Old Feb 02, 2009, 10:33 PM
Taipei, Taiwan
Joined Oct 2005
It's better to measure RPM under stable light source. Doing it under sunshine can be much better.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Feb 02, 2009, 10:38 PM
Taipei, Taiwan
Joined Oct 2005
Just cancel the RPM function then enter it again to measure the RPM, or perform another functions.
Chen
Old Feb 02, 2009, 10:41 PM
Joined Jan 2009
The "peak" function is very helpful!
I've been using it outside, in bright sunlight.
Again, mine measures rpms when the prop is stationary: it is not predictable.
I suspect I must learn exactly how to use it.
hymyankel is offline Find More Posts by hymyankel
Old Feb 03, 2009, 12:54 AM
Taipei, Taiwan
Joined Oct 2005
Just put the spinning propeller in front of the sun, then point the measuring port to the rotating prop, be sure to keep 5-10 cm or 2-4 inches away from it.
Chen
Old Feb 03, 2009, 12:55 AM
Joined Jan 2009
That's my method. I'll try again, tomorrow. I do really like the servo test functions!
Old Feb 03, 2009, 02:41 PM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS4CEO is offline Find More Posts by GWS4CEO
Old Feb 03, 2009, 02:43 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Old Feb 03, 2009, 02:45 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Old Feb 03, 2009, 02:46 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Old Feb 03, 2009, 02:47 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Old Feb 03, 2009, 02:49 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Old Feb 03, 2009, 02:52 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Do you have GWS MT-1?
Pls order from your favorite LHS or go: www.caliberhobby.com
It's at promotion priced $30 now, but sooner or later back to $40!!!
Old Feb 03, 2009, 03:29 PM
Joined Jan 2009
O.K., I give up on the tachometer function: it is either too difficult to use, badly designed or mine is defective.
As a servo tester, it is perfect.
So, DON'T buy it for the tachometer function.
I should add, I spent 30 minutes yesterday and 30 minutes, today, in broad daylight, trying to get the tachometer to perform in any reliable or repeatable manner.
Old Feb 03, 2009, 04:11 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
I am sorry this better function caused you inconvenience to use.
So, GWS should not put too many functions all in one equipment?
I remember, some one said: " Simple is the best! "
Old Feb 03, 2009, 04:15 PM
Joined Jan 2009
I think it is a wonderful function to have SO KEEP IT.
IN MY CASE, either it is defectively manufactured, defectively designed or I'm just too stupid.
I had several friends try it with the same result, so I merely "suspect" MINE is defective.
SUM: KEEP IT, IT'S A WONDERFUL FUNCTION IN AN OTHERWISE VERY, VERY WELL DESIGNED, EXTREMELY USEFUL DEVICE.
Discussion Gws Mt-1綜合測試器 GWS4CEO Taiwan 2 Dec 13, 2009 01:10 PM
Discussion GWS MT-1 RC Multi Tester GWS4CEO GWS (Grand Wing Servo) 21 Nov 19, 2007 04:59 PM
GWS props $1.20 each scmodchips Aircraft - Electric - Airplanes (FS/W) 2 Jun 23, 2003 04:11 PM
GWS 3:1 drive - anybody used it? Matthew Allen Parkflyers 3 Mar 19, 2002 11:24 AM
