Old Dec 07, 2008, 06:53 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
EPP Yak55M Indestructible practice plane 138gr AUW
Here is a pretty nice flying,and very durable plane.
Thread
A lighter build has been completed and flown Dec 23 2008, AUW 158 grams.
EPPYak55.wmv (3 min 4 sec)
leadfeather is online now Find More Posts by leadfeather
Old Dec 07, 2008, 08:10 AM
Dimitry999 is offline
Find More Posts by Dimitry999
Hungary
Joined Feb 2007
Nice build and painting! Looks similar to FF yak 55m but smaller control surfaces. Next time try do build it from 3mm depron, it'll make it way lighter.
Dimitry
Dimitry999 is offline Find More Posts by Dimitry999
Old Dec 07, 2008, 09:03 AM
Winging it >
Joined May 2006
Dimitry
It is a similar size to the FF yak, and once I can fly better I will probably upgrade to the FF Yak kit.
At this point, I would have already totally destroyed 4 or 5 depron Yaks, yet with all the crashing I have done with this epp yak it still looks brand new.
AUW minus battery is 167 grams with a Blue Wonder motor and 12 gram esc. There is room for improvement on weight.
Very cheap and easy to build too. The only carbon is the wing spar and tail spar. No other bracing required. The entire airframe is cut from 1 sheet of 18" x 36" epp from RCFoam.
I wasn't expecting to have something competitive for the F3 type competitions, however, for a practice/learning plane I think this one will serve me well.
Dan
Old Dec 07, 2008, 12:21 PM
Winging it >
Joined May 2006
Dimitry
BTW the paint job was by Adreher...he does phenomenal work. Check out his posts to see more of his artwork. He's also a very good pilot.
Old Dec 08, 2008, 09:14 AM
yuefeifei is offline
Find More Posts by yuefeifei
yuefeifei's Avatar
china
Joined Feb 2008
nice one!It flies so slow!
yuefeifei is offline Find More Posts by yuefeifei
Old Dec 08, 2008, 09:52 AM
Fune is offline
Find More Posts by Fune
Fune's Avatar
Costa Rica
Joined Jul 2006
Nice paint
Fune is offline Find More Posts by Fune
Old Dec 08, 2008, 11:28 AM
Winging it >
Joined May 2006
Thanks guys!
Slow flying is exactly what I was after...and durability. Flying that slow gives my brain time to figure out which way to move the sticks. The epp stands up to the punishment I inflict when I still move the sticks the wrong way occasionally.
Old Dec 09, 2008, 01:01 PM
Wulf_Flieger is offline
Find More Posts by Wulf_Flieger
ProBro Wulf
Wulf_Flieger's Avatar
Joined Oct 2006
Would it be possible to get a copy of your plans for this plane?
Wulf_Flieger is offline Find More Posts by Wulf_Flieger
Old Dec 09, 2008, 02:02 PM
Winging it >
Joined May 2006
Here you go, post #2:
Plans
Old Dec 09, 2008, 07:14 PM
ProBro Wulf
Joined Oct 2006
Thanks!
Old Dec 10, 2008, 10:45 AM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
I like it!
Lighter is always better, but it seems to fly really well. It's just the sort of thing I need to practice F3P and 3D. I'm wondering what the punch-out is like though. I didn't see anything really aggressive in the video. Is it capable of a strong punch-out?
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Dec 10, 2008, 05:49 PM
Winging it >
Joined May 2006
Originally Posted by skunkworks2006
I like it!
skunk, I didn't really try to punch it out of hover, but I think it would be OK but not spectacular at this point.
I am planning on doing more work to get the weight down. It is fun the way it is, but as a personal challenge I want to see if I can get it down to the F3P type of weights but keep it just as simple to build at the same time.
If I can get the weight down, I think the performance will be closer to the F3P machines especially if you use a comparable power system.
Old Dec 17, 2008, 10:26 PM
Winging it >
Joined May 2006
I like it!
I agree lighter is way better!
Hereare a couple of photos of the lighter build in progress now. Target AUW is between 150 and 160 grams
Old Dec 24, 2008, 07:13 AM
Winging it >
Joined May 2006
I like it!
Skunkworks,
Here is a video of the lighter build, 158 grams AUW, lighter Yak in it's first outing last night. You'll get to see strong punch outs.
You'll also get to see one of many durability tests the Yak was put through last night. Passed all the durability tests (crashes) with flying colors.
Skinny Yak (5 min 12 sec)
Old Mar 17, 2009, 07:56 AM
Winging it >
Joined May 2006
Under 5 oz
The development has continued. The Yak in this video is now under 5 oz AUW.
EPP Yak55 (3 min 22 sec)
Discussion EFM Extra 300 EPP ARF - The IMAC Practice Plane! 3d_Crazy 3D Foamies 1402 Mar 08, 2012 01:18 PM
Discussion Axis EPP - 'crashable' aerobatic practice plane signflyer Foamies (Scratchbuilt) 8 May 27, 2011 10:29 PM
For Sale EPP Extra IMAC Practice Plane Ted U Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2006 06:41 PM
Idea EPP F3P Practice Plane? 3d_Crazy Indoor Pattern/F3P 26 Feb 15, 2006 10:34 AM
Discussion EPP F3A-I practice plane? pkruse 3D Flying 7 Jan 19, 2006 02:32 PM
