| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
First Look at the Hyperion Emeter II
Introduction – One good measurement is worth a thousand advertisements
Measuring the real performance of electric power systems is something just about every modeler who runs an electric powered vehicle needs to do if he or she is to move beyond prepackaged combinations or to find out which performance claims are written by the engineering and test department rather than the marketing department. For that matter, a number of prepackaged or frequently recommended combinations are more marketing hype than reality. In order to do that, as a minimum you need a tool that can be inserted into the power system (usually between the battery and the speed control) that can read out real time voltage and current. The simplest of these devices do just that. Some add calculated values such as power and ampere-hours in real time, and some also capture peak values so you don't have to remember them to write them down. Add a hand-held tachometer so you can get RPM readings at the same time and you have the tools to figure out what's real and what's not and what combinations work better or worse as you start to mix and match components. Such a tool is also vital to help you not find the limits of a motor or electronic speed control or battery by burning it up. Some of these tools will also interface with a Windows PC so you can capture and graph data from your tests. You can also use such a tool for a bunch of other things, such as to check to see if chargers are doing what they say (especially if they don't have a display of their own) and in conjunction with some kind of load, test and evaluate batteries. One of the most versatile and sophisticated such tools available to us over the past few years combined the multifunction electrical meter with a tachometer in one unit and added the ability to capture and store "snapshots" of that data all in an easy-to-use handheld device. It also had other capabilities including the ability to interface with a Windows PC to log data as it was being gathered. This tool was called the "Emeter" and was built and sold by Hyperion HK.
Enter the Hyperion Emeter II – Making a Cool Tool Even Better
In July of 2006 I reviewed the Hyperion Emeter here on the Ezone, with the idea that I follow that review with a second part showing how the Emeter worked in conjunction with a PC to enhance its data capture and analysis capabilities. But by early 2007 Emeters got to be hard to find long before I got the second article done (I tend to be kind of slow while trying to be thorough). It turned out that the wizards behind the Emeter were doing a complete makeover to address some of the little things about the first version that folks (including me) had offered some feedback about. They were also adding quite an amazing array of new capabilities. David Radford first outlined what an "Emeter Version 2" would be like in this post on February 25th, 2007. Well, as often happens with projects involving hardware, software and multiple suppliers around the world (*sigh* take a look at the Boeing 787) the Emeter II, as it is now officially dubbed, has taken rather longer than anyone wanted. But it does exist, and I have one that I can introduce it to you. This is the first of a projected four-part series of articles about the Emeter II and how it can be used to find out what's really going on in your power system (both statically and in the air/water/on the ground), as well as the other things that can be done with it. By the way, according to the Hyperion support page for the Emeter II and RDU they will be available from your favorite Hyperion distributor by the end of January 2009. Suggested retail price for the entire package (Emeter II, remote data unit, connecting cable and charge cable) is $199.95 US.
Upgraded hardware
The general outline of the Emeter II package is substantially as David described it in that post nearly two years ago. Compared to the original Emeter, the Emeter II has:
While adding all of this makes the Emeter II physically larger than the original, it still fits comfortably in my hand, and if anything it feels more solid, in part because of the extra mass due to the much larger battery pack. The case is still the rugged-feeling muted blue plastic of the original.
Many more feature and capabilities
All of these hardware upgrades allow for a rather astonishing list of additional features and functions, as well as making some of the more interesting features of the original (such as being able to estimate power out and efficiency of a power system based on prop constant data) MUCH easier to use. Please take a look at the original Emeter review to get acquainted with what it could do if you're not already familiar with it – that way what follows will make more sense (and I don't have to reiterate ALL the functions here). Features and capabilities that are added to the original Emeter's list, or are substantially improved include:
I'm sure I've missed a few, and as Mark and Phil are still working hard on the firmware this list will continue to grow, just as it did for the original Emeter. In fact it's grown a little just while I was putting this overview together. Getting around all these features is very straightforward and feels very familiar, even though the menu system is deeper. In general, a button will be labeled "next" to scroll down the current list and another will be labeled "go" to select the highlighted item and go to the next menu down. At the lower levels there will also be a "menu" button which takes you back up a level.
A Walk Around the Emeter II
As I mentioned above, the Emeter II is bigger than the original, but it's still fairly compact at about 2 1/4 x 4 3/4 x 1 5/16 inches and about 5.3 ounces (58x120x30 mm and 150g). The case is a dark blue plastic (it feels like polystyrene to me) and has a generally solid feel. On the front face below the molded in "Emeter II" logo is the backlit graphical monochrome LCD display that's about 1 ¾ inches (44mm) square. Below it are four push buttons labeled "A", "B", "C" and "D" on the case. Their actual functions at any given time are displayed at the bottom of the display right above them. Below the buttons is a dial that is a little less than ¾ of an inch (19mm) in diameter labeled "servo". This is the control for the built-in servo driver. On the top end is the photocell for the built in tachometer. On the left side is the slot for the SD-format memory card. On the right side are the power switch ("0" for off, "1" for on) and the jack for charging the internal NiMH battery. On the bottom are four sockets. The two on the left are wired in parallel and are for the servo-driver function. Having two allows an external power supply (such as a receiver battery) to be connected without need for a Y-lead. The third socket from the left is for connecting Atlas digital servos while they're being programmed and will also be the connection for a direct computer interface. Of course, as I mentioned above, the SD card can be used as a means to transfer files between the Emeter II and your computer. Finally, on the right end on the bottom is the socket for the cable connecting the Emeter II to the Remote Data Unit (RDU). The provided cable can also be connected to a Hyperion Titan speed control so that you can program it from the Emeter. Inside one finds the five-cell battery and a neat, clean board layout. There is a definite look and feel of quality and care about it.
The RDU itself is about 1 3/8 x 1 1/8 by 1/2 inch (36x29x14mm) and has very heavy power leads that are about 1 3/4 inch (45mm) long coming out of each end. It weighs about one ounce (28g) plus the weight of your chosen connectors, which you must install on the leads. Mine now weighs 1.3 ounces (37g) with Anderson Powerpoles on it. By the way, I had to spread open the "cups" in the 30A Powerpole contacts to get them on the heavy-duty wiring. These would not be a good choice if you were going to use the RDU anywhere near the 150A limit. I'm not really sure what would be – 6 to 8mm gold bullets perhaps. This is rather beyond my realm of expertise.
In addition to the power leads it has two sets of connector pins on each end. On one end they are labeled Aux and Rx. The Aux connector is where the temperature and future sensors will be connected. The Rx connector is for remote triggering of logging on and off and, with the use of an appropriate Y-lead, the pulse width of the throttle channel (from which one can infer the throttle command). On the other end are the connectors for the Emeter cable and the brushless phase RPM sensor. When the cable is connected between the Emeter II and the RDU, the Emeter displays and can capture Volts, Amps, calculated Watts and Ampere-hours, as well as RPM, among a number of other things. If the Emeter and RDU are NOT connected together then the the RDU captures and stores the data itself and will give you the option to upload it to the Emeter (actually the SD card) the next time you turn the Emeter on with the two units connected.
A Brief Tour of the functions
Here are a number of pictures of various displays to illustrate what the Emeter II is set up to do and what the user interface looks like. Over the rest of the articles in this series I hope to share with you how these many capabilities are used, both on the test stand and aboard your model.
The main menu and help files
The Readings Function - The main action is here
Programming for ESCs and Servos
Stopwatches
I haven't experimented with this at all yet.
The Servo Tester - manual and automated testing
A servo or ESC can also be driven manually whenever it's plugged into the Emeter II by just turning the dial on the front.
Retrieving data from the RDU when used as a standalone logger
Examining and visualizing logged data captured by the Emeter II or the RDU in standalone mode
Setup of the RDU and the Emeter II itself
Firmware updates
Conclusion, for now
The Emeter II has been long in coming, but it looks like the wait has been worth it. Even without getting to test out the whole range of its capabilities (yet) I can tell that this little jewel has the potential to handle many of the test scenarios I can think of in a small, portable, upgradable package. It's also very easy to work with. From what I've seen so far (and I've just scratched the surface), this is sure going to be fun!
Next Time: The RDU Goes Flying and Having Lots of Data In The Field Without Needing A Laptop Computer
The next installment in the series will look at using the Remote Data Unit and RPM and temperature sensors to log data in flight and using the Emeter II to display and evaluate that data right on the flying field. Since it's winter time in the Seattle area and as of this writing I don't yet have the brushless phase sensor or temperature sensors, look for this article in the spring sometime. Last edited by Angela H; Jan 21, 2009 at 06:53 AM.. |
Thread Tools |
#2 |
War Eagle!
Bernard,
Thanks for that comprehensive review and for explaining all the features. I'm looking forward to hearing about how the in-flight data logging stacks up. It's nice to see that you can just check it at the field without needing a laptop on site or anything. Very cool! I remember when I went to get a wattmeter, and everyone said I should get the E-Meter — but it was out of stock and this one was "about to come out." But it was a while back, and I'm glad it arrived — better late than never. ![]() $200 sounds like a good bit of money, but Hyperion's products tend to be worth their money. ![]() Thanks again, and I'm looking forward to future installments! |
#3 |
Thanks, Napo. I'm looking forward to future installments, too. You can see by the Switchback Senior review (and the SHAFT before it) that I like lots of data.....
#4 |
War Eagle!
Yeah, I saw those reviews, and they were amazingly thorough! Nicely done.
More (data) is better, right?
#5 |
As always, a great presentation!
![]() Some folks who see this thread may not know that I have a preview/review going on the Emeter II & RDU as well. It is located at http://homepage.mac.com/kmyersefo/em...meter2rdu.html The article was just updated moments ago and now has info on how I used it to bench test a new motor, monitor the discharge and charge of a battery and make the database of props more user friendly. In case some of you might think I am jumping in on Bernard's thread, we've been sharing info and ideas about this tool for quite some time now. We are both awaiting its release to see your reactions to it, once it gets in your hands. It is one great tool! |
#6 |
Molded Hotliner Destroyer
The specs are actually 150 amps continuous or 300 amps peak for 5 seconds.
#7 |
AMA 754
For those of you attending the Arizona Electric Festival this coming weekend, the Emeter II will be available at the ALL e RC vendor booth.
#8 | |
Ken Myers posted the actual table from the documentation in the other Emeter II thread in this post. |
#9 |
Sorry, didn't see the table, I was referring to the text of your article where it says 150 amps maximum rather than 300 amps.
#10 |
Gotcha.....
Actually I dithered a bit about exactly how to describe it because I know from many discussions here in the various fora that if you say "surge" or "peak" of 300A, some folks are going to try it, burn an RDU out and then complain "but you said it would do 300A" for however long they wanted to run it (not that I'd even want to be within the length of the RDU-to-Emeter cable of a running system at 300A). So to think of it as 150A with a good amount of dynamic headroom is, to my mind, a more appropriate way to put it. What the heck wiring and connectors would you use even for 150A for 30 seconds? That is a serious question because I wouldn't trust anything I've ever used to that level (with the possible exception of Astro Flight "Zero Loss" connectors - and probably not even those). |
#11 |
It is released. Check your favorite Hyperion dealer/source.
| Thread Tools | |
| Build Log Swoose version 2.0 | Arrow | Parkflyers | 53 | Mar 07, 2004 08:10 PM |
| DLG version 2.0 | gustabmo | Hand Launch | 10 | Oct 07, 2003 09:19 AM |
| Question BN-2 Number 2 or Version 2.0 | Ruff | GWS (Grand Wing Servo) | 4 | Sep 03, 2003 09:23 PM |
| First look at several new servos | BEC | Parkflyers | 0 | Apr 25, 2003 09:19 PM |
| Just Got my first look at the GWS Tiger Moth-Small battery compartment! | mrebman | Parkflyers | 3 | Jul 10, 2001 09:47 PM |
