post #308.
The description of your test rig leaves much to the imagination.
Are you measuring stall torque ? [ie; with the motor prevented from turning]
If so, that's the quickest way to ruin a motor. And the readings will be meaningless.
Old Nov 21, 2010, 04:15 AM
Joined Nov 2010
Hi all
As requested
Old Nov 21, 2010, 05:47 AM
peterangus's Avatar
Joined Dec 2003
Jon
I take it that you are measuring "cogging" torque, with no power supplied to the motor.
The test results do not indicate any fault with the motors. They do not indicate poor quality control.
I see in post #298 that you did a test run with motor 1. The prop looks suitable since it slowed the motor to 75% of its no-load speed.
You should repeat this test run with the other 3 motors. Hopefully, they will all show similar performance.
Old Nov 21, 2010, 06:28 AM
Joined Nov 2010
Hi Peter
We agree on one thing the motor prop match is spot on. It will operate bang in the middle of the published best efficiency.
If the electro motive force of a motor results from the reaction of an electro magnet acting against that of a permanent magnet, please explain to me how one with 50% less strength in its permanent magnets can operate to the same specification.
Jon
Old Nov 21, 2010, 04:17 PM
Chicagoland
Joined Oct 2008
Jon, you aren't measuring the flux of the magnets with a test that measures cogging. You are only measuring cogging, a measurement that reveals very little about the actual performance of the motor. For instance, I used several 2204-1400 motors from both Grayson (Grayson/Welgard) and Hobby King (Turnigy). These motors were nearly identical in appearance, mass, KV, max current, yada yada yada. Their magnet clearances were different, so they cogged differently. On aircraft, however, they were nearly indistinguishable.
You need to do side-by-side comparisons of motors under load to determine if the cogging has any relation to real world performance. Look around here and you'll find all kinds of test jigs that have been created by insightful RCers with a bent towards collecting useful info that they can then share with the rest of us.
Old Nov 22, 2010, 01:32 AM
Joined Nov 2010
Hi AUG
I am still struggling to understand why six examples of the same motor and manufactured to a fairly comprehensive specification can have any measurable parameter that is so variable. Taking a scientific approach one would expect them to be identical in all respects.
OK you call it cogging but say that it says nothing about how the motor will perform. That's the bit I don't get.
Ultimately I have an open mind I just need to understand why. Thanks for your patience.
Discussion combining data for different brands of motors derway Power Systems 3 Oct 29, 2006 11:23 AM
Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. Steven Chao 3D Flying 0 Aug 29, 2005 02:10 AM
motor/prop test bench txzagi Power Systems 9 May 08, 2002 04:36 PM
motor/prop test bench txzagi Fuel Plane Talk 1 May 06, 2002 06:48 PM
Where to Get Service for Jeti Phasor Brushless Motors? GoEFlight Vendor Talk 2 Jan 09, 2002 11:34 AM
