Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Oct 22, 2009, 12:02 AM   #46
My hanger is full
No Step's Avatar
Thank you Tom.
No Step is offline Find More Posts by No Step   Reply With Quote
Old Oct 22, 2009, 08:25 AM   #47
And a master he is Want to work for him Like cleaning the floor or...As long one can see the master and feel the energy involve.
Has always very good ideas how things can be put together.
Noël
solitairyman is offline Find More Posts by solitairyman   Reply With Quote
Old Oct 22, 2009, 01:09 PM   #48
My hanger is full
No Step's Avatar
Progressing nicely!
Pull the pin on the gear, and it retracts (once) with the help of a spring or rubber band. No gear extension for landings
Wood is on it's way for cowl and canopy plug.
  • Name: IMG_3846.jpg
Description: Motor mount for 41 series AXI motor.  I plan to use a 4120/14.  Firewall is 1/4".  I was going to use 3/16" but didn't have any on hand.   I found this scrap that fit almost perfect.  A little sloppy on the top,.. oh well! Motor mount for 41 series AXI motor. I plan to use a 4120/14. Firewall is 1/4". I was going to use 3/16" but didn't have any on hand. I found this scrap that fit almost perfect. A little sloppy on the top,.. oh well! 91.6 KB · Views: 28
  • Name: mue23 gear.jpg
Description: Here's my design for a "one time retract".  She'll land on the retracted, half exposed wheel.  It's a little bizarre but it's light, and simple. Here's my design for a "one time retract". She'll land on the retracted, half exposed wheel. It's a little bizarre but it's light, and simple. 65.5 KB · Views: 45
Old Nov 03, 2009, 01:59 PM   #49
My hanger is full
No Step's Avatar
It seems longer than a couple weeks since last post. I've been busy with other projects. Currently, I have the gear done, 5/32" wire. I could not bend it as much as the drawing above shows without breaking it. And I've never had much luck with heating wire and trying to regain the correct hardness properties. So I went with a 90 degree bend. About all I have to do is figure out how I want to pull the release pin to retract the gear,.. that is,.. if I want to use a 90 degree bellcrank or a straight bellcrank and how to mount the servo. The pics below show a rubber band for retracting tension. I'll be using a spring eventually. I have put the stringers in place this morning (not sanded yet).
Major work on the fuselage is finished. Wing attach points will wait until I have the wing center section done. I'll be adding gussets here and there maybe. My balsa arrived so I can start carving the cowl and canopy plugs. The canopy will be vacuum formed with a soft aluminum tube frame will nest inside it.
  • Name: IMG_3850.jpg
  • Name: IMG_3851.jpg
Description: This hole was cut before I had teh gear figured out totally.  It's too big and will be fixed.  The wheel does not protrude into the fuselage interior.  It stays below the "floor". This hole was cut before I had teh gear figured out totally. It's too big and will be fixed. The wheel does not protrude into the fuselage interior. It stays below the "floor". 90.2 KB · Views: 19
  • Name: IMG_3897.jpg
Description: Gear down.  I still need to add single plate "gear door" above wheel. Gear down. I still need to add single plate "gear door" above wheel. 100.9 KB · Views: 29
  • Name: IMG_3898.jpg
Description: Cruise and landing position Cruise and landing position 111.7 KB · Views: 23
  • Name: IMG_3900.jpg
Description: pin pulled, gear retracted pin pulled, gear retracted 102.9 KB · Views: 29
  • Name: IMG_3901.jpg
Description: Gear retracted.   The motor battery will be fwd (to the left) of protruding gear Gear retracted. The motor battery will be fwd (to the left) of protruding gear 84.6 KB · Views: 28
  • Name: IMG_3896.jpg
Description: Rubber band will be replaced with a spring.  When pin is pulled, tension retracts gear and is held in place against the double brass square stock (spruce inside).  I'll pad it with thin rubber later Rubber band will be replaced with a spring. When pin is pulled, tension retracts gear and is held in place against the double brass square stock (spruce inside). I'll pad it with thin rubber later 100.9 KB · Views: 28
  • Name: IMG_3894.jpg
Description: Most joints are soldered wheel axle and spring attach cross piece are Jen-Welded.  I wanted to be able to remove the axle easily  to replace the wheel if needed. Most joints are soldered wheel axle and spring attach cross piece are Jen-Welded. I wanted to be able to remove the axle easily to replace the wheel if needed. 122.9 KB · Views: 36
  • Name: IMG_3902.jpg
Description: With gear installed, she weighs 15.3 ozs. as she sits there. With gear installed, she weighs 15.3 ozs. as she sits there. 113.6 KB · Views: 35
Old Nov 05, 2009, 12:22 PM   #50
My hanger is full
No Step's Avatar
I'm getting the cowl and canopy started. I'll probably get the plugs finished then move on to the empennage. I'll save the actual vacuum forming and fiberglass work until later.
  • Name: IMG_3903.jpg
Description: Starting balsa block - canopy Starting balsa block - canopy 125.5 KB · Views: 21
  • Name: IMG_3906.jpg
Description: 1/8" dia. aluminum tube applied, balsa is at or below contour, sweeping filler against tubes will bring surfaces nice and flat with crisp corners.  And I'll use the same dia. tubes for interior framing, should turn out nice! 1/8" dia. aluminum tube applied, balsa is at or below contour, sweeping filler against tubes will bring surfaces nice and flat with crisp corners. And I'll use the same dia. tubes for interior framing, should turn out nice! 96.3 KB · Views: 23
  • Name: IMG_3909.jpg
Description: Cowl block surrounds fwd fuselage.  This will work for awhile, until those top contours get whittled down to the fuselage frame, then I'll have to glue in interior reinforcements and finish with it removed from the fuselage Cowl block surrounds fwd fuselage. This will work for awhile, until those top contours get whittled down to the fuselage frame, then I'll have to glue in interior reinforcements and finish with it removed from the fuselage 89.1 KB · Views: 32
  • Name: IMG_3910.jpg
Description: Long way to go. I hope to get it close to contour tomorrow. Long way to go. I hope to get it close to contour tomorrow. 78.7 KB · Views: 26
Old Nov 05, 2009, 04:41 PM   #51
Nice work Fred!
You are making a real mould then or will you use the balsa shaped as your cowl? Keep it going...
Noël
Old Nov 05, 2009, 05:20 PM   #52
My hanger is full
No Step's Avatar
Hi Noel,....yes, I'll be making a mold and doing a fiberglass cowl. That's the only way to go.
Fred
https://home.comcast.net/~guilfoyle72/
Old Nov 07, 2009, 12:42 PM   #53
My hanger is full
No Step's Avatar
I've got the cowl very close to being finished. But,... something just didn't look right. The cowl looked too wide, the canopy angles didn't "agree" properly where they meet the cowl. I went back to the 3-view, back to the pictures, back to the several factory drawings I have. Then I saw my mistake. The nose tapers in at the front. The 3-view I have shows the sides parallel. Early drawings I made were made according to the 3-view, later revisions were made after getting better drawings, but was overlooked. >Now<, I have to go back, remove the firewall, bring the fuselage sides together more, reshape canopy plug, slice cowl plug in half, remove a section and glue back together. Luckily, I don't have to get into the landing gear mount area. It starts to curve just fwd of that.
Geez, I was going to have a nice weekend building the tail, now I have lots of rework to do.
  • Name: MÜ23-RUMPFVORDERTEILsm croppedjpg.jpg
Old Nov 07, 2009, 01:16 PM   #54
SB-28 UK Display Pilot
GeeW's Avatar
Don't you just love 3 views!
GeeW is offline Find More Posts by GeeW   Reply With Quote
Old Nov 07, 2009, 02:28 PM   #55
My hanger is full
No Step's Avatar
Not anymore. I used to think, " Ah, a 3-view. I've got it made". But now I understand.
Scale guy in training.
Old Nov 07, 2009, 05:41 PM   #56
When you do nothing Fred, you can't make mistakes!!
But we do build things out of just a drawing now with little other info yet. Collecting info on a plane is one thing, and then make it work an other. And of course there are holidays and other projects that makes you forget ...
But this will be OK when changed as you are going to.
Noël
Old Nov 07, 2009, 08:38 PM   #57
My hanger is full
No Step's Avatar
You are right Noel. I'm finished making the alteration. And very happy I took the entire day to fix it. It came out very good. The firewall is now 1.25" narrower, and the cowl is 1/2" narrower. It's looking very good. Pics when the filler is dry and it's sanded,.... then I can move on to the tail.
Old Nov 10, 2009, 09:18 PM   #58
My hanger is full
No Step's Avatar
My goal for this week is to get the tail and fuselage construction done and sanded, ready to cover. Next week I'll start the wing, or maybe take a break and make some Christmas presents. No,.. not model airplanes.
  • Name: IMG_3921.jpg
Description: An earlier pic in the process of shaping cowl/canopy An earlier pic in the process of shaping cowl/canopy 109.1 KB · Views: 18
  • Name: IMG_3940.jpg
Description: A little more contouring of the cowl is needed. A little more contouring of the cowl is needed. 104.8 KB · Views: 25
  • Name: IMG_3942.jpg
Description: Stab 98% shaped and sanded, Rudder/fin 70% shaped and sanded Stab 98% shaped and sanded, Rudder/fin 70% shaped and sanded 94.1 KB · Views: 22
  • Name: IMG_3935.jpg
Description: Pic of stab tubes before sheeting bottom Pic of stab tubes before sheeting bottom 100.0 KB · Views: 19
  • Name: IMG_3937.jpg
Description: Rudder before shaping Rudder before shaping 94.8 KB · Views: 19
  • Name: IMG_3936.jpg
Description: Bottom view of stab assy before sanding Bottom view of stab assy before sanding 93.4 KB · Views: 21
Old Nov 11, 2009, 11:00 AM   #59
Hi Fred,
This looks more like it. The few pictures we have show that you are close now. I asked for more detailed pictures from München.
I do hoop I get them before you have finished your model.
Anyway this looks like it will be a great model to fly.
Now you take a brake and enjoy playing Santa
Noël
Old Nov 11, 2009, 11:39 AM   #60
My hanger is full
No Step's Avatar
Yeah, starting to look like a motor glider now. The cowl is hardest part to define. These are the only pics I can find (and even at that, there are two or three different shapes). The 3 view is useless for this. I'm going to do my best, then set it aside until after I finish the wings, before I make the mold. I'm trying to model the one in the colored photo. I need to round the top more I think.
  • Name: dmu23cropped.jpg
  • Name: mu23cropped.jpg
Description: This is the one I'm trying to model. This is the one I'm trying to model. 11.4 KB · Views: 17
  • Name: mue23p142.jpg
  • Name: Saurier Mü 23.jpg
Bored? Want to fight?
Join the RCGroups clan!
