Old Dec 03, 2008, 06:53 AM
frac is offline
Find More Posts by frac
anarchist
frac's Avatar
Inexpensive 2.4ghz programmable radio system now with Rx's available separately
see my post here:
http://www.rcgroups.com/forums/showp...&postcount=212
complete radio system $42.49US
rx and satellite alone $16.52US
you program this radio using your windows PC or notebook...bind as many rx to the tx as you want. unlike regular computer tx's you can store and load an infinite number of heli or plane setups
screen shots of the programming utility showing what you can program
here:
http://www.rcgroups.com/forums/showp...9&postcount=16
radio manual here: http://www.helipro-rc.com/download/RADIO%20MANUAL.pdf
frac
frac is offline Find More Posts by frac
Old Dec 03, 2008, 07:05 AM
walikard is online now
Find More Posts by walikard
walikard's Avatar
Malaysia
Joined Jun 2007
frac, the link lead to an error page, 404.
walikard is online now Find More Posts by walikard
Old Dec 03, 2008, 07:19 AM
frac is offline
anarchist
frac's Avatar
fixed
frac
Old Dec 03, 2008, 07:29 AM
Giovanni Day is offline
Find More Posts by Giovanni Day
Gettin back into it!!
Giovanni Day's Avatar
KY
Joined Apr 2002
very interesting. Do you have one?
Giovanni Day is offline Find More Posts by Giovanni Day
Old Dec 03, 2008, 07:34 AM
frac is offline
anarchist
frac's Avatar
i have 3 radio systems
frac
Old Dec 03, 2008, 07:39 AM
KY
Joined Apr 2002
Three of these? How many point are on the throttle and pitch curves for programming in heli mode?
Old Dec 03, 2008, 07:46 AM
frac is offline
anarchist
frac's Avatar
five. I added a link in first message to screen shots of the programming utility see above
yes, three!! and i just ordered 3 more receivers.....$5.60 US postage to NJ in the US
frac
Old Dec 03, 2008, 08:16 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
I don't suppose you could bind one of these receivers to a DSM2 (Spektrum) TX, could you? That would cut out the single most expensive component to a new heli for those of us who missed this radio deal and bought a Spektrum
murdnunoc is offline Find More Posts by murdnunoc
Old Dec 03, 2008, 08:25 AM
frac is offline
anarchist
frac's Avatar
i don't know if they are compatible....maybe probably not.
yeah i've seen lots of ppl bitching about the Spek rx pricing.
enter the competition...
let's see what effect this has
the real point is, now you don't have to bleed to get your
piece o crap micro/mini trimmed and flying right.
frac
Old Dec 03, 2008, 08:35 AM
KY
Joined Apr 2002
what is the size and wt of the receiver. I must have missed it somewhere.
Old Dec 03, 2008, 08:39 AM
frac is offline
anarchist
frac's Avatar
dunno how you did that G it's right on the rx page and here again:
Specification:
Receiver: 2.4GHz
Operating Voltage Range : 4.8-6v
Operating Current : 30mA
Resolution : 10bit
Latency : 22ms
Net Weight : 12g
Packing Weight : 36g
hm guess the size wasn't there so i measured it:
lenth x width x ht
rx: 1 3/4" x 7/8" x 3/8" plug area is 1/2" high
satellite: 1" x 11/16" x 1/4"
if the cases are taken off and it is shrink wrapped it can be much thinner...except for the plug area
frac
Old Dec 03, 2008, 08:52 AM
elan is offline
Find More Posts by elan
elan's Avatar
VT
Joined Feb 2006
frac, what is the unit (small box) that pugs into the rx in the pic at the link?
elan is offline Find More Posts by elan
Old Dec 03, 2008, 08:57 AM
frac is offline
anarchist
frac's Avatar
satellite. secondary receiver that assists main rx....like almost all 2.4ghz systems have. you orient then at right angles to each other and it improves reception quality under any orientation
at http://www.hooked-on-rc-airplanes.co...pectrum.html#4
where u will find more info about spread spectrum radios.....
"Why Two Receivers?
Because the wavelength of the 2.4 GHz frequency is so small it can't go around objects very well. The 2.4 GHz signal can be easily blocked by metal objects on the airplane such as the engine or landing gear. A second receiver is added to the system so that at least one of the receivers will have a clear unblocked signal from the transmitter."
frac
Old Dec 03, 2008, 09:02 AM
elan is offline
elan's Avatar
VT
Joined Feb 2006
Thanks for the explanation. Does the 12gr rx listed weight include the weight of the satellite? Hey, thanks for the interesting post...
Old Dec 03, 2008, 09:03 AM
treflip is offline
Find More Posts by treflip
Joined Nov 2008
Could this help the Walkera 4 3 fly better. Better thank the original tx?
treflip is offline Find More Posts by treflip
Sold New Spektrum DX6 2.4GHz DSM Radio System philipnow Aircraft - General - Radio Equipment (FS/W) 7 Jan 27, 2008 01:52 AM
For Sale futaba 6ex 2.4ghz like new in box with rx for 170.00 shipped mrctattoo Aircraft - General - Radio Equipment (FS/W) 1 May 31, 2007 01:04 AM
Discussion 2.4ghz spektrum radio system richard trebel Radios 12 Mar 19, 2006 02:25 AM
FS- (2) Plantraco DSP4-SC Digital Signal Processing Rx's with built in 10A ESC's-NIB Etonic Aircraft - Electric - Airplanes (FS/W) 4 Feb 12, 2004 07:15 AM
FS- (2) Plantraco DSP4-SC Digital Signal Processing Rx's with built in 10A ESC's Etonic Aircraft - Electric - Airplanes (FS/W) 3 Jan 18, 2004 08:12 PM
