Old Mar 06, 2009, 12:56 AM
Shinear is offline
Find More Posts by Shinear
Shinear's Avatar
Joined Oct 2008
question.......here goes
I have not seen an answer to this yet...on a sloflyer (superslow 28) type model can I use hot glue to hold the carbon in place????
Shine
Shinear is offline Find More Posts by Shinear
Old Mar 06, 2009, 05:28 AM
dz1sfb is online now
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Shine
Shine,
You can, but this a very heavy option. Could lighten it up if you just tack it every 4" or so. That is assuming you are talking about spars.
There is a big advantage to gluing the entire length of the CF. Besides adding lateral stiffness, fully glued spars contribute to longitudinal stiffness as well. You will not realize this by tack glueing.
Best bet is to get some polyurethane (Gorilla) glue, and use the foaming method mentioned in this thread to get a light fully adhesed carbon to foam joint. Contact cement like Welders glue would be my second choice.
Ken
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Mar 06, 2009, 05:46 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Shine
Here are some videos from my site!
1st one shows how to cut a grove (my method)
How to Dremel a Carbon slot in EPP foam (5 min 6 sec)
2nd one show how I use epoxy to glue in the carbon.
How to epoxy a Carbon wing spar video (6 min 8 sec)
I built the yak55 with all 9mm 1.3# epp foam my total AUW (add up weight is only) 5.4oz 6.5 with battery
If I were to build another one I could do some stuff to save weight but the little planes flys great the way she is!
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Mar 06, 2009, 12:26 PM
moxjett is offline
Find More Posts by moxjett
Pug Pilot
moxjett's Avatar
Wichita, Kansas
Joined Dec 2004
Here's the "head cam" I'm going to try and build for my next flying session.
moxjett is offline Find More Posts by moxjett
Old Mar 06, 2009, 06:11 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Balanced, sleek, light weight, attractive; genius! Just what a cranium Cam should be
leadfeather is online now Find More Posts by leadfeather
Old Mar 06, 2009, 06:23 PM
Shinear is offline
Shinear's Avatar
Joined Oct 2008
just trying to be cheap...all ways of gluing seam to ruin the cf tubes......with my taxes going up and cap n trade in the future new cf may be a stretch...mmm bamboo may be the ticket.......lol
Old Mar 06, 2009, 09:09 PM
Patsy 2 Shoes is offline
Find More Posts by Patsy 2 Shoes
RC Flyer
Patsy 2 Shoes's Avatar
Malverne NY
Joined Jul 2007
Hi Leadfeather
I have some 1.3 EPP in 8 MM and am very tempted to build your yak.If you had to build one now what are the latest changes you would recommend?
Charlie
Patsy 2 Shoes is offline Find More Posts by Patsy 2 Shoes
Old Mar 07, 2009, 09:53 AM
Trouble Maker is offline
Find More Posts by Trouble Maker
Zippy, Strong Like Bull!
Trouble Maker's Avatar
USA, KS, Wichita
Joined Apr 2008
Ok here is a video from the Noggin Cam of the Yak flying. I had many distraction during the fight but it was alot of fun. Make sure you turn your sound up so you can hear and play close attention around the 2:14 second mark. This video would not have been possible with out adreher and pixturethis.
Mark
Noggin Cam Yak55 Flight
Trouble Maker is offline Find More Posts by Trouble Maker
Old Mar 07, 2009, 10:21 AM
Winging it >
Joined May 2006
Originally Posted by Patsy 2 Shoes
Hi Leadfeather
Charlie
Charlie,
There are two versions I think are the best; one indoor, one outdoor/indoor. Both use the same plans; just different foam and some different guts.
Indoor: Target weight 5 oz or less incl battery
1#, 9mm epp (fluffy foam)
3 HXT500 servos
15 gram Hacker motor
6A Turnigy esc
lightweight Rx
8x4.3 GWS prop
2s 360 mAh battery
Outdoor/Indoor: Target weight 5.5 oz or less + battery
1.3#, 9mm epp (standard foam)
HXT900 aileron servo
HXT500 for rudder and elevator
1500 kV BW or equivalent
Supersimple 10A esc
lightweight Rx
8 x 4.3 SF or 8 x 4 DD GWS prop
2s 360 mAh Rhino battery indoor/ outdoor no wind
3s 360 mAh or larger outdoor
Glue and paint can add a lot of weight if you are not careful. It is possible to do very strong glue joints; full length; adding minimal weight by using PU glues such as Gorilla glue.
Old Mar 07, 2009, 10:24 AM
Winging it >
Joined May 2006
I have recycled and reused CF tubing by tearing it out of the foam and carefully scraping off the glue and foam. Takes patience but saves spendolas (money).
Old Mar 07, 2009, 10:25 AM
tallflyer's Avatar
Joined Jul 2002
Troublemaker
Nice video flying indoors must be nice.
Old Mar 07, 2009, 10:28 AM
Winging it >
Joined May 2006
Mark
Good video Mark...too funny!
Old Mar 07, 2009, 10:43 AM
tallflyer's Avatar
Joined Jul 2002
Another tip if you take a heating gun and you run it over the carbon the epoxy can be pulled off pretty easy and the carbon looks like new.
We can rebuild her bigger faster stronger.
And your right you save money
Old Mar 07, 2009, 11:13 AM
Figure.N9ne is offline
Find More Posts by Figure.N9ne
Miami, FL
Joined Mar 2007
i wish i had heard this before! i sit there for hours with a razor blade lol
Figure.N9ne is offline Find More Posts by Figure.N9ne
Old Mar 08, 2009, 05:30 AM
Dewane is offline
Find More Posts by Dewane
Dewane's Avatar
United States, AR, Benton
Joined Dec 2007
Whats the preferred method of cutting out the plans?
A. Leave the front and rear horizontal brace one piece and split the fuse into two pieces.
B. Leave the fuselage one piece and split the the braces.
I plan on a skinny yak version with ply/foam motor mount.
Dewane is offline Find More Posts by Dewane
