Old Jan 19, 2012, 02:44 AM
uptime4downtime is online now
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Changed my mind about 3s 800s. Took out the yakka with the 3s 460/370s and it is nibble indeed. Love it.
uptime4downtime is online now Find More Posts by uptime4downtime
Old Jan 19, 2012, 04:57 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
after flying my first few in the 225g range (bigger motors, ESCs, batteries), these last couple at 180g make lots of difference and the 370mah 3s help there.
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Jan 19, 2012, 05:53 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Originally Posted by MikeMcChiken View Post
I wanted to get some of the new Xacto blades they just came out with but the freebee trial ended already . Nobody I know has gotten theres yet . Some ordered the trial ones months ago . They look cool and have a special coating on them . Suppose to stay sharp longer and be sharper than the regular ones . Hopefully the stores get them soon .
FWIW, I had some extra weight left on an order from HK and bought some of their #11 blades. Don't bother unless you're planning on whittling 2x4s they're thicker, and I think the angle on the edge is different.
Has anyone seen the new Xacto blades yet?
FWIW2: for beveling I use a single edge razor blade. They're cheap and I toss them after the bevels are done.
Azarr
Azarr is offline Find More Posts by Azarr
Old Jan 19, 2012, 06:17 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Azarr
The cheap snap knives at Harbor Freight work well and you can extend them long and have plenty sticking up above the bevel(watch the finger tips holding the ruler). And since you can extend them in single clicks you get a lot of new blade surface while beveling. I find I need to have the #11 blades only partially in the handle to get enough of the point sticking out above and handle clearance below when doing 9mm EPP and then the EPP always hits the same spot on the edge for the entire use, dulling it faster. usually takes me a couple of blades to do a 32" Yak cleanly
Old Jan 19, 2012, 07:45 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Canada, ON, Ayr
Joined Apr 2010
I use 2 types of blades:
Single edge razor blades (commonly found at most hardware stores as paint scraper blades). The large flat sides works well for long straight cuts and bevels.
#11 blades for finer work, curves, etc. You can buy 100 packs for $15 at Tower:
http://www3.towerhobbies.com/cgi-bin...ES++&search=Go
philipa_240sx is offline Find More Posts by philipa_240sx
Old Jan 19, 2012, 10:43 AM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Originally Posted by briskability View Post
So I built a 30in and just wanted to know how much throw I should have on the control surfaces?
Studies have shown that anything over 50 Degrees acts as a air break ... so I would say that would be the max for control ... unless you want to air break the plane in a dive or downlinedownline
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Jan 19, 2012, 10:45 AM
Jenison
Joined Nov 2009
Need an edit button on mobil version of RCG ...
Old Jan 19, 2012, 12:06 PM
3d Kiwi
New Zealand
Joined Dec 2007
Got my differential sorted and it rollers great now. More fun than a barrel of monkeys (or stink bombs when I was a kid)
Wringing out the Leadfeather Yak 55 (5 min 13 sec)
Old Jan 19, 2012, 12:26 PM
MyDigitalParadis is offline
Find More Posts by MyDigitalParadis
Callsign: Jolly Roger
MyDigitalParadis's Avatar
Ridgecrest California
Joined Jun 2006
Nice flying Rick, you are lucky to be able to fly in the afternoon. I'd love to make a flight or two on the way home but that is a no go here it is always windy in the afternoon.
MyDigitalParadis is offline Find More Posts by MyDigitalParadis
Old Jan 19, 2012, 02:03 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
exactly!
leadfeather is offline Find More Posts by leadfeather
Old Jan 19, 2012, 02:18 PM
3d Kiwi
New Zealand
Joined Dec 2007
Haha - yes, afternoon flying - still on holiday, but like you, will soon return to early morning or later on. The fields fill up with park users after work, so I try not to hog the field and get home pretty soon after so as to keep the rc reputation clean
Old Jan 19, 2012, 03:20 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Glad you got it all dialed in. They are a lot of fun once they get set up
Old Jan 19, 2012, 03:55 PM
Joined Jun 2006
We are lucky in that regard. Fields are rarely crowded and the few that are there often sit to watch the show. I could just picture the reaction to a flight of your skill level.
Old Jan 19, 2012, 04:24 PM
3d Kiwi
New Zealand
Joined Dec 2007
When I almost cut my face off that must have been fun to watch! Yes, I find the spectators generally help the flying by keeping you on your toes and trying to give them a fun time. On rare occasions they make your fingers twitch - then it's time to pull out the little yak and it doesn't matter if you bounce it.
Yeah, parkflying is a great thing to be able to do in urban areas. We have enough parks, but the mornings get the dogs and the afternoon the sports guys... I consider this a sport so just try to blend in... not sure how fit I'm getting tho :-)))
Old Jan 20, 2012, 03:16 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Great for throwing it into a nice violent wall as well
3DNater is offline Find More Posts by 3DNater
