Go Back   RC Groups > Aircraft - Electric - Helis > Large Electric Helis
Old Nov 28, 2008, 07:53 PM   #1
Now Wren 1701
Wren1702's Avatar
Flybarless Swift 16/Approach Cobra Build
OK, couldn't stand it anymore...had to build the mechanics.
Equipment:
Swift 16
AR-7000 RX
401/9254 Combo
HS-5625MG Servos
HV-85 ESC
Starting out with Scorpion 4025-890 motor
Skookum SK-360
First, the head. Assembled very easily, no problems. Was super smooth!
Wren1702 is offline Find More Posts by Wren1702   Reply With Quote
Old Nov 28, 2008, 09:13 PM   #2
Now Wren 1701
Wren1702's Avatar
Next, the frames. Wasn't crazy about how you have to hold the nuts for the motor mount....but no big problem.
Old Nov 28, 2008, 09:48 PM   #3
Will work for heli's
Dogwoodtheone's Avatar
Send a message via AIM to Dogwoodtheone
Nice Wren, will be keeping my eye on this one
Dogwoodtheone is offline Find More Posts by Dogwoodtheone   Reply With Quote
Old Nov 28, 2008, 10:05 PM   #4
Yes that is my Agusta A109
Spidious's Avatar
Hey its all my fault he decided to go ahead and build his Christmas present early !
Really waiting to see the body kit build !
Spidious is offline Find More Posts by Spidious   Reply With Quote
Old Nov 28, 2008, 11:18 PM   #5
I will be following as well. I keep thinking of doing an approach build.
pjpg is online now Find More Posts by pjpg   Reply With Quote
Old Nov 28, 2008, 11:36 PM   #6
Now Wren 1701
Wren1702's Avatar
Moving ahead.... goofed up a couple of times not paying attention to what I was doing...no harm, just a few extra minutes time. Century should really take the manual and make it step it step (AKA Align manual).
Old Nov 28, 2008, 11:53 PM   #7
Spidious's Avatar
Be sure you got a good tail boom. Some of them were drilled off slightly and can cause the tail rotor blade to be at a 85° angle instead of a 90° angle..
It doesn't matter if you use a aluminum tail rotor assembly !
Old Nov 29, 2008, 12:40 AM   #8
Now Wren 1701
Wren1702's Avatar
Tail box is OK, thanks!
Starting set up the mixing, etc with the Skookum.
Used servo plates and longer screws to install the servos. I did use two of these same servo plates to space the elevator servo out a bit more for perfect alignment.
Old Nov 29, 2008, 01:05 AM   #9
Volts < Amps
desert_flyer's Avatar
Wren,
Make sure you reduce tail drag compensation to -1 in the SK360. The standard setting is way too high - the heli tends to pitch up and down in FFF.
desert_flyer is offline Find More Posts by desert_flyer   Reply With Quote
Old Nov 29, 2008, 02:05 AM   #10
Now Wren 1701
Wren1702's Avatar
Originally Posted by desert_flyer
Wren,
Thanks, I'll make sure and check it. Have you tried the new revision yet? They say that the problem has been cured with this revision.
Old Nov 29, 2008, 02:14 AM   #11
Now Wren 1701
Wren1702's Avatar
Well, time to call it at night. About 4 1/2 hours spent on the heli. so far. All the mixing/Skookum setup is done. I'm really impressed with the kit! Ball links fit very well. Tomorrow we'll tidy up the wires.
Old Nov 29, 2008, 05:31 AM   #12
Greybird's Avatar
Man, that looks nice! Sure cleans up the rotor head without a flybar, and all that goes with it.
Greybird is offline Find More Posts by Greybird   Reply With Quote
Old Nov 29, 2008, 10:12 AM   #13
Spidious's Avatar
This looks really nice. But how much wire clearance to the motor ?
Are you going to put the gyro on the back plate area ?
Old Nov 29, 2008, 11:20 AM   #14
Now Wren 1701
Wren1702's Avatar
Haven't decided where to route the servo wires yet.
Old Nov 29, 2008, 03:45 PM   #15
Now Wren 1701
Wren1702's Avatar
OK, everything mounted and wired. Turned out really well (At least I think so ) Made my own Gyro/Skookum mount after finding a similar setup in the Tales thread.
Turned the motor around so I could mount the ESC a little different so the throttle wire would reach the RX.
Discussion Swift 16 Airwolf build Skywolf Electric Heli Talk 2 Jun 27, 2008 07:52 PM
Discussion Swift 16 build questions ghostofpf1 Electric Heli Talk 6 Mar 10, 2008 08:37 AM
Discussion Swift 16 Arf Build Question RabelRouse Electric Heli Talk 6 Nov 09, 2006 08:04 PM
Century Swift 16 Build Thread dthreatt Electric Heli Talk 52 Dec 21, 2005 04:32 PM
Congratulations SimpleM!
