This thread is privately moderated by BowerR64, who may elect to delete unwanted replies.
Old Dec 08, 2008, 06:15 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Walkera G001 Gyro board closeup pics
Here are some closeup shots of the walkera gyro board requested by another member. I had one apart so i took a few closeup shots of it.
Shot with a canon powershot S2 using the stock flash in super macro mode with a paper/cardboard flashring. ISO 50, F5.0, 1/500 shutter, max flash manual mode. Cropped with MS paint for file size.
BowerR64 is offline Find More Posts by BowerR64
Old Dec 08, 2008, 08:25 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
can you describe how to make that flash ring? The shots are great.
Gino CP is offline Find More Posts by Gino CP
Old Dec 08, 2008, 08:51 AM
Chophop is offline
Find More Posts by Chophop
What Tough Luck Is This ?
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Here is what I was looking for :
See in the lower left side of the board, next to the inter board connector pins. There is a capacitor, resistor and empty pads for something ? I amhoping a resistor goes there. A cap would be difficult to guess and I'm sure Walkera wouldn't answer, they rarely do.
This is a different board than Bower's. It is a G006.
Thanx Bower.
CH
Chophop is offline Find More Posts by Chophop
Old Dec 08, 2008, 06:03 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I made another blog entry with some idea of what im using and the cardboard flashring setup. I think one can be built for a smaller pocket camera, i never really tried. I probobly should sometime.
camera setup
Old Dec 08, 2008, 06:46 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I think this gyro will only be good for rate mode, or some goofy experiment. X the HH mode. The rate mode piro rate is like a snail, my old Walkera 4 has more piro than I can get with this cheapo.
CH
Old Dec 08, 2008, 07:26 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I dono, like i said i liked the 006 in rate mode when i had one. It flew really good. I wouldnt mind having another one
If you notice how that sensor is mounted in foam in the center of the board. Is yours square with the case?
I moved mine on a couple of my helis. I put it on the top of the board and then i mounted the gyro on its side up under the boom.
Old Dec 08, 2008, 07:54 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
I did think about flipping the sensor. I'll just use it on a docile rate mode heli.
I've been working up the stuff for a King V2 I am getting. The problem is, I was supposed to gut the belt tail CP2 to build the King, but after flying it a few more times, just can't shoot a horse that can run.
I guess it's gonna be a whole new heli, servos, gyro, AR6000, and set of lipos. I may back out and continue to fly the CP2 on old 3 cell lipos that are too weak to fly the 400's. I cut them down to two cells and the CP2 , specially configured for 2 cells, has as much or more climb rate as the 400's on new lipos, and it can easily fly 10 minutes. I limit it to 9 for safety. 2 cell helis can be a trick for the BEC because there is not much voltage margin on a 2 cell system. You can get to 3v/cell on a 3 cell and the BEC has plenty of reserve. Down to 3v/cell on a 2 cell and it's a gamble as to the BEC having enough input level to power the radio/servos etc.
CH
Old Dec 08, 2008, 10:08 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I have a 450 on a 2200 2S pack and it flys awsome. Its one of my favorite slow flying helicopters. I put those 325mm flat bottom plastic blades on it and i fly it around every now and then. Ive never had a problem with the bec not having the right voltage.
I usualy fly a 6EX radio and the esky 6ch king receivers. I dont think they have issues with low voltage like the newer radios do.
Old Dec 08, 2008, 10:18 PM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
There is a thing called dropout voltage that BEC's have. Below the dropout voltage , operation can be unpredictable, like turning off/on or unstable output. Be careful, it can sneak up on you, especially when very low on the battery and you jam full up collective.
I think the becs I saw work 6 or 6.5v up to 4 or 5 cell lipos.
And so far, by the old (new ?) break the old 3 cells into 2 cells technique, I got just at 550 flights in that I otherwise wouldn't have. Beats making lipo explosion videos.
CH
Rant cannot believe this. mixer gyro board fabtechprerunner Micro Helis 25 Jul 22, 2004 10:37 PM
Gyro Board won't initiate jeff2215 Micro Helis 7 Apr 12, 2004 01:26 AM
Aerohawk Piccolo/Gyro Board Repair jeff2215 Micro Helis 6 Mar 12, 2004 01:42 PM
Aerohawk Gyro Board jeff2215 Micro Helis 0 Feb 18, 2004 08:20 PM
My New Corona is done Question about Gyro set-up? PICS RCKing Electric Heli Talk 12 Apr 29, 2002 12:30 PM
