Old Dec 09, 2008, 05:26 PM
czechyour6 is offline
Find More Posts by czechyour6
überprüfen Sie Ihre sechs
czechyour6's Avatar
Central Utah
Joined Feb 2005
Help!
Flycamone2 firmware update not working
I just got it, was trying to update firmware, not real clear instructions, i installed the driver so I can hook it up to computer. Any ideas or sequences that will work?
czechyour6 is offline Find More Posts by czechyour6
Old Dec 09, 2008, 06:32 PM
FL Knifemaker is offline
Find More Posts by FL Knifemaker
St. Boondock
FL Knifemaker's Avatar
Joined Aug 2008
I never got mine to work.
FL Knifemaker is offline Find More Posts by FL Knifemaker
Old Dec 10, 2008, 06:58 PM
sylifis is offline
Find More Posts by sylifis
sylifis's Avatar
So. Calif.
Joined Nov 2008
I don't know if this will help you. I got my flycamone2 and immediately tried to install the v4 software update and I could not get it working. I eventually went back to the update site and first loaded the v3 software and the driver. I had a problem locating the STK driver at first but a search found it okay. Then once v3 worked I downloaded v4 and absolutely no problems since. Be sure you have your SanDisk installed and "clicked" locked in before doing the software updates as I am informed by Hobby Lobby that the camera has no memory of its own. Hope this helps.
sylifis is offline Find More Posts by sylifis
Old Dec 14, 2008, 10:35 AM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, CA, Anaheim
Joined Aug 2005
I think you should just give it to me.
denial15 is offline Find More Posts by denial15
Old Dec 28, 2008, 11:11 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
I had problems at first because for the latest 2 updates you leave the cam OFF and then hold in the MODE buttom as you plug in the cable.
Note:
Cam should not be connected when you install the STKO2H 2.0 camera driver. After that reboot the computer and Camera driver will show on new Hardware found note. Then you plug the cam in while holding in the Mode button. Works great. Note that STKO2H 2.0 should only be installed once otherwise next try uninstalls it! It will say Install or Uninstall while the files load. If you uninstall it run it again and it will reinstall.
boomer
boomerace is offline Find More Posts by boomerace
Old Jan 17, 2009, 11:42 PM
Tony_Fletcher is offline
Find More Posts by Tony_Fletcher
AMA #903699
Tony_Fletcher's Avatar
USA, VA, Alexandria
Joined Mar 2008
No success here with this new 4.01 firmware update. Followed the instructions multiple times over the course of an hour and have had no luck.
When I "Start the program STK02HU-Reinstall." That program will not load. Windows says "Device Can't be initialized."
Very frustrating. Not real impressed with this camera. The steps necessary to update the firmware couldn't be more convoluted.
Tony_Fletcher is offline Find More Posts by Tony_Fletcher
Old Jan 18, 2009, 12:18 AM
boomerace's Avatar
Joined Sep 2001
Tony did you follow my instructions above?
boomer
Old Jan 18, 2009, 07:50 PM
AMA #903699
USA, VA, Alexandria
Joined Mar 2008
Boomer: Thanks for you response. I did get it to work. I was not allowing the Windows "new hardware found" routine to install the driver. I didn't realize this was an additional step. I assumed that the install of the driver was all I needed. I think this issue was more a result of my Windows experience. I'm a Mac user and we don't do all this drive install/new hardware "found" stuff. These types of updates are much more simple on the Mac. Thanks for you detailed instructions.
Old Jan 18, 2009, 08:11 PM
boomerace's Avatar
Joined Sep 2001
Tony,
Glad I could help. The instuctions do suck!
boomer
Old Feb 02, 2009, 08:38 PM
b_carleton is offline
Find More Posts by b_carleton
The woods of New Hampshire
Joined Jul 2008
I've had three FlyCamOne2"s. I could not get two of them to work.
The one that worked okay was lost in a flyaway.
I upgraded as I was instructed and read the forums but nothing worked for me.
It is so frustrating to make a really nice flight and get myself all excited about
watching the video, only to find out that it recorded nothing.
It was really a nice little unit though as far as size, weight and features.
I've been hoping Acme would come out with a new version due to all the
problems with it but I dosn't look as it's about to happen.
I saved up $200 this winter and hopefully will find something better this spring.
b_carleton is offline Find More Posts by b_carleton
Old Mar 03, 2009, 10:51 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
WOO HOO!!! I got it. Thanks czechyour6. I'll be sure to get some video of the next "bag of Doritos". You can still use it any time you'd like. Um....I also have a Watt Meter you can borrow too.
Old Jan 19, 2010, 06:00 PM
traxxas4fun is offline
Find More Posts by traxxas4fun
Joined Jan 2010
ok im having issues with this! i have the same problem tony does.. im following these instructions.. http://www.rcuniverse.com/forum/m_9360808/tm.htm
7th post down
except i cant find one of these files STK02N 2.0 Update.exe
STK02NC-WC viewer.exe
STK02NU-Update.exe
the only option s i have are STK02HU 2.0 reinstall?
help
traxxas4fun is offline Find More Posts by traxxas4fun
Old Jan 29, 2010, 02:13 PM
mossrcgrps is offline
Find More Posts by mossrcgrps
Joined Mar 2007
Has anyone successfully installed the 2010 software from the Flyonecam web site?
mossrcgrps is offline Find More Posts by mossrcgrps
Old Jan 30, 2010, 08:50 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Please, can you post the link to this update?
Thank you
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 31, 2010, 10:31 AM
Joined Mar 2007
Update address
I logged on to
www.Flycamone.com
If you have success in installing please let me know the steps.
I'm starting with a blank Flycamone2 on a Vista computer, the previous SD card has been formatted.
Discussion Flycamone2 Not working out of the box skid56 Hobby Express (Formerly Hobby Lobby) 1 Apr 07, 2008 11:33 AM
"view new posts" feature not working Neil Morse Site Chat 3 Oct 25, 2001 07:47 AM
Auto Cig lighter socket not working anymore JoeR Electric Plane Talk 7 Sep 19, 2001 01:29 PM
What's up with "Hot Topics" Not working? slowflyer Electric Plane Talk 1 Sep 08, 2001 08:04 AM
ELMH Not Working! airwolf Electric Heli Talk 14 Jul 02, 2001 12:48 AM
