Old Dec 08, 2008, 12:53 PM
tweety777 is offline
Find More Posts by tweety777
tweety777's Avatar
Vlaardingen, The Netherlands
Joined Nov 2008
Build Log
Scratch-build, own-design ocean-going salvagetug 1:50
Hello guys,
My previous model wasn't yet fully finished, and today i've restarted the work on her.
It was originaly planned to build the Zwarte Zee III in scale 1:50, but as this was my first scratchbuild model there went a lot of things wrong which made me deside to keep the hull, that didn't have the shape i wanted it to have, and put an own-design superstructure on it, with interior.
As this is an own-design i could make everything like i wanted, and one of the results is more towingpower and higher topspeed, which meens that my version would be first at the ship in need.
It also meant that i was able to build her like i like it most.
The engine used to be a Speed 500E, but that one past on to the Well Enhancer, so this model is currently not available for sailing.
A replacement for the engine is not yet desided, but for now most the work will go to the Well Enhancer.
Here are some pics of the build.
As this was my first scratch-build model there has went a lot of things wrong.
The first thing was that i didn't use a normal keel.
Here is the inside of the hull before some major changes.
Here is one of the most dared changes, putting the whole main deck in the hull, for which parts of the hull had to be removed.
Here an drawing with pics from throughout the build.
Here the hull looks awful, but the stem is a bit the same as how i want to make it yet again, with foc'sle.
This is the progress of today, a bit of walls (which need to be increased in height) is attached, and the first part of the first webframe is made and placed.
Used an old picture and paint to make this Artist Impression.
And a picture of the same recepee to show what it will look like.
As these are only Artist Impressions there is probebly going to changes some things, but the foc'sle will come there.
Greetings Josse
tweety777 is offline Find More Posts by tweety777
Old Dec 08, 2008, 07:34 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Looks good Josse. Keep it up!
Tugboat Andy is offline Find More Posts by Tugboat Andy
Old Dec 08, 2008, 10:06 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
I like it too! Nice work!
Aerominded is offline Find More Posts by Aerominded
Old Dec 09, 2008, 07:07 AM
graphixman is offline
Find More Posts by graphixman
ΜΟΛΩΝ ΛΑΒΕ
graphixman's Avatar
Coastal Maine
Joined Jun 2007
Very nice Tweety! I like the work on the hull, very nice work there!
graphixman is offline Find More Posts by graphixman
Old Dec 09, 2008, 01:52 PM
LONGBIKE is offline
Find More Posts by LONGBIKE
If you cant find it Build it!
LONGBIKE's Avatar
NEAR ST. LOUIS ILL. SIDE
Joined Jan 2006
Looking great!
I found out the more you build the more you learn, The learning never stops!
Every time I build a new boat I figure out a different way to do things and I will think
"Why didnt I think of that before"
Looks great keep building!
Jeff
LONGBIKE is offline Find More Posts by LONGBIKE
Old Dec 09, 2008, 02:11 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Pretty intense with a bed next to the work bench.
420TEE is offline Find More Posts by 420TEE
Old Dec 09, 2008, 10:29 PM
tweety777's Avatar
Joined Nov 2008
Hi guys,
Thanks for the compliments!!
Hi 420TEE,
Thats really nice 'cause when i open my eyes when i'm laying in bed i can still see my models.
But i'm doing more and more work outside.
Greetings Josse
Old Dec 11, 2008, 10:38 AM
tweety777's Avatar
Joined Nov 2008
Hello guys,
Today i've been working pretty much between pretty much sleep.
Here are the pics of the progress.
The foc'sle is getting it's shape.
Started with the interior.
Some more work on the interior.
Here are the cabins getting in shape as well.
Here the first 3 cabins are getting in shape.
The entrance will stay where it is, i probebly won't be able to remove it.
It will be build as much out of sight as is posible (except for the door) because it isn't very realistic this way.
The interior has had the most progress, for it won't be easy accessable when the hull is finished.
And the last progress on the foc'sle.
I have re-attached the towing-things.
I've also started with the inside of the sloop.
I've also made a design, which isn't very accured because i didn't know all the sizes.
Greetings Josse
Old Jan 25, 2009, 02:01 PM
tweety777's Avatar
Joined Nov 2008
Hello guys,
Now that the Well Enhancer is progressing so much i thought it was time to give the Josse I a better look.
I've started repainting her.
The new colour at the underwater part of the model.
This is the colour used for the upper part of the hull of Well Enhancer.
I'm thinking of giving this model completly different colours, such as blue for the upper part of the hull, but i'm not sure about that yet.
Greetings Josse
Old Feb 24, 2009, 01:48 PM
tweety777's Avatar
Joined Nov 2008
Hello guys,
Today i've been working on getting this model running again.
Now the only thing that still needs to be done is placing the engine with support.
To do so the propshaft needed to be lengthened to be able to aline the engine properly, and now the engine is placed in the engine room of the real ship, at about 50 to 60% of the hull-length from the bow.
If the weather is good enough tomarrow i'll take her with me for a testtrial.
Greetings Josse
Old May 05, 2009, 09:04 AM
tweety777's Avatar
Joined Nov 2008
Hello guys,
I've decided to convert this model to an escort-vessel.
Right now i'm working on the convertion, but the armament will remain unknown for a while.
The main gun was allready under construction, so that only needs to be finished.
Here are the pics:
The 700 Torque engine is being put back in Josse I, and this photo also shows the current status of the model.
Foc'sle under construction. The main gun will be standing in front of the mast on the foc'sle-deck.
Gun as far as completed now dry-fitted on a not to be used deck.
And this was the last picture.
Greetings Josse
Old May 05, 2009, 01:47 PM
tweety777's Avatar
Joined Nov 2008
Next update.
More work on the bow.
Lights being placed.
Lights on.
The light on the right is the stern-light, but it needs to get a difuser.
Lights for when towing one vessel.
Lights for when towing 2 or more vessels.
LED's for the interior or pretty bright.
That's it for now.
Greetings Josse
Old May 05, 2009, 06:29 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
Josse
I had never seen anyone use those little right angle braces like that. You use those a lot (I noticed especially on your Well Enhancer) do they really keep things straight at a right (90 deg.) angle? If they do with the size of stuff I have to deal with I may use them to align the ribs to make sure they are perpendicular to the keel.
Foo
fooman2008 is offline Find More Posts by fooman2008
Old May 06, 2009, 03:20 AM
tweety777's Avatar
Joined Nov 2008
Hi Foo,
They may bend a little, so it is pretty well recommended to check them every time.
For the sizes i'm building now there really isn't a problem.
For bigger sizes i would recommend a larger version of those things so you have more momentum to keep things straight.
I actually wasn't aware of any other way to do this, but it works to me.
Greetings Josse
Old May 06, 2009, 08:37 AM
tweety777's Avatar
Joined Nov 2008
Here is a small update.
Been doing some research on the guns, and these are the guns that will used:
http://en.wikipedia.org/wiki/BL_4_inch_naval_gun_Mk_VII
This will be the maingun which will be placed in a protected turret.
http://en.wikipedia.org/wiki/1.1%22/75_(28mm)_gun
These will be the AA-guns in single-barrel "turrets".
These are the barrels i will use:
The barrel in the rear was planned to be used for the maingun, but that turned out to be a 225mm gun, so that one won't be used.
The front barrels (4 of them) are the AA-guns, and the only remaining barrel is for the maingun.
Here a update:
Maingun under construction.
Interior under construction while i can still get there.
The deck above it will be removeable.
Here the front end of the interior is being build.
Before this wall will come a massive block of wood.
And this is what it looks like from the shore.
Greetings Josse
Poll scratch build own design GOJIRADOR Sailboats 22 Aug 14, 2006 12:05 PM
Build Log Scratch built own design foamie... "Whiplash" glydr Australia 30 Jul 09, 2006 05:28 AM
Scratch Build design, need suggestions e-sailpilot86 Thermal 26 May 02, 2005 05:29 PM
Own design hovers at less than 1/2 throttle on cheap GWS 300 Tumbler Parkflyers 151 May 22, 2003 11:50 AM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
