Old Feb 28, 2003, 07:55 PM
ControlFreak is offline
Find More Posts by ControlFreak
Antioch CA
Joined May 2002
Will this fry my brushless controller?
Controller is a Jeti JES 70-3P with BEC 7 to 12 cells
Can this controller handle more that 12 NiCads? And still provide BEC?
Can I use this with a 13 cell 3000NiMH?
My logic is; since voltage from NiMH is 1.1 Vs. Nicads at 1.2 then a 13cell NiMH has slightly lower voltage than a 12cell Nicad. Is this correct?
Thanks in advance for your help
Dennis
ControlFreak is offline Find More Posts by ControlFreak
Old Feb 28, 2003, 08:02 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Wrong! Nicads and NIMH have the same voltage. In any event the problem is overheating the BEC. If that happens it will stop supplying the 5 volts needed for the radio. Be safe and use a small Rx battery.
Steve
sneu is offline Find More Posts by sneu
Old Feb 28, 2003, 08:13 PM
rc-eflyer is offline
Find More Posts by rc-eflyer
T:W>1= :>)
rc-eflyer's Avatar
St. Louis, Missouri, United States
Joined May 2002
Steve
Wrong! Control Freak is correct, NiMhs have a lower nominal
voltage per cell as a general rule. Steve is right though about
overheating the BEC as it has to drop more voltage to get
down to the 5V which is dissipated as heat.
rc-eflyer is offline Find More Posts by rc-eflyer
Old Feb 28, 2003, 08:38 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Re: Will this fry my brushless controller?
Originally posted by ControlFreak
13 cell 3000NiMH
If your going to fly a plane that can handle that much weight, I'd go with a 4-5 cell flight pack or a UBEC.
Your asking a lot from your speed controls BEC circuit for that many cells.
William A is offline Find More Posts by William A
Old Feb 28, 2003, 08:48 PM
Antioch CA
Joined May 2002
Can I use a fight pack w controller w BEC
Can I use a fight pack with controller that has BEC?
And if so can how many cells? The controller says "6 - 12 NC" on the label.
Thank you
Old Feb 28, 2003, 08:54 PM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Re: Can I use a fight pack w controller w BEC
Yes, just remove and isolate the power wire between ESC and Rx.
Old Feb 28, 2003, 09:15 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Wrong! Nominal voltage of NIMH's is the same as NiCad's. NIMH's tend to sag in voltage a bit more than nicads during flight, this gives rise to the 1.1 volt philosophy. However, NIMH's are getting better and better and sag less now than ever. If your counting on sag so that you don't blow your ESC up, your walking on very thin ice. My advice: Get a UBEC or use an Rx battery.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Mar 02, 2003, 12:23 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
-Jim
OK, "nominal" was a poor choice of words but I think
the common understanding and use of NiMh for our purposes
and what ControlFreak was referring to in the original post
was that we normally use a greater number of NiMhs than
NiCd to acheive the same voltage under operating conditions.
So just saying they have the "same" voltage was not a good
answer to the orignal post imho and that's why I considered
it "wrong". I do agree with your statement about the "thin ice".
I apologize if I stepped on any toes , I never meant to.
Old Mar 02, 2003, 12:58 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
The high rate NIMH and Nicads have teh SAME voltage under load. In fact some of the latest NIMH actually have higher cell voltage that the same sized Nicads. The is no reason to add cells if you use quality batteries intended for high rate use.
Steve
Old Mar 02, 2003, 02:48 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Steve
That, I did not know . That's why I love this forum, you
can always learn something if you are willing to keep an
open mind. Thanks Steve.
Old Mar 02, 2003, 11:13 AM
Antioch CA
Joined May 2002
It did not fry
Nothing like real world flight test
Flew today on 13 cells. Put it through some serious paces and no fried speed control. My guess is that the manufacturers rate at level below what it can actually handle ... to provide a safety margin.
Tomorrow I try 15 cells (just kidding!)
Thanks for all the responses
Dennis
Old Mar 02, 2003, 11:37 AM
harryo is offline
Find More Posts by harryo
Mmmm... crunchy balsa.
harryo's Avatar
United States, CA, Oakland
Joined Sep 2002
Dennis, You flyin today!?!
Be very very careful of your servo current draw. If there is asbolutely no binding or friction on them, then you might be okay. When flying at high speeds, you know these servos draw more current. So it becomes another gamble.
Added: As the vIN to the ESC increases, it has to work harder to provide the 4.8v to the receiver. This increases the risk of cooking the BEC FET.
How many servos? What kind of plane? Is it your hotliner?
Just asking 'cause I lost an ESC from this very thing. Luckily, it was on the test stand. The ESC was rated for 3 servos up to 10 cells, so I tried 12 cells. Wouldn't you know, I got record breaking thrust measurements. (for about 10 sec) Then I moved the control surfaces and everything whent dark.
When it comes to recievers and radio equipment, I'll never stray from the suggested parameters. Motors, ESC and batteries on the other hand...
So what's the deal? you flying today or what?!?
cheers,
-=h=-
harryo is offline Find More Posts by harryo
Discussion Will this FRY my ESC or RCVR? king-fisher Power Systems 5 Apr 06, 2006 08:24 PM
Will Using A 10 Cell 3300pk Fry my Speed Controller BatteryJockey Power Systems 6 Aug 21, 2004 07:27 PM
What is this on my brushless ESC KonstantKrash Modeling Science 4 May 15, 2003 03:39 PM
I just SMOKED my Brushless Controller ewhahn Electric Plane Talk 6 Oct 20, 2002 10:35 AM
Will this make my Champion go. Paul Susbauer Parkflyers 8 Dec 10, 2001 11:02 AM
