Everett Wa.
Joined Jun 2001
Fun Build II Guillow's Cherokee, 20 inch plan build
Gentlemen I’m entering the Fun Build 2 contest with a plan built Guillow’s 20 inch Piper Cherokee. These plans are found in the Guillow’s kit #307. As the rules state plans only this forces me to change the cowl design. The original kit suffers from the bane of most Guillow’s kit that is the awful plastic cowl. I have redesigned the cowl to be an integral part of the fuselage and made of balsa wood. I hope to work out a full flying stabilizer. I will have an operational rudder with steerable nose wheel. I also hope to have ailerons. The landing gear will be my now standard torsion bar style with high anchor. Other than the shape of the cowl (I hope I make it more scale) the outline of the little Cherokee will be close to that of what is drawn on the Guillow’s plan sheet.
I have hand cut the fuselage formers to be about 1/3 the weight of what is shown on the plans. I have also redrawn the airfoils to have a large Philips entry. I have also taken out some of the chamber from the front of the airfoil. While there may be some debate as to the virtue of the stock airfoil for free flight it offers no benefit for the R/C pilot. Also as I’m hand cutting all the parts I have decided to try to laminate all four keels from 2 each 1/16 square strips. This will add a lot of strength while saving me the time to cut the side keels from sheet. I have also eliminated the deep keel slot from the fuselage formers. As the Cherokee’s fuselage is almost as wide as it is tall, half the formers grain is going the wrong direction. To solve this I have glued some 1/16 square supports to the top and bottom of the formers These supports not only support the grain of the former but also act as keys to align the other half of the former as one builds the other half of the fuselage (in the air, off the board).
Everett Wa.
Joined Jun 2001
Fuselage is starting to look like a canoe! The second stringer from the bottom keel is doubled between B2 and B4 as this will become the side of the hatch opening. This doubler tapers to nothing outside of B2 and B4 so as not to kink the main stringer. You can also see a side stringer doubler in front of B2 to support this stringer, as it tries to bend into the cowl. As the formers are rather weak until all the "H parts are added, I had to add a temporary building aid to keep the top and bottom apart while I bend the stringers. I hope you can see the 1/16 cross pieces on some of the formers top and bottom. This keep the formers from being crushed as the wood grain in the former is going the wrong direction. This is a problem with most Guillow kits and is made worse with the narrow cross section I choose to use.
I have made the cowl a little wider than stock and with a much more triangular shape up front. The nose block will be made from 7 layers of 1/16 balsa. Top of the nose is open until I add the motor firewall and nose gear hard points. Most of the cowl sides will be inlayed with 1/16 (now 1/8) balsa to give strength and shape to the nose. Konrad
Everett Wa.
Joined Jun 2001
I'm sorry I misspoke when I said earlier that I would use 1/16 balsa for the cowl inlay work. What I am using is 1/8 contest grade balsa. Contest grade is balsa that weighs about 4 to 6 lbs per cubic foot. This is half the weight of most “good balsa” I build most of my ships from 8 lbs to 10 lbs wood. This means that for the same area of wood my 1/8 contest grade balsa part weighs about the same as my normal 1/16 sheet part.
The added dimension of the 1/8-sheeted inlayed part allows for more shaping with the sanding block. This is a real benefit as there are a lot of contour changes in the front of this Cherokee cowl. In one of the photos you can see the final shape on the right and the raw blocks on the left. It would have been almost impossible to bend the 1/16 sheet to make the shape needed. But with 1/8 contest grade inlays I was able to do this and still be about 3/4 the weight that it would have been had I used 1/16 8 lbs sheet inlays. I hope you can see that some of the curves were so severe that I needed to cut some of the inlays on the bias (grain going diagonally). I did not like the way the front of the fuselage was blending into the wing mounting box. This is why I moved the bottom stringer up 3 mm from where it is shown on the Guillow's plan on the first Guillow former. With some gusset work later on this should look OK. All the best, Konrad
Everett Wa.
Joined Jun 2001
I have to admit I like the faceted look of well-placed stringer. But the starved horse look of the formers sticking through can destroy the nice look. As the covering can only span straight across the stringers any curve to the fuselage cross-section needs to be controlled by the placement of stringers not the former itself. To test to see if there are enough stringers and that they are properly placed I do a credit card test. This test is accomplished by placing a credit card across two adjacent stringers. Then moving the credit card along the stringers. If you can feel any disruption (bump) to the smooth movement of the credit card this means that whatever it is causing the bump will show through when you cover the ship. To solve this one usually scallops the formers between the stringers.
Now if the credit card actually stops or sticks this means that there may not be enough stringers to define the cross section of the model (former). Should this happen I add extra stingers where needed to help define the shape. Some times there is no option but to leave the former as it was cut. When this happens such as around windshields and hatches I use a gusset between the stringers to help transition the covering from the stringers to the former.
| Thread Tools | |
| Contest Fun-Build 2 - Guillow's B-24 Liberator conversion FLIES!! | Smokin' Beaver | Scale Electric Planes | 223 | Aug 14, 2012 05:30 PM |
| Contest Kit/Plan Fun Build - Guillow's DH4 | Smokin' Beaver | Scale Electric Planes | 91 | Jun 12, 2008 06:17 AM |
| Build Log Guillow's B-17G Electric Build | crxmanpat | Scale Electric Planes | 20 | Mar 03, 2007 04:47 PM |
| Question To build a Guillow's Messerschmitt BF-109 or not? | Wally_Gator | The Builders Workshop | 4 | Jan 31, 2007 01:32 PM |
| Guillow's build... | Scudrunner77 | Indoor and Micro Models | 11 | Nov 18, 2005 11:28 AM |
