Old Dec 04, 2008, 01:00 AM
heliaddict22 is offline
Find More Posts by heliaddict22
E-Flite Hawker Sea Fury DX6i retract help! I NEED! haha
I have the E-Flite Hawker Sea Fury and i want to set up the retracts on the DX6i. how do i do this?
heliaddict22 is offline Find More Posts by heliaddict22
Old Dec 04, 2008, 02:15 AM
gp125racer is offline
Find More Posts by gp125racer
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
Option #1:
Run them on a Y cable and hook them up to the 'gear' port on your rx
OPTION #2:
For more granular control, you can plug one servo into 'gear' port, and the other into 'aux' channel. Then in your programming, setup a custom mix for gear -> flap (100% up, 100% down. Move the switch to get both directions). If you do it this way, you'll want to make sure your flap settings are set to 0% on the flap screen. This way your aileron in the aux port will get full travel.
Hope that helps!
Don
gp125racer is offline Find More Posts by gp125racer
Latest blog entry: D100
Old Dec 04, 2008, 07:03 PM
thanks!
Old Jan 08, 2009, 08:36 AM
franktrew is offline
Find More Posts by franktrew
www.foambusters.org
Nashville, TN
Joined Mar 2008
Originally Posted by gp125racer
Option #1:
OPTION #2:
Hope that helps!
Don
When I tried the y harness on mine, I could not get the gear to sync...one went up, one went down. Any idea how to change this? My LHS did not know, told me I had to put one on one channel, one on the other, and use BOTH switches to gear up or down...NOT what I want to do.
franktrew is offline Find More Posts by franktrew
Old Jan 08, 2009, 08:46 AM
simon737 is offline
Find More Posts by simon737
Triple boxed goodness!
simon737's Avatar
United Kingdom, Doncaster
Joined Sep 2008
You need to buy a reversing y harness, it'll reverse one of the servos.
simon737 is offline Find More Posts by simon737
Old Jan 08, 2009, 10:27 PM
ekk202 is offline
Find More Posts by ekk202
Joined Dec 2008
E-Flite Hawker Sea Fury maunal suggests EXRA320 (Y-Harness 6"/Reverser Standard by Expert Electronics) I'm having the same issue.
Question: Using a Dx6i, is it not possible to mix both gears and ailerons (2 servo's each)? Doesn't see, to be enough channels for both so I'm assuming at least one y harness is a must. If so, any thoughts as to which to harness? (i.e. reverse y harness for gear vs. y harness for aileron)
Thanks!
ekk202 is offline Find More Posts by ekk202
Old Jan 08, 2009, 11:13 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I run a Y harness on ailerons, they are too near to the tips to be of any real use as flaperons anyway, and having to separate channels mixed to gear is a big benefit in setting up.
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 09, 2009, 03:24 AM
simon737 is offline
simon737's Avatar
Joined Sep 2008
I bought a reversing harness for the gear and had a standard y for the ailerons, but my didn't work properly so ended up having one wheel plugged into the gear slot and the other in the aux slot, so each wheel is on a seperate switch. I prefer it that way.
Old Jan 09, 2009, 03:07 PM
ekk202 is offline
Joined Dec 2008
thanks, played around with mixing the 2 gear servos and now understand why all recommend separate channels for gears. does seem like there's much more adj flexibility than if went with reverse y-harness. I was looking forward to messing around with rx differential settings on dual ailerons, tho, from the looks of it, it wouldn't have made much difference...
would be fantastic if could control the rate of movement through rx... slow retract would look real/nice!
Old Jan 09, 2009, 03:14 PM
Auckland NZ
Joined Aug 2007
Using programmable servos you can slow them down if you want - Hyperion DS09AMD's would be perfect fit too.
Or you could also do it using 2 "servo-slows"
Old Jan 09, 2009, 04:23 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
AS mentioned, a servo slow unit thing works for this or higher end radios let you program in servo speed directly in the computer radio settings. The JR9303 lets you do both speed from 0 to 15 sec.s as well as a delay up to 2 secs.
kahloq is offline Find More Posts by kahloq
Old Jan 09, 2009, 07:53 PM
rjapodaca is offline
Find More Posts by rjapodaca
rjapodaca's Avatar
Ventura, CA
Joined Feb 2008
I would recommend using the gear and auxiliary channels and mixing them. I have a DX6 and it took about 30 mins to figure it out. It was worth it, you can set individual end points when you use two channels and mix them. Also consider adding an isolated BEC you are running 6 servos.
Here are my birds:
http://www.rcgroups.com/forums/showthread.php?t=917247
Good luck.
-RjA
rjapodaca is offline Find More Posts by rjapodaca
Old Jan 10, 2009, 05:40 AM
simon737 is offline
simon737's Avatar
Joined Sep 2008
RjA,
Do you mind posting the setup you've got on your DX6i for the mixes? I was going to use my mixing for aileron+rudder as i've got my landing gear on independant switches.
Old Jan 17, 2009, 09:51 AM
ekk202 is offline
Joined Dec 2008
I'm using a Dx6i with Hitec 65mg servos. I'm sure settings will vary on different equipment and other variables but the following settings seem to work perfectly for me:
Travel adj: Gear 125% (up), 88% (down) / Flap 125%
Sub trim: Gear 0 / Flap (up) 55
Flaps: 88 (down) for both normal and landing
Mix 1: Gear-Flap Rate +125%
Should also note that I am using the holes closest to the pivot point on the servo horns. So movement needs to be adusted way up for full lock.
Yippee! New E-Flite Hawker Sea Fury Bajora Electric Warbirds 3107 Nov 01, 2014 05:08 PM
Found NIB E-Flite Hawker Sea Fury SammyB Aircraft - Electric - Airplanes (FS/W) 2 Dec 04, 2008 03:01 PM
Sold E-Flite Hawker Sea Fury MERLIN V16 Aircraft - Electric - Airplanes (FS/W) 11 Aug 25, 2008 04:14 PM
