| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Motor Data - test bench data for several hundred brushless motors.
For many years several of us have been generating and accumulating test stand data for a wide variety of electric RC motors, but the information could only be found, frustratingly scattered, amongst a myriad of threads in RC Groups.
Now Robert Goble has taken it upon himself to set up and maintain a webpage which provides a central, searchable source for all the available data: anyone with reliable test data is invited to contribute their information to the cause! [I've never counted them up, but Robert found 245 different motors in my EXCEL Spreadsheet]. http://www.flybrushless.com/ Welcome to FlyBrushless.com Mission Statement: To standardize brushless motor measurements in a comprehensible way, and to provide radio controlled aircraft pilots with a common resource for comparing and choosing the right motor for their applications. At this time, we are obviously still adding to/proof reading the data sets, so bear with us. [Adding in Io data and measurements, I've only got to letter G so far]. Much of the data posted so far is from my own testing [any and all errors are mine alone], but obviously lots of other people will add their data as this site evolves. As far as my own data are concerned let me add a caveat to the way in which parameters such as Io have been measured, and Kv and Rm have been calculated - I run no-load and prop tests on each motor... I measure Io/rpm at several voltages but typically have entered the figure I obtained @ ~10v into this database [manufacturers, if they give you an Io, usually do not state the voltage at which their Io figure was obtained]. I then use a program such as Motocalc or Drive Calc. to calculate Kv and Rm. I cannot see that there can be much argument over Kv (even though there are occasionally great disparities between my figures and those posted by manufacturers - where do they get some of their numbers? - no-load rpm divided by voltage applied is a reliable guide to at least a ballpark figure). For Rm, I find that often my figures differ substantially from those given by manufacturers and distributors - they may be using Rm for one phase (I know Mega does that), or Rm for the motor directly, when, in my case, an ESC has to be in the system. Any suggestions as to obtaining the most accurate figures are welcomed. We hope that this resource proves to be useful. Cheers, Phil Last edited by Dr Kiwi; Dec 10, 2008 at 05:30 PM. |
#2 |
If you have any questions or problems with the site please let me know here.
Also if you have any ideas for improvements I would be glad to hear them. Thanks, Robert Last edited by rgoble; Dec 10, 2008 at 01:00 PM. |
#3 | |
characters welcome
![]() For future information, you request a sticky using the Report Post To Moderator button and choose Stick/Unstick thread option. mw |
#4 |
I steer with my thumbs
Awesome! Thanks for sharing all your hard work!
Cheers Keith |
#5 |
Good Better Best quest.
Great
only suggestion i can make is to give the vertical columns colours ,as i work my way down i lose whats amps ect.but a worthwhile data base IMHO. |
#6 |
Thanks for the suggestion. I added a new header row that shows what the columns are ever 30 rows. That's about one every screen (at least for my resolution) and can be adjusted if needed. I was going to use the column colors as you suggested but I think this might work better.
I never realized the full extent of testing Phil did on these motors until I started adding his data to the site. Robert |
#7 |
I registered , but did not get my confirmation email ??
#8 |
I'm not sure what happened there. I sent you a pm to verify your email address and I activated your account.
Robert |
#9 |
homo ludens modellisticus
#10 |
Is that your site or does it belong to someone else? I don't want to add someone's data with out their permission.
Robert |
#11 |
It's not my site Robert, you have to contact Fredrik.
#12 |
I just emailed Fredrik, I will have to wait and see what he says. Thanks for letting me know about it.
Robert |
#13 |
I'm through all the entered motors.
For some of the motors I tested early on, I did not obtain no-load data... for those I still have, I will, in due time, measure those parameters. For other motors we may have to enter, in the interim, "manufacturer's data" which is a problem since we have no way of knowing how their figures were obtained - hopefully users may be able to contribute measured numbers for some of these. If you don't see a "Dr Kiwi Io data" entry, then you'll know that the Io and Rm are from some other source. For some motors I did not measure diameter and length [contributions please!] - we could use manufacturers' figures, but these require caution since some include the entire shaft in the "length" measurement (some only give stator length, and some are pure fiction!)... I have consistently used "body" length (end plate to end plate, or front face to rear of bell), since I think that gives the user a better idea of the physical size of the motor. For shaft size I have simply entered the nominal sizes (2.0mm, 3.0mm, 3.17mm, 4.0mm, 5.0mm) although every shaft is different (usually smaller by a few hundredths of a mm). Cheers, Phil Last edited by Dr Kiwi; Dec 11, 2008 at 05:27 PM. |
#14 |
Flying motor mount master
Great job Phil, this will be an invaluable resource for many folks who come to RCG for answers.
Now one question that comes to mind is watt rating. Are you guys just going to stick with the manufacturers recommendations or go with what people are flying at today? Again, great job! |
#15 |
The weights on the motors seem to be wrong when compared to Phils spreadsheet.
Look at the Suppo's...... |
| Thread Tools | |
| Discussion combining data for different brands of motors | derway | Power Systems | 3 | Oct 29, 2006 12:23 PM |
| Test pilots wanted for our AON brushless motors on E-flite Mini-Edge 540 3D ARF. | Steven Chao | 3D Flying | 0 | Aug 29, 2005 03:10 AM |
| motor/prop test bench | txzagi | Power Systems | 9 | May 08, 2002 05:36 PM |
| motor/prop test bench | txzagi | Fuel Plane Talk | 1 | May 06, 2002 07:48 PM |
| Where to Get Service for Jeti Phasor Brushless Motors? | GoEFlight | Vendor Talk | 2 | Jan 09, 2002 12:34 PM |
