Old Feb 27, 2003, 01:17 PM
Osiris is offline
Find More Posts by Osiris
Joined Oct 2002
GWS P-51 maiden
I'll hopefully be flying this weekend, depending on the weather
Does anyone have any tips or suggestions they can share?
Osiris is offline Find More Posts by Osiris
Old Feb 27, 2003, 01:42 PM
pc_pilot is offline
Find More Posts by pc_pilot
USA, NY, Yonkers
Joined Aug 2002
make sure you airplane is balanced. CG should be between 1/2 inch and 3/4 inch in front of the bamboo spar. Keep the control throws (especially the elevator) at about 6mm for the first few flights, until you get used to it. It is a tricky airplane at first but once you get used to it you will be fine.
Do not turn until you are abut 20ft high and keep the power up in the turns.
Hope that helps.
pc_pilot is offline Find More Posts by pc_pilot
Old Feb 27, 2003, 02:00 PM
fly4fun is offline
Find More Posts by fly4fun
Joined Jun 2001
Keep your speed up on landings. Its not a floater like a trainer. Low power it sinks pretty fast. During your turns be sure to use up elevator through out the turn or you will lose altitude. Do figure 8's and 360 turns to get use to it. After that try some mild aerobatics. It doesn't loop to well. Other than that its a fun flying airplane.
David
fly4fun is offline Find More Posts by fly4fun
Reply With Quote  (Disabled)
Gws p-51 Maiden FASTALJR Parkflyers 5 Apr 11, 2004 10:35 PM
GWS P-51 Maiden Flight/Report Wingbreaker GWS (Grand Wing Servo) 4 Nov 22, 2003 01:20 PM
Flying GWS P-51 maiden tomorrow. First aileron plane and advice needed Subysouth Parkflyers 27 Apr 06, 2003 08:03 AM
Flawless GWS P-51 maiden :-) E-Pylet Parkflyers 9 Feb 03, 2003 02:54 PM
MY GWS P-51 Maiden Report... Aldur Parkflyers 14 Jan 07, 2003 10:39 AM
