Old May 15, 2001, 09:22 AM
Wake Forest, NC USA
Joined Apr 2001
power system for akromaster
OK, I'm shelving the ECL speed 400 idea for now. Here's my new approach.
Assume an e-constructed Sig Akromaster. (34 inch wingspan, about 240 squares, and the box says .15 to .19 engine.)
What do you suggest for the motor, gearbox, prop, and battery combination to get the most aerobatic performance with a reasonable flying time for a budget of $125 for those 4 items.
(The $125 is not meant to be a hard number. Just a designation that says it's not 'cost is no object,' and also not 'as cheap as possible.')
thanks for your ideas, glenn
gponder is offline Find More Posts by gponder
Old May 16, 2001, 08:35 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Not sure, but I think that a "stock 27 turn" car motor w/direct drive 8x6 prop on a 7x1500 car pack, using a low voltage cut-off relay ( http://www.ezonemag.com/disc/Forum14/HTML/000028.html ), might give you some good flight performance.
Too big for S400 and a bit small for monster truck motors like Magnetic Mayhem; so in between would be S500 or 27T car.
Also, you ought to be able to put this power package together very easily; maybe even with stuff left over from a RC Car nut!
jrb is offline Find More Posts by jrb
Old May 22, 2001, 08:01 AM
Wake Forest, NC USA
Joined Apr 2001
What's the downside of using the Magetic Mayhem motor if it is 'too powerful.' I'm thinking the MM would be useful for a subsequent model, so maybe it could handle the akromaster first.
Old May 22, 2001, 08:10 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Only that MM is just a little heavier than a "stock" motor, and may also need to be purchased.
Originally proposed system (actually use 6 cells) could be gotten FOC from RC car buddy.
Servos and power system for XL3200? jshelton Electric Sailplanes 23 Oct 13, 2002 07:43 AM
Any subjection on power system for F5D ? gouang High Performance 12 Dec 22, 2001 02:47 PM
Alternate power system for P38 ( is it possible?) BlueAce Scale Electric Planes 8 Nov 20, 2001 03:48 PM
Best power system for the Hobby Lobby Champion? Jason M Parkflyers 6 Oct 05, 2001 02:11 PM
Suggestions for Power System for Robbe K-rat TThroop Electric Sailplanes 1 May 10, 2001 05:47 PM
