Old Feb 28, 2003, 02:06 PM
compuatic is online now
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Would anyone be interested in a cheaper alternative to UBEC ?
I am in the process of designing my own BEC Circuit. Specs will be the following
4.5V-40V input voltage
5V regulated out independant of Vin or load current until battery drops below 4.5V, then output voltage is directly wired to battery.
4 AMP continous current output independant of Vin
design is pretty much complete and dimensions will be smaller than your typical 40 AMP ESC. once i have it made i will send out a couple units for beta testing to some of the senior members on the board so that they can report back. if succesfull, price will be about $20 a pop. does this interest anyone ?
compuatic is online now Find More Posts by compuatic
Old Feb 28, 2003, 04:13 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
With the wide use of high-powered digital servos do you think 4 amps is enough? I would like to see 10A + to be on the safe side.
Also I can see that 10 series LiPo batteries (10s?p) are going to me used on some helicopters. That will give a fully charged voltage of close to your limit. What is your safety margin on the voltage?
RC Man is offline Find More Posts by RC Man
Old Feb 28, 2003, 05:03 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Most of the digital servos use less than an amp. Probably something like 600 ma peak.
10 amps at 5 volts is way overkill. That's enough power to run 16 digital servos simultaneously. It's 50 watts.
To put this into perspective, a hovering Piccolo uses about 25 watts (8v @ 3 amps). So you're basically describing a BEC that has the power output of two Piccolos hovering simultaneously.
Toshi
TMorita is offline Find More Posts by TMorita
Old Feb 28, 2003, 05:31 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I don't see anything wrong with 4amps, the UBec is 3-5amps.
But what about the size? Sure in a larger plane the oz makes no big diff.
With the lithiums coming up an airborn pack is gonna get really small and light. If a BEC is bigger and heavier than a battery pack, the only plus is not charging it. But with lithiums we get such high capacity, that will be a small issue too.
How about one the size of a GWS 4 channels RX?
Fred Bronk is offline Find More Posts by Fred Bronk
For Sale would anyone be interested in a trex? prodigy Aircraft - Electric - Helis (FS/W) 0 Mar 15, 2006 08:58 AM
Discussion Would anyone be interested in buying my website? gbagley GWS (Grand Wing Servo) 0 Dec 31, 2005 10:12 PM
Would anyone be interested in a short form kit LiPoly charger ? mwilhelm100 Batteries and Chargers 18 Nov 08, 2003 03:50 AM
would anyone be interested in high-rate NiMH button cell? GKP27 Batteries and Chargers 0 Jun 21, 2003 01:17 PM
Interested in a cheaper alternative to UBEC ? compuatic Sport Planes 11 Mar 03, 2003 01:01 PM
