Old Feb 25, 2013, 01:05 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Originally Posted by joker24458 View Post
Ok, thanks. I can't make it to the WRAM show though. Will it be at the Weak Signals Show?
-joker
Well, when you wrote that we were driving home from WRAM. There will be kits at the show in the National Balsa booth. I probably won't be building any 3mm Depron versions as transportation would be an issue. The EPP can take the bounce packed in a trailer better.
It was a good show. The 10 RTF Yaks I took were gone in the first 4 hours. Wish I had had more notice that I would be going. It looks like Toledo, SEFF and Joe Nall on on the the immediate calendar
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Feb 25, 2013, 02:23 PM
joker24458 is offline
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Wow, they sell fast! But that is not surprising...... Also, I will look for the National Balsa Booth.
-joker
joker24458 is offline Find More Posts by joker24458
Old Feb 25, 2013, 02:40 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
-joker
and there will be 3mm Depron kits, there just won't be 3mm depron ones prebuilt. I'll have the completers available also. It was fun meeting all the guys that stopped by the booth over the weekend
Old Feb 25, 2013, 03:03 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
What's the consensus on a Welders replacement since it's now really hard to find? My wife sent me to Michaels for some E6000. I tried some on a test piece of EPP and it looks fine. A little thicker than epp. I did a search and folks seem to like it, the last post was back in 2010.
thanks,
Rob
robj is offline Find More Posts by robj
Old Feb 25, 2013, 03:09 PM
robj is offline
robj's Avatar
Joined Nov 2008
AND...are they phasing out the old red tube for the new white tube? Welders that is...
ombudsman is offline
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
thanks,
Rob
Though I've only found it in town once, I have no trouble getting it at all - amazon.com. One-click buy and in three or four days I have it.
ombudsman is offline Find More Posts by ombudsman
Old Feb 25, 2013, 03:15 PM
robj is offline
robj's Avatar
Joined Nov 2008
Yeah I saw that there and that's not a bad price, free shipping, I got a 6 pak and noticed I had some Amazon points and I used some. So mostly free.
thanks,
Rob
Old Feb 25, 2013, 03:41 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
thanks,
Rob
UHU is going to be tough also. I have about a case left. Beacon Adhesives has Foam-Tac and I'll be offering that and using it for my builds. I've used it before and it works fine. it was created specifically to address the UHU/Welders users and has a formula that passes the restrictions that are causing Welders and UHU to be unavailable
Old Feb 25, 2013, 03:44 PM
Markran is offline
Find More Posts by Markran
Markran's Avatar
United States, CA, Sacramento
Joined Aug 2011
When I started building out of EPP early last summer I followed the recommendation to use Welders which worked very well. However, in the last couple of months the Welders has started to turn yellow on those seams and get brittle. The yellowing took over six months to manifest and I never left those planes exposed to sunlight except when out flying them.
I've ordered some Foam Tac (despite the higher cost) and am going to try that, unfortunately I won't really know about U/V driven yellowing for at least six months. Foam Tac seems to have slightly changed their formula in the last couple of months. Does anyone have first-hand experience with the previous Foam Tac formula yellowing (or not) over a period of six months or more?
Markran is offline Find More Posts by Markran
Old Feb 25, 2013, 03:46 PM
Jack the R is offline
Find More Posts by Jack the R
Jack the R's Avatar
Joined Aug 2009
How do you keep your foam tac nozzle from getting clogged up?
Jack the R is offline Find More Posts by Jack the R
Old Feb 25, 2013, 04:34 PM
balesse is offline
Find More Posts by balesse
balesse's Avatar
USA, WA, Seattle
Joined Oct 2005
I used E6000 for years because it was easy to find and inexpensive. It is much thicker (which I don't like), does not dry as fast, but does not yellow like Welders.
I'm lucky enough to have found a local source for Welders through one of our small hardware stores (City Peoples Merchantile). They say they order it through Ace, but I've never seen welders at any of our other hardware stores that use Ace.
But now I've found one that I actually like better called Quick Grips, which (like Foam Tac) is also from Beacon. I don't know what success others will have finding it, but in the Seattle area it can be found at TAP Plastics, and according to the Beacon website at Sherwin Williams paint stores. It costs about four times as much (one tube is twice as much as the two pack of welders). So far (been using it for a year or so) it does not yellow like the welders, it is a bit thinner than welders, it seems to dry a little quicker, and I like the tube better than the Foam Tac bottle.
They all seem to be easy to find on line, but it can sure be nice to know a local source, when you just need some right now!
balesse is offline Find More Posts by balesse
Old Feb 25, 2013, 04:38 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
We have been using and selling foam Tac for over 6 months now on EPP as well as depron. I placed a glue hinge in direct sunlight as well as heat ... on the dash of my car ... there was Zero discoloration and no degradation of the glue hinge.
GM
WMParkFlyers.com
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Feb 25, 2013, 04:42 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Yeah, the Beacon guys at WRAM were suggesting Quick Grips also. I have a tube that I got from Michael's craft store a while back but I never opened it to try it since I had a good supply of UHU
Old Feb 25, 2013, 04:57 PM
Bigster is online now
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
I've been using Quick Grips from Wal-Mart. Seems very similar to UHU - I'm down to my last tube of that!
Bigster is online now Find More Posts by Bigster
Old Feb 25, 2013, 05:02 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Michael's at Rt146 and grab one of their 40% off 1 item coupons from their website. Got my Byper!! WRAM Delivery
