Old Feb 16, 2009, 08:43 PM
rcolle is offline
Find More Posts by rcolle
rcolle's Avatar
SW Las Vegas
Joined Sep 2006
Originally Posted by tallflyer
I just made a new design in google sketch Im going to layout a pdf file soon!
Looks Good So Far. It will be my next build.
rcolle is offline Find More Posts by rcolle
Old Feb 16, 2009, 09:17 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Looks good so far. What size are you thinking of?
leadfeather is online now Find More Posts by leadfeather
Old Feb 16, 2009, 09:49 PM
Jerry Combs is offline
Find More Posts by Jerry Combs
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
Yaniel
I here you my friend I get up at 7am to hit the local parking lot before any wind kicks up! I can also fly at night under the lights with very low wind (but to fly indoors) that would be cool.
If anyone knows of any place to fly indoors in the san Diego Area please let me know!
I wish I could help you find a place to fly indoors Tallflyer. It is a totally different experience than flying outdoors. It isn't just the nice still air, it is how fast the walls and ceiling come up and bite you.
Jerry
Jerry Combs is offline Find More Posts by Jerry Combs
Old Feb 17, 2009, 01:12 AM
mikebergy is offline
Find More Posts by mikebergy
I Love My Ember!
Arroyo Grande, CA
Joined Jun 2008
looks a lot like a 3DFoamy edge 540...
mikebergy is offline Find More Posts by mikebergy
Old Feb 17, 2009, 11:24 PM
Winging it >
Joined May 2006
I flew the Fluffy Yak for the second time tonight. I really like the foam the wifre cut .9lb supplied to me by Motorhead. I think it is a great combination of light yet stiff. It is almost identical inn weight to 6mm 1.3# ep but much, much stiffer.
I will be replacing the HC Hacker clone with an actual Hacker...A10-15s. It should keep me under 5 oz yet provide the power I need to pull out of hovers. I hope to test the new motor on Sunday.
Old Feb 18, 2009, 12:05 AM
Figure.N9ne is offline
Find More Posts by Figure.N9ne
Miami, FL
Joined Mar 2007
i'm placing an order tomorrow for some 9mm 1.3# foam so i can finally build another of the original yaks. i'm pretty interested in building one with the .9# foam though, for the rare calm day or if i ever find an indoor venue.
Figure.N9ne is offline Find More Posts by Figure.N9ne
Old Feb 18, 2009, 01:26 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
I will be cutting a few yaks in the next couple weeks if anyone wants one I will sell the basic blank white 1.3# 9mm foam and carbon and motor mount PM me for more details.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Feb 18, 2009, 08:11 AM
Winging it >
Joined May 2006
I'm planning going to build a standard Yak for outdoor flying. I think I could shave some weight from my original (green Yak in post #1).
With a 3s battery it is surprisingly capable outdoors. With a small 2s, it is still a very respectable indoor flying machine.
Old Feb 18, 2009, 08:27 AM
Court461 is offline
Find More Posts by Court461
Something Witty.
Court461's Avatar
United States, OK, Tulsa
Joined Dec 2007
I just started building this plane last night (thanks for the plans and all the information in this thread).
I noticed from the plans, and the instructions, that it says to build all the horizontal parts first (Wing, elevator, and side fusalage) first and then add the vertical fuse parts. This appears different from the originals built early in this thread. Is this method as strong? Just curious if you lose some rigitidy over having a fuse with a slot for the wing. Note that this is only my second scratch build, so I in no way suggesting anything is wrong, just curious as to the change. Thanks
Court461 is offline Find More Posts by Court461
Old Feb 18, 2009, 08:44 AM
Winging it >
Joined May 2006
It is just as strong either way you build it. It is a little easier to build the horizontal stuff first and then add the fuse.
Old Feb 18, 2009, 09:30 AM
tallflyer's Avatar
Joined Jul 2002
Outdoors
I think that if you build the plane using 9mm for the wing,front end piece and side braces
and 6 mm for the fuselage/elevator/ailerons
this would be perfect for the outdoor version
bluewonders motor 1300kv a gws 8040hd prop a 10 amp esc 3 cell 300mah
3 towerpro 5 gram servos
should come in around 5-6 oz would be perfect.
Old Feb 18, 2009, 09:57 AM
mattk0 is offline
Find More Posts by mattk0
mattk0's Avatar
United States, MN, Apple Valley
Joined Jan 2004
Tallflyer, what's your price on these?
Also, can you make a Yak with one full 18x36 1.3 9mm sheet or do you need more? Thanks,
mattk0 is offline Find More Posts by mattk0
Old Feb 18, 2009, 11:02 AM
Winging it >
Joined May 2006
Outdoors
Tall,
What you've described for the airframe is what we call the "skinny" Yak build. At full speed it will flutter somewhat. The standard airframe; all 1.3#, 9mm epp yak doesn't do this, so of course it is the build I plan on doing for my outdoor Yak.
As I have stated before, I think it is a good idea to build the plane so that the battery is at the cg. For outdoors; on those (rare) no wind days; you can fly a small 2s battery. On windier days you can use a larger 3s battery for the extra speed and momentum.
Old Feb 18, 2009, 11:44 AM
tallflyer's Avatar
Joined Jul 2002
I would then say build the original just change the wings to the new version all 1.3# 9mm epp foam
outdoors the 2 setups would favor
1300kv outrunner (0-5 mph wind) how I fly 2 cell 7.4v 400mah with a gws ep9050 prop
or I kick it up a notch prop down to a ep8040 and put on a 3 cell 11.1 v 300 mah
I have not tried a larger pack like a 600 mah 11.1 yet wind has been my friend the last couple of weekends!
Old Feb 18, 2009, 12:10 PM
Miami, FL
Joined Mar 2007
my outdoor setup which is great in even a small ~7mph breeze is:
all 9mm 1.3#
hxt500's on the tail
eflite s75 on ailerons
1300 kv blue wonder
9050 gws prop
3s450mah 25c 2dogrc lipo (44g)
built with hot glue
auw is ~190g seems like a brick compared to your indoor ones but its great for outdoor use and hovers at half throttle. try it out, you wont be disappointed.
