Old Dec 07, 2008, 12:12 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Originally Posted by goldguy
Thank you, thank you, thank you.........exactly what I'm looking for
Gold, you're welcome.
It was exactly what I wanted too but didn't exist.
leadfeather is online now Find More Posts by leadfeather
Old Dec 07, 2008, 01:01 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
A couple of questions
- What size is the carbon for the wing and stab spar ?
-What is the span?
When I print out the tiled pdf I get ~32.5", but the 28" dimension on the wing comes out more like 26.7". The single PDF also measures ~32.5"
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 07, 2008, 01:45 PM
Winging it >
Joined May 2006
-What is the span?
Pat MacKenzie
Pat, The wing spar is 1/8" carbon tube. The stab spar is 1/16"carbon rod. The span is 32.5". I'll have to double check the 28/26.7 issue. I built mine to the plans and seems OK.
I also used 1/16" carbon rod for the control rods
Dan
Old Dec 07, 2008, 02:06 PM
pmackenzie's Avatar
Joined Dec 2002
Thanks.
The plans and dimension are right.
I only taped together 1/2 the wing drawing, and assumed that the dimension was centered
If I tape all of it together it is 28"
Pat MacKenzie
Old Dec 07, 2008, 02:29 PM
fxstbi is offline
Find More Posts by fxstbi
United States, IL, Quincy
Joined Dec 2001
Thanks leadfeather, I'll post a pic when I get it finished!
fxstbi is offline Find More Posts by fxstbi
Old Dec 07, 2008, 03:32 PM
Twisted Realm is online now
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
I like it, looks great nice job! Humm I might just try it.
Twisted Realm is online now Find More Posts by Twisted Realm
Site Sponsor
Old Dec 07, 2008, 05:21 PM
Winging it >
Joined May 2006
CG stuff
As flown, the cg was about 3" from the leading edge of he wing. It was a little tail heavy so I think a better position is going to be about 2 3/4".
To get the battery a little closer to the cg I would move the 5 gram tail servos up a little. As shown in the photo they are about 8" back from the leading edge. My best guess is that if they were mounted at 7" from the leading edge the battery would be very close to the cg.
Old Dec 07, 2008, 06:48 PM
Trouble Maker is offline
Find More Posts by Trouble Maker
Zippy, Strong Like Bull!
Trouble Maker's Avatar
USA, KS, Wichita
Joined Apr 2008
Dan's EPP Yak55
Here are a couple of image I took at the fly-in yesterday of the man with the plan EPP Yak 55 that is.
Dan thanks for the hardwork and making the plans and information available so others can enjoy!
Mark
Trouble Maker is offline Find More Posts by Trouble Maker
Old Dec 07, 2008, 07:57 PM
United States, FL
Joined Aug 2008
Hey leadfeather, I'm having a problem printing the pdf's out, when I print I slecet fit to page and I come up with 14" instead of 15" with I put it together? Any ideas? Also I also love hobbycity for parts they got the best pricing IMO.
Site Sponsor
Old Dec 07, 2008, 08:01 PM
pmackenzie's Avatar
Joined Dec 2002
Select "none" for page scaling.
edit - did the Yak have a "close encounter" with another plane?
Those look like prop marks on the left wing.
Pat MacKenzie
Old Dec 07, 2008, 08:16 PM
Winging it >
Joined May 2006
Pat MacKenzie
Good eyes Pat. The Yak has already had two mid airs on two separate days...I think with the same other airplane ha!
Gotta love that epp, takes a beating and just keeps on flying.
Old Dec 07, 2008, 08:21 PM
United States, FL
Joined Aug 2008
Pat MacKenzie
Thats whats weird I do and it cuts the left side boards off, I put it together is you can see it comes up a little bit smaller?? the 15 inch comes out 14?? I don't know if it will make a difference, I hate starting a project off wrong..
Site Sponsor
Old Dec 07, 2008, 08:36 PM
Winging it >
Joined May 2006
I don't know that much about printing pdf's so I hope someone else can give you some help and direction.
I would recommend getting the printing sorted out first. I think the rest of the project will go better for you with a good set of plans/templates.
Dan
Old Dec 07, 2008, 08:38 PM
United States, FL
Joined Aug 2008
Dan
LOL so true, moving on.. I love the setup it looks like a winner. I'm printing now.
Site Sponsor
Old Dec 08, 2008, 05:55 AM
Winging it >
Joined May 2006
More data
My Yak55's flying weight is 190 grams. The main wing has an area of about 240 sq in. A few taps on my calculator gives me a number of 4.014 oz/sqft.
I would love to be able to shave off 30 grams or more without sacrificing durability, airframe stiffness and simplicity.
