Old Mar 15, 2009, 08:26 PM
rcnxs is offline
Find More Posts by rcnxs
Alabaster AL
Joined Aug 2006
Originally Posted by Yaniel
this is my full deflection
this is my linkage setup
and this is how my electronics are laid out
hopefully something there helps because its a shame it doesn't roll quickly. i also have hot glue hinges which i think add a bit to the stiffness of the aileron itself which may also help but requires a servo with enough tq to move them.
I have the Gene Bond Yak and did hotglue hinges it is a dog for roll rate, I am going to cut them free and go with the welders glue hinge. If the surfaces will not drop to full deflection on their own, they are too stiff and will hurt your roll rate.
rcnxs is offline Find More Posts by rcnxs
Old Mar 15, 2009, 08:32 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
is this what you mean!
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Mar 15, 2009, 08:35 PM
Figure.N9ne is offline
Find More Posts by Figure.N9ne
Miami, FL
Joined Mar 2007
no, not that far back
i marked it here on the left wing tip
Figure.N9ne is offline Find More Posts by Figure.N9ne
Old Mar 15, 2009, 08:36 PM
Miami, FL
Joined Mar 2007
thats what i thought to, and plan to do a welders glue hinge on the next one but the servo seems to push this one around just fine
Old Mar 15, 2009, 08:53 PM
rcnxs is offline
Alabaster AL
Joined Aug 2006
You also have to take into effect the air preasure pushing against them called blowback. You can cut them loose and try the welders hinge, probably would hardly know it was done.
Good Luck
RCNXS
Old Mar 15, 2009, 09:00 PM
Miami, FL
Joined Mar 2007
i'll check tomorrow if i can locate some welders glue. only contact cement i have now is incredible goop. that wouldnt work would it?
Old Mar 15, 2009, 09:02 PM
rcnxs is offline
Alabaster AL
Joined Aug 2006
Nope, stick with what is proven, the other would be stiff like the hotglue.
RCNXS
Old Mar 15, 2009, 09:04 PM
Miami, FL
Joined Mar 2007
alright, thanks
Old Mar 15, 2009, 09:12 PM
tallflyer's Avatar
Joined Jul 2002
Ok thats what i thought also I was going to say dude thats like gotta be so tail heavy
Well I'm off to do a little flying!
Old Mar 16, 2009, 12:51 AM
jtaz456 is offline
Find More Posts by jtaz456
Joined Jan 2009
got mine done
well i got mine done and it flys better then i thought it would i am going to go much lighter next time i used to much glue this time .
but this was my first one i ever bulit so it flying at all made me fell good lol
jtaz456 is offline Find More Posts by jtaz456
Old Mar 16, 2009, 01:03 AM
tallflyer's Avatar
Joined Jul 2002
Ok I did a little more testing
My slofly28 and the yak are both 5.2oz on the scale.
And they have the same setup (so I think the issue is that the motor are not the same wind (2 1300 but they perform different) one plane hovers at 1/2 with major pull out the other feels like a brick.
So time to get another motor so see if its the problem.
Stay tuned.
Old Mar 16, 2009, 02:42 AM
rcolle is offline
Find More Posts by rcolle
rcolle's Avatar
SW Las Vegas
Joined Sep 2006
Yak 55sp
SP for super pig. 8.5oz
rcolle is offline Find More Posts by rcolle
Old Mar 16, 2009, 06:19 AM
rossmkly is offline
Find More Posts by rossmkly
rossmkly's Avatar
Joined Sep 2006
Welders Glue
I have seen Welders glue at Walmart as well as Lowes. Note welders just changed the package style ... the old one was red ... the new one is silver with lack lettering ... I love this glue on EPP!
rossmkly is offline Find More Posts by rossmkly
Old Mar 16, 2009, 08:53 PM
EKflyer is offline
Find More Posts by EKflyer
EKflyer's Avatar
Alaska
Joined Feb 2009
Were can I buy EPP foam? Do I have to order it or is it something that can be found pretty easily. I've never seen it anywhere but maybe I am just blind.
EKflyer is offline Find More Posts by EKflyer
Old Mar 16, 2009, 09:09 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Great scheme on that, and my 8.1oz yak flys fine. But yours looks a lot like a Yak 54, not the 55. What is the wingspan? I have a 36" Gene Bond Yak 54 that I really love.
Diggs
Diggs is offline Find More Posts by Diggs
