| View Poll Results: Ducting inside fuse, what´s the best? | |||
| Ducting all the way to the fan! |
22 | 100.00% |
| Ducting ending before fan, fan using intake lip! |
0 | 0% |
| Voters: 22. You may not vote on this poll | |||
| Thread Tools |
Marell01
i think you should take a look at thise .. http://www.rcgroups.com/forums/showt...light=clausxpf it is down at post 13 i think it will get you into how it is done and for what reason. Claus at area 52 velocity-rc team ps... jeg taler dansk og svensk ... |
question
clausxpf
over in the foamey section I'm building a star max f-5 below are the results of fan testing out of fuse and in: note the loss in fuse , how can this be corrected? QUOTE:I ran the test to day these are the results using the 77MM 7 blade unit with just the fan housing in test stand using a 4s lipo at full charge 39.2 amps 513 watts trust 1357 grams trust then with a 6 " exust tube narrowed to 62 mm battery fully charged 40.3 amps 528 watts 1412 grams trust then mounted in f-5 fuse ducting sanded and coated,ducting smoothed for change in size of fan:with a fully charged battery 46.4 amps 547 watts 1118 grams trust it seems power when up and trust when down , and quite a bite of power loss , r vincent had mentioed that he had modifed his ducting to over come this and would show us his setup. I have the feeling that its not the airframe thats causing this to not fly as fast as we would like but Issues with the ducting inlets seem large enough and the ducting is smooth , possable that the split exaust is problem? |
pulsery2k1
is the intake lips (on the plane) roundet? Is the inlet-duct area ruled? 90-110% FSA is it with very soft direction changes? does the duct have a smooth surface? because dimples does not help in a duct..The only reason it works on a golf ball is it helps fill the vacum after the ball, and that way reduce the drag of the ball. when looking at a duct .. have in mind that the air inside is moving fast, real fast 140 mph ( 200km/hour) or even more with the better fans. It hits like a sleadge hammer. the split exhaust will give a little drag but still if area ruled it would be in the 5-8% area. The drop in static thrust when mounted in the model is normal but it is only for the first couple of meters that it means something at flying speed things change to the better. Claus at area 52 Velocity-RC team |
| Thread Tools | |
| For Sale Mint cond JR 8103 Radio with 3 Recvrs or W/O | fw-190 | Aircraft - General - Radio Equipment (FS/W) | 1 | Oct 21, 2008 08:31 PM |
| For Sale High Performance Prodigy wing kits ,with or w/o motor/prop | sylair | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 20, 2008 01:44 PM |
| Sold 27 inch wing kits with or w/o motors- on SALE | sylair | Aircraft - Electric - Airplanes (FS/W) | 15 | May 06, 2008 06:20 PM |
| For Sale Futaba 6EXHP (heli PCM) Computer TX with or w/o Rx | Etonic | Aircraft - General - Radio Equipment (FS/W) | 1 | Mar 15, 2007 03:31 PM |
| WTB: GWS Pico RX with or w/o Xtal, any shift. | LexTalionis | Aircraft - General - Radio Equipment (FS/W) | 3 | Oct 07, 2004 05:10 PM |
