Old Dec 10, 2008, 10:41 AM
zultone is offline
Find More Posts by zultone
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
Omg! Led's On A Plane!
So, question -
I have an Air Hogs U-Build it, and being winter here, it gets dark around 5:30-6:00... I get off work at 5:30, and don't get home until 5:40-5:45.
So, I want to put LED's on my plane to see it in the dark.
Here's my question-
Would it be easier to A
Hook the LED's to my motor wires, which would draw curent from the motor of an already under-powered plane, or
Use 2 1.5 volt (small watch) batteries and the LED's?
I want one on each wing tip, and one on the tail, so 3 in total, probably parralell.
zultone is offline Find More Posts by zultone
Old Dec 10, 2008, 02:34 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
A typical small LED draws 20mA.
A typical RC plane motor draws 100-1000 times as much.
Any questions left
Julez is offline Find More Posts by Julez
Old Dec 10, 2008, 02:35 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
You should be fine hooking them up right to the main battery with current limiting resistors etc.
BushmanLA is offline Find More Posts by BushmanLA
Old Dec 10, 2008, 05:13 PM
Ron W3FJW is offline
Find More Posts by Ron W3FJW
Ron W3FJW's Avatar
Tacoma WA
Joined Feb 2008
Here's an example of leds in an Akromaster..
http://myhobbycity.com/showthread.php?t=4146
Ron W3FJW is offline Find More Posts by Ron W3FJW
Old Dec 11, 2008, 10:20 AM
zultone is offline
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
well, I tried using 2 watch batteries on the plane, 3 volts, for 2 LED's in parralell, a hair too heavy...
I could definately to it in a series with a switch, straight into the battery mains with resistors... Maybe a POT? How small do pots come in? Variable so I can turn the lights up and down... Needs to be teeny tiny, smaller than a watch battery.
Discussion Please help !! (LED's on charger) tekkishodan Micro Helis 1 Oct 19, 2006 11:40 AM
Dimly lit LED's on apache 2500 + long charging times, is it busted? Peter W Batteries and Chargers 2 Jul 14, 2005 02:32 PM
Question backwards LED's on Lipo-103 charger and where to buy jumpers and 2.5mmbarrel to allig jay flay tway Batteries and Chargers 0 Apr 23, 2005 01:32 AM
Idea's On Next Plane..help jeddy11 Parkflyers 12 May 05, 2002 11:02 AM
Idea's On Next Plane..help jeddy11 Foamies (Kits) 3 May 04, 2002 06:03 AM
