Old Jul 06, 2010, 01:17 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Originally Posted by Diggs View Post
What are you guys using for template / Stencil material?
Diggs
Originally Posted by leadfeather View Post
I use poster board.
That's what I use also. I have some laser cut plastic mylar stencils, but they're hard to use on EPP. On Depron I hold them down with a post it glue stick. I've been wanting to try this place, but haven't yet. Not sure how the vinyl would do on EPP.
Also been looking at the Cricut, basically a poor man's plotter. There is some software out there that works around having to use their cartridges and works directly off of your PC.
Azarr
Azarr is offline Find More Posts by Azarr
Old Jul 07, 2010, 02:42 PM
helivsFMX is offline
Find More Posts by helivsFMX
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
I am going to start building one of these tonight. Been flying the shockflyer on clearview LOTS and love it. So here's what I have.
Stack of FFF (blue foam)
Suppomodel B2207/17 motor/ESC http://www.suppomodel.com/motor/B2208.html
HS65 for ailerons, HS55 for rudder and elevator
3S 1000mah lipos
Will have a spektrum rx
Since the motor and batteries are heavy, I was thinking the 36" WS should work? Will that give me enough "floatiness" AKA low wing loading? Or do I need a 42"?
I was thinking that since FFF is so much thinner and lighter than EPP, could I double up on the thickness to make it more sturdy? Use a 3M spray adhesive or something to stack 2 pieces together before cutting out the parts? Or is the weight addition not worth the strength addition? I'll probably crash lots because I haven't flown a plane in a while. I fly helicopters pretty regularily, and I only crash on the sim when I want to (IE start 3d'ing).
Thanks for any input,
James
helivsFMX is offline Find More Posts by helivsFMX
Old Jul 07, 2010, 04:25 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
36" would be a good place to start.
motorhead is offline Find More Posts by motorhead
Old Jul 08, 2010, 10:47 AM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Anybody have any insight into the double thickness FFF? I cut out the template last night and Im ready to cut foam tonight. Just dont know if I should do double thick or stick to single.
Old Jul 08, 2010, 12:47 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
A single layer should work. You could double up around the nose since this is the part that usually gets the most abuse.
Good luck, let us know how your FFF Yak works out.
leadfeather is offline Find More Posts by leadfeather
Old Jul 08, 2010, 02:50 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Just buy some 9MM EPP
flyboy321 is offline Find More Posts by flyboy321
Old Jul 08, 2010, 08:58 PM
deafmusicman is offline
Find More Posts by deafmusicman
Joined Jul 2005
I built a FFF yak it flies well but know where near as good as the epp !!!!
deafmusicman is offline Find More Posts by deafmusicman
Old Jul 08, 2010, 09:15 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Whats the difference? How does the EPP fly much different?
Old Jul 08, 2010, 09:19 PM
nagayama13 is offline
Find More Posts by nagayama13
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
For one, EPP is much more forgiving (when the ground is considered). It might actually be lighter too.......not sure on that one.
nagayama13 is offline Find More Posts by nagayama13
Old Jul 08, 2010, 09:26 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Well yes I understand EPP will crash thousands of times better than FFF... blue foam shatters...exploads... whatever you want to call it. But FFF should be similar in the air isn't it?
Old Jul 09, 2010, 06:51 AM
Winging it >
Joined May 2006
EPP flies better because:
1) the thicker foam wing seems to allow slower flight speeds
2) less crash anxiety allows you to learn faster
3) less rigid airframe can be like adding expo, smooths things out.
Rigid foam flies better because:
1) Stiff airframe has crisper control and more precise handling
2) Stiff airframe will normally fly faster
3) Probably some others if I thought hard enough
Which one is "better overall" is a matter of what you want in a plane.
Old Jul 09, 2010, 10:04 AM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Id love one that I can nose in after a botched hammerhead???
I blew up my corsair that way... I think when I came screaming downwards, I pulled up too hard and the wings couldn't take the G's... then straight into the ground. Toast! That cost me .32 cents! But the time it takes to build is what sucks in a crash. Id rather split it between cost and time...
I figure I'll test out the FFF and see how it does and if I like the feel I'll go to EPP. Id rather have a smaller plane all around than what Im making (the 36" WS) but oh well. I dont think parking lot flying is an option really.
I have one layer of foam cut. I'll cut the other tonight, then glue them together double thick. The thickness of 2 pieces of FFF is exactly the thickness the templates show. That works out nice
Old Jul 09, 2010, 01:00 PM
Geezertom is offline
Find More Posts by Geezertom
USA, MA, Eastham
Joined Jul 2009
MENTOR or CLUB NEEDED FOR GRANDSON IN PITTSBURGH AREA
Hey guys, I have an 11 year old Grandson I have gotten started flying on a HZ Super Cub and lately graduated into a Leadfeather EPPEdge 540. He currently has operating problems with both planes and I am unable to troubleshoot quickly by telephone from 600 miles away. He lives in the Gibsonia/ Mars area near Pittsburgh. Is there a good club or someone interested in mentoring a smart young pilot in that neck of the woods?
Thanks for any leads!
Grandpa (GeezerTom)
Geezertom is offline Find More Posts by Geezertom
Old Jul 09, 2010, 01:11 PM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Mentoring an 11 year boy might open a whole can of worms. Jeez, in the UK parents arn't even allowed to shoot vids of their own kids sports days. Best make sure his parents are on board. Hey, perhaps they might be converted to RC foam heaven!
Head
headlessagain is online now Find More Posts by headlessagain
Old Jul 09, 2010, 01:27 PM
USA, MA, Eastham
Joined Jul 2009
Parents on Board
Mom and Dad are on board and involved, just not able to get technical enuf to lead the charge without help from an experienced RCer.
Thanks for the comment!
Grandpa
