Old Dec 05, 2008, 08:30 AM
reptileman is online now
Find More Posts by reptileman
nj
Joined Jan 2004
Originally Posted by meronr
That doesn't seem to be the issue due to the fact that I have been able to charge both ignitors at 1c on my other charger which is a MRC 989 brain.
Hyperion chargers probably have better safty programs in them thuse knowing charging 1 cell at that high amprage is wrong so it turminates charge.
reptileman is online now Find More Posts by reptileman
Old Dec 05, 2008, 11:53 PM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
Check the link at ACW after Dec 15th. We expect to have them between 15th and 20th.
D
Originally Posted by pepatrick
ND,
Can you let me know when you get the new displays for the 610 duo. I need 2 of them.
Philip
NipponDave is offline Find More Posts by NipponDave
Old Dec 06, 2008, 06:57 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Sorry but there is nothing wrong with charging a single cell at more than 1C.
It is in fact safer to charge a single cell at a higher rate as there is no balance issue and yes I know the question is about Ni cell and yes Ni packs do get out of balance.
I have charged a single Ni cell at up to 5C as I also flew glow for over 45 years and my son still did up to this past summer.
Now , some chargers have a difficult time charging a single cell at a high rate due to the simple fact that they have a difficult time reducing the 12-15 volts input down to approx. 1.6volts output.
Some chargers come with a chart which shows max. charege rates at different voltages. Perhaps this one does also.
OP Snip
I have been trying to charge my glow ignitors. One is a one cell 5000mah nicd battery and the other is a 1 cell 4400mah nimh battery, when I charge these batteries at 1c the voltage reads at over 2.0 volts and than the charger stops charging and gives an error message that says output voltage too high..
Old Dec 06, 2008, 11:38 AM
meronr is offline
Find More Posts by meronr
One bad mama jama
Oradell New jersey
Joined Dec 2008
Theories are great and I appreciate them but I just want some definitive answers as to why I am having this problem...I know I have said that I've charged my battery at 1c on my 989 but that is not the only charger I've done it on, I've done it as well on some very good chargers, this is first time i'm having this issue with a charger and in my opinion it shouldn't be this way especially for how advanced a charger the duo is claimed to be
meronr is offline Find More Posts by meronr
Old Dec 06, 2008, 11:56 AM
hilgert is offline
Find More Posts by hilgert
Buyin', Tryin' and Flyin'
hilgert's Avatar
DFW, Texas
Joined Jan 2005
Maybe someone else can help me with my dilemma...I have been trying to charge my glow ignitors. One is a one cell 5000mah nicd battery and the other is a 1 cell 4400mah nimh battery, when I charge these batteries at 1c the voltage reads at over 2.0 volts and than the charger stops charging and gives an error message that says output voltage too high..The only way that i have been able to charge these batteries is to charge them .5c or lower....PLEASE SOMEONE HELP ME
You are selecting the right battery type (nicd and nimh), correct? I know it sounds like a silly question...just wanting to eliminate all possibilities. I am sure you are selecting this correctly, but it's worth a shot to ask.
Also, have you charged other battery types with this charger? Lipo? A123? Maybe it's a bum charger.
-Hilgert
hilgert is offline Find More Posts by hilgert
Old Dec 06, 2008, 03:36 PM
nj
Joined Jan 2004
Well i would not charge 1 cell at that hight rate only leads to a shortened life..
Also what MV sensitivity you setting your charger at maybe you need to set it a little higher? Also if these cells are always charged like you said they may be worn down and this causes a charger to false peak do to damaged over used cells
Old Dec 06, 2008, 06:34 PM
meronr is offline
One bad mama jama
Oradell New jersey
Joined Dec 2008
-Hilgert
yeah i have everything set correctly
Old Dec 06, 2008, 06:36 PM
meronr is offline
One bad mama jama
Oradell New jersey
Joined Dec 2008
I've tried both 5mv and 6mv both have the same result and the batteries themselves have not been charged more than 30 to 40 times doesn't like that many times to me
Old Dec 07, 2008, 08:25 AM
Dragonfueled is offline
Find More Posts by Dragonfueled
Joined Jul 2008
Anyone figure out what the channel button with the 1.9 firmware update changed? I cant seem to see the change the addendum talks about. Maybe i gotta redo the install?
Dragonfueled is offline Find More Posts by Dragonfueled
Old Dec 07, 2008, 07:26 PM
feathermerchant is online now
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I love my Duo! I had a problam the other night though. I pushed the mode button and the display went blank. I tried it and teh ch button and nothing made it come back. The charger was still beeping and acting like it was still charging/balancing. I had 2 6S packs charging solo. After pushing the enter button for both chargers it stopped charging. I disconnected teh packs and cycled the power. It has worked fine since. It probably charged 10 or 12 6S LiPo and 2 2S A123 batteries today. Anyone else seen this?
feathermerchant is online now Find More Posts by feathermerchant
Old Dec 07, 2008, 10:46 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Pls tell me the following:
1) Firmware revision
2) NiMH / NiCd MODE used to charge
3) Are the Batts inside the glow ignitor, or removed from it?
4) What is the gauge (awg) of wire used between charger and the batts?
David
Old Dec 07, 2008, 10:55 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
We have seen this situation when a AC>DC Power supply is being used, and the PS starts generating too much electronic noise. Typically this happens when the PS is being pushed hard, or if the PS is just poor quality. v1.9 (for DUO/NET) and the newest firmware for DUO2 and 0720iNET attempt to help address this, but in some cases the PS will need to be replaced, or draw limited.
In a few other cases out of thousands sold, we simply get an LCD problem or related issue which causes the LCD to go permanently blank or characters not to display - and which would require LCD or charger replacement as the case may be.
David
Old Dec 07, 2008, 11:02 PM
NipponDave's Avatar
American in Japan
Joined Mar 2001
hang on a bit for more news on this one... The lab report for latest firmware had a note "Contact for details" on the upgrade list next to the CH BUTTON upgrade, but my firmware engineer was on holiday the past week, and I was buried trying to get docs for emeter v2 done so did not test the function myself before release. I see now that it is not as fully implemented as we wanted yet. I expect to get the background on Tues morning when he returns.
I'm guessing that full implementation involves a lot more coding than one might think, and that it is being worked on for next release. Anyway, news soon...
David
UPDATE after talking to engineers: Yep, I was right... Due to a variety of factors - such as Global Settings (PS Load etc) being under CH1 but not CH2 - and just generally a lot of required code additions, the v1.9 change is limited to this new description in the Manual Addendum:
Previously, when viewing – for example – Cell Voltages in the Data View on one CHANNEL, pushing the CH Button would take you to the previously used screen position on the other Channel. Now when the CH Button is pressed it will take you to the corresponding MODE, on the other channel, but not usually the exact same screen. It simply saves a few button pushes during setup… This applies only during setup, and not during charge (or discharge, store, etc) operation. We hope to have this function screen-to-screen and during operation in upcoming release, but it does require major rewrites so please be patient…
By "MODE" it means MEMORY, USER SETUP, DATA VIEW... is followed from CH1 to CH2, but the specific screen can't yet be followed. Anyway, it is on the table and we'll continue working to get screen-to-screen implemented all the time (as long as batts on CH1 and CH2 are the same chemistry, otherwise it may get too complex...).
David
Old Dec 07, 2008, 11:23 PM
meronr is offline
One bad mama jama
Oradell New jersey
Joined Dec 2008
David
1.Currently using firmware version 1.7 but have the usb link on the way to update to the 1.9 firmware. Should be able to do it by Tuesday.
2.Using Normal mode to charge both forms of battery.
3.The battery is not removable on one of the ignitors the other one it is, but I am not removing it.
4.I am using a hobbico glow ignitor cable which they sell with the banana plugs already installed on it to be used on a charger, the wire is 16awg.
Hope this info will help you Dave to figure out my problem. Thanks in advance.
Meron
Old Dec 09, 2008, 03:11 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Been playing with my duo2 for a week now. It rocks Im charging lipos as quick as I can fly them! Where as I was constantly waiting for my poor over worked 606iAC/DC to churn them out. I actually like the noise as of the 2 fans in the charger and the 2 fans in the PS fire up, mmmmm... Power
jackosmeister is offline Find More Posts by jackosmeister
Article Hyperion EOS 0610i DUO Multichemistry Charger Review Spackles94 Batteries and Chargers 113 Sep 12, 2015 08:40 AM
Discussion Hyperion EOS DUO-NET Beta logging Software NipponDave Batteries and Chargers 83 Nov 30, 2008 11:07 PM
Sold Hyperion EOS 0610i DUO Charger - $190 Shipped hilgert Aircraft - Electric - Batteries & Chargers (FS/W) 3 Nov 25, 2008 08:00 PM
Discussion Hyperion EOS 0610i DUO - where to buy? jaron Batteries and Chargers 2 Jan 22, 2008 09:21 AM
Sold hyperion eos 5i chargers $72.00 shipped ea kmp647 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 15, 2006 11:23 AM
