Old Nov 30, 2008, 02:04 PM
interplanet is offline
Find More Posts by interplanet
interplanet's Avatar
Sheboygan Falls, WI
Joined Nov 2006
sky surfer powered parachute $29.95 w/ Free shipping
http://www.etoys.com/genProduct.html...YCa65C9B02E954
interplanet is offline Find More Posts by interplanet
Old Nov 30, 2008, 02:45 PM
Sheboygan Falls, WI
Joined Nov 2006
I have been looking for a cheap and easy night flyer. Should be easy do mod it with lights like below. I ordered 2, one for me and one for my buddy.
rc paraglider night flying (3 min 52 sec)
Old Nov 30, 2008, 03:24 PM
aviator24 is offline
Find More Posts by aviator24
Flint, Michigan
Joined Aug 2008
Does it have a light on it or what??
aviator24 is offline Find More Posts by aviator24
Old Nov 30, 2008, 03:25 PM
Sheboygan Falls, WI
Joined Nov 2006
No, but its easy enough to put one on at the price
Old Nov 30, 2008, 03:39 PM
Flint, Michigan
Joined Aug 2008
I have read all the reviews. More bad ones than good. I really want one of these but the negative reviews are making me nervous...
Old Nov 30, 2008, 07:44 PM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
I had one of these it flew quite well once you get the hang of it. I swapped for a 2S lipo instead of the heavy nicad pack and if flew much longer and was lighter as well. For $30 it is a fun flying machine. I just bought one thanks for the link!
Don
The Don is offline Find More Posts by The Don
Old Nov 30, 2008, 08:11 PM
Flint, Michigan
Joined Aug 2008
I could not resist! Free shipping and less than 30 bucks, very cheap!
Rode in a real one, what a blast...
Old Nov 30, 2008, 09:18 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I remember that when I had mine launches were at full power. Then backed off to about 1/2-2/3 throttle or so once airborne. Since thrust controls climb it is best to add or remove power slowly as if you go too quick the gondola starts to swing back and forth. Once you get it trimmed out though it looks really cool! The worst part of the kit is the parafoil, it starts to come apart from assembly and disassembly at the flying site.
Don
Old Nov 30, 2008, 09:31 PM
osprey is offline
Find More Posts by osprey
United States, MI, Alpena
Joined May 2003
what is the shoot made of cloth paper ?
osprey is offline Find More Posts by osprey
Old Nov 30, 2008, 10:13 PM
bondohead is offline
Find More Posts by bondohead
If it flies, its cool
bondohead's Avatar
Atlanta
Joined Apr 2007
does it steer from a servo moving and pulling on the lines going to the back corners of the canopy?
bondohead is offline Find More Posts by bondohead
Old Nov 30, 2008, 10:30 PM
Sheboygan Falls, WI
Joined Nov 2006
I think so, wonder if it could be made 4 channel? I guess we will see.
Old Nov 30, 2008, 10:38 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
It has only two controls. Throttle via the ESC, and a left and right servo. The servo has a long arm on it that the chute lines connect to. So when you move right, the right lines are pulled down and the left ones go up. Works very well. The chute is a thin plastic material like a grocery store bag. The ribs in the foil are from a flexible foam material and the foil is glued to the tops of the ribs. This is what usually came off after a while and happens from installing the spar. There is a long "spar' you insert just behind the leading edge to hold the shape.
Don
Old Dec 01, 2008, 01:03 PM
Jim Petro is offline
Find More Posts by Jim Petro
Gary, IN, USA
Joined Jul 1999
I replaced the 2 piece plastic rod used to keep the leading edge of the parafoil spread with a 1 piece fiberglass rod. Also wanted a better radio so I swapped the receiver with a Spread Spektrum. Yes, a lipo battery improves duration, but I have gotten caught in thermals that you have to really work your way out or kiss it out-of-sight gone!
Mine is with several breaks in the body now because it is styrene plastic which becomes brittle at 40 deg. F.
Some small novelty LEDs are easily attached for the calm night flying. Land and take-off from a lit area so you can judge the ground.
A new realm of flying that I encourage you to try.
Jim Petro is offline Find More Posts by Jim Petro
Old Dec 01, 2008, 01:33 PM
staggerwing is offline
Find More Posts by staggerwing
In NY's beautifull hills
staggerwing's Avatar
Binghamton Broome Cty, New York, United States
Joined Jun 2004
I was thinking of one for my grandson but the reviews turned off my thoughts
staggerwing is offline Find More Posts by staggerwing
Old Dec 03, 2008, 04:09 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Mine arrived today. Looks like they have upgraded the canopy to a better grade plastic material and it is silver.
Don
Discussion Best Price on GWS E-starter $29.39 + FREE shipping..UPDATE! mtdoramike Hot Online Deals 0 Feb 14, 2008 07:57 AM
Cool StevensAero--Free shipping Jan 25-29, 07 FirstShirt Parkflyers 0 Jan 25, 2007 05:14 AM
sky scooter free shipping chris-miranda Aircraft - Electric - Airplanes (FS/W) 5 Nov 04, 2003 03:58 PM
FS: Sky Scooter Battery, 7 cell, 8.4v, 600 mah free shipping! Nik-rc Aircraft - Electric - Airplanes (FS/W) 0 Mar 21, 2003 09:06 PM
I found Sky Scooter Gearboxes & Props with Free Shipping! mrebman Foamies (Kits) 2 Nov 03, 2001 03:22 PM
