Old Feb 09, 2009, 12:47 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
You can also put a clunk on the pressure feed (third line) and drain your tank thru that line.
Rodney is offline Find More Posts by Rodney
Old Feb 09, 2009, 04:03 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Originally Posted by Zor
Hello Andy,
You can turn the upper tube down like the bottom one, insert the tank cap and then turn the tube back up about 180 degrees.
Zor
Zor,
Amazingly enough, that's exactly how I achieve the end result.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Feb 09, 2009, 04:06 PM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
Rodney,
It works perfectly well without an extra clunk providing you manoeuvre the bottom line into position much like as the post above. It stays there so no need to put a clunk weight on it.
Andy.
Old Feb 27, 2009, 04:16 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Check out these sweet shop tools.
http://www.byrnesmodelmachines.com/i...m=0227MM308221
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Feb 27, 2009, 06:36 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by AndyOne
Zor,
Andy.
Hi Andy,
I do not find anything amazing in plain logic .
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Feb 27, 2009, 11:36 PM
demonnitro is offline
Find More Posts by demonnitro
Joined Feb 2009
One of my most handy tools http://www3.towerhobbies.com/cgi-bin...?&I=LXK378&P=7
demonnitro is offline Find More Posts by demonnitro
Old May 26, 2009, 05:46 PM
Murocflyer's Avatar
Joined Nov 2005
Originally Posted by demonnitro
I agree, I just picked one of those up. Very handy indeed.
Frank
Old May 26, 2009, 06:26 PM
EricClark is offline
Find More Posts by EricClark
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Ha, I too picked one up because of this thread. Love it.
EricClark is offline Find More Posts by EricClark
Old May 27, 2009, 12:43 AM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
When rough shaping a LE with a razor plane, cover the LE sheeting of the wing with Duck Tape/Gaffa Tape or similar, preventing any "slips" with the razor plane from gouging the wing sheeting.
MCarlton is offline Find More Posts by MCarlton
Old May 30, 2009, 02:34 PM
pathfinder is offline
Find More Posts by pathfinder
Mach 1
pathfinder's Avatar
walterboro s.c.u.s.a
Joined Jun 2004
I always have short pieces of of that flexi-tubing used for push-rods leftover.
I use weed-eater cutting line for throttle cables.Use ez-connecters on both ends.Get the small weed cutting line and find a the smallest tube and it pushes through just as good as any throttle cable.I have a lifetime supply of throttle cable now.
When running a receiver antenna out the side of the fuse and attaching it to the vertical fin with a rubber band and a t-pin, I use I use a short piece of fuel tubing.I cut a small slit it the fuel tubing and run the antenna through it,and then insert a t-pin through the tubing and into the fin.This way it lasts forever.Fuel would always eat the rubber band and it would come loose.
jimmy.p.
pathfinder is offline Find More Posts by pathfinder
Old Jun 08, 2009, 07:30 PM
Murocflyer's Avatar
Joined Nov 2005
I just stumbled across these items: http://www.c-tronicsinc.com/Products.htm
Does anyone have any experience with the Plug and Glow? http://www.c-tronicsinc.com/Product-...owComplete.htm It looks like a cool item.
Frank
Old Jun 14, 2009, 06:25 AM
Murocflyer's Avatar
Joined Nov 2005
Originally Posted by EJWash
Last night, I remembered reading another method of applying wing sheeting.
The technique comes from a book from Model Airplanes News’ “Radio Control Airplane Building Techniques” by Randy Randolph.
Elmer’s, Tiebond, or any white glue is used (Titebond for me). A thin layer of glue is applied to the surfaces of the wing that will come in contact with the sheeting, and on the sheeting in the area that will contact the wing. The glue is allowed to dry (:30 in minimum) to the touch. The sheeting is then “ironed-on” using a clothes iron set to wool. The heat causes the glue to polymerize. Not sure if you can use a covering film iron or not.
I wanted to try a test piece, so I brushed-on Titebond on a 3/32” X 1/2” strip and a 1/4” square stick, both about 5” long. I used an old non-steam travel iron and bonded the two pieces together and set it aside to cool. Yep, it bonded alright!
Applying the top sheeting to the wing went smoothly. No pins, no pins holes. A much less intrusive method! I’ll be applying the cap strips the same way.
Thanks for following along!
EJWash
Old Jun 14, 2009, 11:20 AM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Frank
That does look sweet! But I too don't know.
Discussion What happened to original stickied Building Tips and Tricks thread. turt1e_b Foamies (Scratchbuilt) 9 Oct 15, 2008 07:10 PM
Discussion Lee ME262 Mods, tips and tricks thread Extreme_RC Australia 179 Oct 28, 2007 04:03 PM
Video Editing Tips and Tricks slopeiron Aerial Photography 6 Jun 11, 2003 11:52 AM
Viper Tips and Tricks? MattLarson29 Foamies (Kits) 3 Aug 16, 2002 02:48 PM
Ant tips or tricks for cutting a foam P-47 wing? kit basher Power Systems 0 Oct 28, 2001 09:23 AM
