Old Feb 25, 2013, 10:15 PM
rajeev is offline
Find More Posts by rajeev
Joined Jul 2004
Hi guys! I am planning on building the 32.5" version using 6mm depron with a 3s battery and 8045 prop for outdoor flying. I want this one to be light and slow and as much 3d-ish as possible. Request your advice on the motor. I have heard lots of good reports on HK 2730 but I am trying to stick to what is available locally (HK Australian warehouse) to keep the costs down. So, here are my options:
Option 1: Turnigy Park300 Brushless Outrunner 1600kv
Battery: 2~3 Cell /7.4~11.1V
RPM: 1600kv (Isn't this a bit too high for a light and slow 3d?)
Max current: 9A
Weight: 25g (not including connectors)
Option 2: Turnigy Park300 Brushless Outrunner 1380kv
RPM: 1380kv
Max current: 7A (77 watts? Isn't this a bit low?)
Current capacity: 9A/15sec
Weight: 24g (not including connectors)
Option 3: hexTronik 24gram Brushless Outrunner 1300kv
Kv - 1300rpm/v
Max Load: 7.5A (Isn't this a bit low too?)
Thrust: 400g+
Weight: 20g
So what do you think will be a good motor for my new Yak?
LF, a big thanks for the beautiful plane !!!!
rajeev is offline Find More Posts by rajeev
Old Feb 26, 2013, 01:12 AM
Blaser is offline
Find More Posts by Blaser
Blaser's Avatar
Joined Mar 2012
I like the 2730 1300kv with a 8x4gws dd @7.5 amps 500 grams thrust and if you like a lot more power 9x5 @ 10 amp 590 g. of thrust this is what I use but the 1500kv with a 8x4 DD works great
http://www.hobbyking.com/hobbyking/s...er_1500kv.html
Max current: 9A
RPM: 1380kv
Kv - 1300rpm/v
Thrust: 400g+
Weight: 20g
Blaser is offline Find More Posts by Blaser
Old Feb 26, 2013, 05:56 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Max current: 9A
RPM: 1380kv
Kv - 1300rpm/v
Thrust: 400g+
Weight: 20g
Any of those motors may work fine. It's all about trade offs.
The weight of the HXT 2730 is more like 27 grams, not 20 grams listed for the motor. Some motors have built in prop savers and motor mounts, so I include prop saver and motor mount in the weight for a good "as installed" comparison.
Trade offs:
In general; as kV goes up; use smaller prop, prop torque goes down, static thrust efficiency goes down, maximum power available goes up, top speed goes up.
In general; as kV goes down; more static thrust efficiency, less amps to hover, smaller esc and battery possible (weight savings), bigger prop and more prop torque,
Also properly designed 2s system ( system means correctly matched prop, motor, esc and battery) will have better static thrust efficiency than 3s system.
For slow and floaty flying that you want, light weight is the key.
If you do a really good job keeping the air frame light, you may even be able to drop a motor size, and smaller battery and esc too for more weight savings. You have to work a lot harder to do this successfully.
leadfeather is offline Find More Posts by leadfeather
Old Feb 26, 2013, 10:09 AM
tele1974 is offline
Find More Posts by tele1974
tele1974's Avatar
USA, OH, Olmsted Falls
Joined Feb 2007
EPP Full fuse plans? Anyone?
tele1974 is offline Find More Posts by tele1974
Old Feb 26, 2013, 02:27 PM
Jack the R is offline
Find More Posts by Jack the R
Jack the R's Avatar
Joined Aug 2009
Originally Posted by balesse View Post
and I like the tube better than the Foam Tac bottle.
Yep - love the glue, hate the bottle.
Jack the R is offline Find More Posts by Jack the R
Old Feb 26, 2013, 02:35 PM
Markran is offline
Find More Posts by Markran
Markran's Avatar
United States, CA, Sacramento
Joined Aug 2011
Originally Posted by WMParkFlyer View Post
We have been using and selling foam Tac for over 6 months now on EPP as well as depron. I placed a glue hinge in direct sunlight as well as heat ... on the dash of my car ... there was Zero discoloration and no degradation of the glue hinge.
GM
WMParkFlyers.com
Thanks, that was exactly the confirmation I've been wanting to hear. BTW, the plane that yellowed from the Welders is the first I used it on, my beloved McFoamy XL...
Markran is offline Find More Posts by Markran
Old Mar 01, 2013, 09:29 PM
nhibberts is offline
Find More Posts by nhibberts
Joined Jan 2013
yet again
yes i said it yet again. Im going to start witht he 19 in and work my way up building all the sizes. build and fly till i get bored with one and on to the next
nhibberts is offline Find More Posts by nhibberts
Old Mar 09, 2013, 03:17 PM
dr.E is offline
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
Welders should have come with an UV stabilizer(HMMM?).... For my PSS Sloper airplanes I used to use Goop but that yellowed too untill the guys started using Marine Goop... Those are powerfull fumes though....
dr.E is offline Find More Posts by dr.E
Old Mar 10, 2013, 02:22 PM
joker24458 is offline
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Soooo.....any new info on 3mm depron Yaks?
-joker
joker24458 is offline Find More Posts by joker24458
Old Mar 10, 2013, 02:29 PM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
-joker
I have the carbon figured out and should have some kits at Toledo. I'm hoping to do the picture build for the instructions in the next week. Surprise blizzard on friday put a damper on my schedule this week. Are you looking for painted or unpainted?
coreman is online now Find More Posts by coreman
Old Mar 10, 2013, 02:43 PM
joker24458's Avatar
Joined Mar 2012
Well, I am not sure. I might buy a 3mm Yak later this year (yeah....another delay ) because I just bought a Twisted Hobbies Crack Yak, used up all my allowance (I do not regret that at all, though, the CY is great! ). But speaking about later this year, it depends on the color scheme. I will most likely buy it painted though, I would not like to ruin a nice LF Yak because I painted it badly. For the meantime, though, are there any new videos?
-joker
Old Mar 10, 2013, 02:56 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I have another video from 2 weeks ago I need to finish editing and upload. Soon
Are you going to Toledo? if so, stop by the National Balsa booth and say Hi
Old Mar 10, 2013, 03:31 PM
joker24458's Avatar
Joined Mar 2012
Yes, I am definitely going to Weak Signals on the 6th (Saturday) and I will definitely look for National balsa and say hi.
-joker AKA Andres (real name)
Old Mar 10, 2013, 03:49 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Very cool. See you then/there
Jim
Old Mar 10, 2013, 04:51 PM
joker24458's Avatar
Joined Mar 2012
Ok, sounds cool.
-joker
