Old Dec 03, 2008, 08:54 PM
nikg is offline
Find More Posts by nikg
Keep the ideas for stiffening coming. Nice to have many alternatives. Provides ways for us cheapos to build good planes. Also gives more flexibility to anyone looking to revise designs or tinker with a new design.
Sounds more genious than idiot to me!!
nikg is offline Find More Posts by nikg
Old Dec 04, 2008, 02:39 AM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
This had been repeated here in the forms many, many times, but here it is again........the number one most important aspect of building for success is building light, not strong. There's a very long list of the benfits of light and a very short list of the benifits of heavy. Every extra gram counts, as it only takes 28 to make an ounce, saving an ounce is like adding 1.5 volts to your battery pack in performance, plus, less crash damage.
Concentrate more on what it takes to make it light, than what it takes to make is strong.
goldguy is online now Find More Posts by goldguy
Old Dec 04, 2008, 10:40 AM
MYHELIGUY is offline
Find More Posts by MYHELIGUY
BUILDIN-FLYIN-CRASHIN-FUN
Michigan
Joined Feb 2008
goldguy is right . when i do need strength,i use cling wrap with glue,if done correctly,its lighter than packaging tape.
MYHELIGUY is offline Find More Posts by MYHELIGUY
Old Dec 04, 2008, 11:35 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Using foam all by itself , form it into a tube or a triangular cross section , it does not need any other strengthening .
I also have a Clark Y section wing made of foam it has stood up to many crashes and tree landings , now in it's seccond plane ( hodge podge )
lake flyer is offline Find More Posts by lake flyer
Old Dec 04, 2008, 12:54 PM
windbender is offline
Find More Posts by windbender
Quebec, Canada
Joined Aug 2006
For planes with complex shapes, i like silkspan and polycrylic (Minwax). Upside - light and strong; downside - takes a while to dry and if you apply tape(as on ailerons) and the poly is not completely dry, your tape slooowly unsticks.
Wb
windbender is offline Find More Posts by windbender
Old Dec 04, 2008, 01:03 PM
flyin' fool
goldguy's Avatar
Joined Jul 2003
If you have looked at any of our indoor flying videos over in the NutBall thread, you'll see how well light flies and survives with minimal bracing. Light for indoor (or outdoors) means slow flight capabilities and instant reaction to control input, both important for flying indoors. Bash the hardwood floor motor first, centre the prop back on the wobbly and keep right on going. If flying outdoor, it's just a matter of cleaning the dirt out of the motor and your off again. That's why I remove the 'e' clips on the rear on all my outrunners and pack 'Q'Tips.
Think light, build light and you will be rewarded by the foam gods......
Old Dec 04, 2008, 01:18 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Another way to strengthen an EPP fuselage in with angle iron depron, angle depron, depron on an angle, bent depron, one of those. A piece about 2 1/2 in. wide and clamped down the centre between two yardsticks, metersticks, milesticks Using a heatgun and putting pressure on the edge of your workbench, you end up with something like below.I wear a pair of welding gloves to protect my delicate pinkys I trim it so it's wider at the front and tapers narrower at the back. I glue it on, then run a strip of hockey tape down the surface. Makes for a very rigid fuse. Motor mounts I make from kitchen cutting board.
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 04, 2008, 01:42 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Just to add to what Frank says, This Catsass weighs 10 oz. with batt. 30 in. W.S. 540 sq in. With the wide wing struts and fuse, it will knifedge all the way around the drill hall at walking speed. Weight is everything. Wing wire braces are denral floss. Strong stuff, been on there for two yrs. and havn't broke one yet, even with more than a few midairs. Looking for a rafter to make me climb.
Crazy Rainy Day Build Ideas - Glass M60 Fuse screamin' eagle Slope 7 Feb 18, 2005 05:13 PM
Which One, or any better ideas? Someone Electric Heli Talk 3 Feb 17, 2005 12:30 AM
my first bit plane build (ideas welcome) charlieuk Scratchbuilt Indoor and Micro Models 80 Dec 12, 2004 12:39 PM
Ed Lyerly, Genious? Or Mad Scientiest??? gdretiredcop Sport Planes 25 Sep 24, 2003 10:19 AM
Best ARF or quick build aerobatic slowflyer ??? Jeff Meyers Parkflyers 25 Aug 17, 2002 09:46 PM
