Lester, Al
Joined Mar 2005
Peter Rakes Albatross D II
This is the second thread on this design. The prototype build which I am using for reference is located at:
http://www.rcgroups.com/forums/showthread.php?t=764611 Having built Gee Bee's till I reach burn out, I decided to look around at other peoples work. I have no experiance with biplanes so I decided for this years projects I would purchase Pat Trittle's Curtiss Jenny and Peter Rake's D II My problem with my own work is that it is dated to older gas designs that come out heavy. I am looking to learn from Pat and Peter the fine art of building lighter. Originally I was going to purchase the Curtiss Jenny first but having seen Pat Lynch's article in Flying Scale Models complete with sheet one of the plans I made the move to buy the short kit that night. The Curtiss will get ordered as soon as the wife lets me have control of my check after her Christmas Shopping. One thing I do have coming for Christmas is a balsa building board from Hobby Lobby located in Tennessee. This will hold me up on the wings and fuselage until I can get it away from the wife. She seems to think I should put it under the tree till Christmas day. May have to slip a like size board into the package to open in front of her. As I am waiting to start I have cleaned of a bench and pulled out supplies to get ready. I talked to Pat about adding to his thread but agree his is pretty long. He has recommended linking to his and I will have to work out how to do that. Tonight I built up the tail skid assembly to test the stain I purchased from Proctor over 5 years ago. It is unique in that it is lacquer based and dries almost instantly. The liquid evaperates leaving the stain with in minutes. The colors are cherry and oak. The do not interfere with any glue I have used. I tried both on a piece of dark 1/64 Plywood and on the built up tailskid. |
Australia, NSW, Bungendore
Joined Jan 2005
Me-thinks you had better do some sneaky swapping under the Christmas tree - let's get our priorities sorted
Either of those stains would do depending on the original chosen. There is some discussion on the darkness or otherwise of the DII colour as old photos are notoriously unreliable guides. Nice to see the article in your photo - I haven't seen it yet Are you going to use ply or balsa skinning? Here is my thread: http://www.rcgroups.com/forums/showt...11#post8453007 Good luck with it Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
Pipescs - One of my often-used charts stuck to a cupboard is a Wire Number/SWG/AWG chart in metric and 'Imperial' sizes. Why a different standard evolved beats me!
For the foam tyres, I just slice the cord reasonably squarely with a sharp blade (doesn't have to be perfect) at a length a little shorter than needed to go around the finished wheel. A small spot of med. CA in the middle of one end and hold the two ends together on a flat surface to align them then lightly sand off the join. To fasten to the wheel, make sure the tyre is centred and with no twists (Use a mold line on the tyre as a guide) and a few drops of thin CA will run around the joint- on the inside as well. Best done after the wheels have been sealed and painted. I agree about wooden wheels and wet grass - my DII has had the wheels repaired a couple of times after getting soggy! One wheel even fell in half and I didn't notice until later I admit I also use a lathe but when making a prototype, I dont usually mention it - might make some think it was a requirement Since the wheels are in front of the CG, their weight shouldn't be a big worry but still be mindful of overall weight. Cheers Pat |
| Thread Tools | |
| Peter Rakes "Sopwith Tri-Plane" | Robert Hoffman | Scale Electric Planes | 465 | Apr 01, 2005 07:03 PM |
| Peter Rakes' B.A.T. Baboon | BennyLaird | Scale Electric Planes | 7 | Apr 01, 2003 11:22 PM |
| Peter Rakes SE5A design | Philip Thulin | Scale Electric Planes | 2 | Mar 07, 2003 10:55 AM |
| Albatross D.V | mudfarmer_mike | Parkflyers | 14 | Jan 10, 2002 08:28 AM |
| Albatross D.V. | UTAH E-FLYER | Foamies (Kits) | 28 | Nov 06, 2001 09:48 PM |
