Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Mar 07, 2009, 08:13 PM   #31
My hanger is full
No Step's Avatar
Thanks Dieter, I might just take you up on that. I intend to make a contribution to their restoration fund. I may have you translate a letter for me. That'd be much better than translation software. Btw, looks like some nice slope sites you've found over there!
Fred
No Step is offline Find More Posts by No Step   Reply With Quote
Old Oct 10, 2009, 09:08 PM   #32
My hanger is full
No Step's Avatar
I'm starting the build. It's been a year since I started thinking about this model. I just finished doing the maiden flight on my most recent project, a Sperry Messenger biplane,- http://www.rcgroups.com/forums/showthread.php?t=1074370 (yes, I'm very happy) , so next one in the build Que is the Mue-23. I'm clearing my workbench tomorrow and will start laying down balsa on Monday.
I've just spent 5 hours going over my plans, making changes and adjustments here and there. And I'm sure more changes will come about as I go along. To my knowledge, this will be the only R/C model ever built of the Mue-23, in the whole wide world,... to this date. That's so cool! I'm a pioneer!
I contacted Akaflieg München last month to see how much progress has been made on their restoration project. Sadly, no progress has been made at all. They have been doing other things and/or flying. I was hoping for some new pictures. But that's just not going to happen. I'm officially part of their Mue-23 restoration project. I contributed $75 to their building fund. Solitaryman contributed as well. They probably bought beer and Schnitzel with the money. That's OK. I feel like I'm a part of the project anyway .
Stay tuned for progress reports as they happen. I'm hoping the build will be completed by the end of January, 3 1/2 months. That should be more than enough time.
If anyone has missed it, to recap, it will have a 157"ws, electric (Axi 4120/14), 4s or 5s 2600 maybe even smaller - 2100? All I want is about 2 climbs to altitude. I'm thinking 4s will be a longer, more labored climb. Whereas, 5s, will take her up NOW! We'll see. It will have a one time retractable gear. So after takeoff, the gear will retract once and stay there. Landing will be done on the half exposed wheel. I don't want the complication of a fully up/down retractable wheel. I want light and simple. That's my thinking so far, all subject to change .
Old Oct 13, 2009, 06:46 PM   #33
My hanger is full
No Step's Avatar
It's a start.
  • Name: IMG_3712.jpg
Old Oct 13, 2009, 08:50 PM   #34
slope'n the Colombian Andes
ShredAir's Avatar
Originally Posted by No Step
It's a start.
No step, it's a first step... : )
I look forward to following along, and I'll be in Munich next spring, maybe I'll have a look at what the Akaflieg is doing with theirs.
Dieter Mahlein, ShredAir
ShredAir is offline Find More Posts by ShredAir   Reply With Quote
Old Oct 14, 2009, 09:36 AM   #35
Fred!
Keep the pics coming!!!! Waiting all the time.
Toshiro
suirendoujin is offline Find More Posts by suirendoujin   Reply With Quote
Old Oct 14, 2009, 11:35 AM   #36
My hanger is full
No Step's Avatar
That would be great Dieter. I'll be finished with the model by then but that's OK. I'd be interested in hearing how it's coming. They said they'd send me photo updates, but I'm not really expecting them. It's easily said and easily forgotten,... with all good intentions.
Toshiro, hello my friend! Long time no see. I'll keep progress updated regularly. I have both sides done, and now planning how to join them. The lower mid fuselage transitions to an inverted triangle cross section which will be tough to do. Water, maybe mixed with ammonia, patience, and for sure cracking (or cutting) of the the longerons will be in needed. Upper image is a cross section roughly 3/4 down from top of fuselage.
  • Name: mue-23 fuselage cross section.jpg
Description: upper image is a cross section roughly 3/4 down from top of fuselage upper image is a cross section roughly 3/4 down from top of fuselage 19.3 KB · Views: 64
Old Oct 14, 2009, 04:31 PM   #37
My hanger is full
No Step's Avatar
I'll be posing often. I know of one at least one other person that may build one so this thread will also serve as a well documented "how-to" to show how I went about building mine (right or wrong). I'm pretty much making up the process as I go along. Mistakes will be admitted, and successes will be bragged about,... all in good fun. I must have made dozens of changes (some major) to my drawings just over the past week. I think I've got it pretty much nailed now though.... subject to change as I go along .
  • Name: IMG_3713.jpg
Description: Fuselage plate is 3/16 balsa.  I considered 1/8" lite ply, but stayed with balsa.  I had a nice piece on hand.  I'll be adding some cross pieces to the plate later. Fuselage plate is 3/16 balsa. I considered 1/8" lite ply, but stayed with balsa. I had a nice piece on hand. I'll be adding some cross pieces to the plate later. 43.3 KB · Views: 45
  • Name: IMG_3714.jpg
Description: Gluing fwd part is easy Gluing fwd part is easy 42.0 KB · Views: 48
  • Name: IMG_3715.jpg
  • Name: IMG_3717.jpg
Description: I didn't use water on the longerons while wrapping to the curved plate I didn't use water on the longerons while wrapping to the curved plate 91.4 KB · Views: 47
  • Name: IMG_3719.jpg
Description: I sliced the longeron 1/2 way thru but it still snapped apart at the last second.  If I used water it would have been fine. I sliced the longeron 1/2 way thru but it still snapped apart at the last second. If I used water it would have been fine. 71.2 KB · Views: 51
  • Name: IMG_3720.jpg
Description: When I positioned them back together, I ended up with a small gap.  I'll add a tie plate there later When I positioned them back together, I ended up with a small gap. I'll add a tie plate there later 70.5 KB · Views: 48
  • Name: IMG_3716.jpg
Description: Top cross pieces will be easy, but the fuselage sides are going to be groaning with stress in the transition area. Top cross pieces will be easy, but the fuselage sides are going to be groaning with stress in the transition area. 34.3 KB · Views: 44
  • Name: IMG_3721.jpg
Description: Back half is triangular.  I'll add cross pieces tomorrow... and I'll wet the balsa.  At the bottom, some of the joints may crack under the stress.  I'll reglue everything once the cross pieces are installed. Back half is triangular. I'll add cross pieces tomorrow... and I'll wet the balsa. At the bottom, some of the joints may crack under the stress. I'll reglue everything once the cross pieces are installed. 94.3 KB · Views: 50
Old Oct 14, 2009, 09:53 PM   #38
My hanger is full
No Step's Avatar
This has got to be the most tedious part of the build. It is going well.
  • Name: IMG_3725.jpg
Description: Angle aluminum is used to keep longeron straight.  Cross pieces are easily installed. Angle aluminum is used to keep longeron straight. Cross pieces are easily installed. 40.0 KB · Views: 51
  • Name: IMG_3727.jpg
  • Name: IMG_3726.jpg
  • Name: IMG_3731.jpg
Description: Oh man, this is gorgeous! Oh man, this is gorgeous! 36.7 KB · Views: 59
  • Name: IMG_3729.jpg
Description: Bottom longerons beveled and glued together Bottom longerons beveled and glued together 96.0 KB · Views: 53
Old Oct 15, 2009, 07:22 AM   #39
ShredAir's Avatar
They say, the worse the weather the better the building...
Is the weather THIS bad already in Everett? : )
(from sunny and warm Colombia)
Old Oct 15, 2009, 10:25 AM   #40
My hanger is full
No Step's Avatar
Yep, it was very nice until Monday (the day I started the mue-23), now it's raining, and windy. 10 day forcast is for more of the same. Our winter is here. Whoo-Hoo! Perfect building weather. I love it. Full speed ahead.
Old Oct 15, 2009, 08:25 PM   #41
My hanger is full
No Step's Avatar
I didn't do much today but "fix it". Because the sides were built first then attached to the fuselage plate with the drastic concave curve, there was a foreshortening of the side frames. I used aluminum angles to square everything up again and cut loose lower glue joint of 5 paired diagonals so they would allow the bottom longeron to drop down properly. I filled the gap with balsa. I have no idea how to get around this. It'd be very difficult to purposely build the sides "wide" in the middle to make it come out right. I'm happy with how it's turned out . Everything is straight and square. That's the most important thing.
  • Name: IMG_3735.jpg
Old Oct 18, 2009, 11:58 PM   #42
The weather station near the ERMA field on saturday morning at 8am showed a rainfall of 3.2 inches per HOUR....God was playing with the garden hose again. Got enough balsa Fred ???
Neil
maxxnut is offline Find More Posts by maxxnut   Reply With Quote
Old Oct 21, 2009, 05:47 PM   #43
Hi Fred,
I like this. But it is going to fast again.
I am looking forward to the rest of the building now.
BTW I did send them a box of the good Belgian chocolates too.
As I was told the box was empty before one new it
I have changed a bit on my Moni too.
I will post it later.
Noël
solitairyman is offline Find More Posts by solitairyman   Reply With Quote
Old Oct 21, 2009, 10:18 PM   #44
My hanger is full
No Step's Avatar
I spent half the day today gluing up the lower fuselage and double, triple checking My landing gear idea. I'm going to have to start bending steel pretty soon.
Hello Noel, those drawings I gave you are way out of date now. I've made many, many, many changes since then. I'll get you the new files when I'm done, or sooner if you need them.
  • Name: IMG_3828.jpg
Description: 1/8" hard plywood plate on bottom of fuselage floor.  Spreads out stress of hard landings.  Still need to make cut out for gear legs to retract up into fuselage. 1/8" hard plywood plate on bottom of fuselage floor. Spreads out stress of hard landings. Still need to make cut out for gear legs to retract up into fuselage. 83.9 KB · Views: 19
  • Name: IMG_3833.jpg
Description: 1/8 x 1" lite ply extends through the 3/16" balsa floor, up onto fuselage framing.  This helps spread out the loads from landing gear,... I think. 1/8 x 1" lite ply extends through the 3/16" balsa floor, up onto fuselage framing. This helps spread out the loads from landing gear,... I think. 38.1 KB · Views: 27
  • Name: IMG_3836.jpg
  • Name: IMG_3845.jpg
Description: Lower fuselage basically done, landing gear next. Lower fuselage basically done, landing gear next. 44.6 KB · Views: 27
  • Name: IMG_3834.jpg
Description: RH door, LH is a window RH door, LH is a window 40.4 KB · Views: 19
  • Name: IMG_3843.jpg
Description: Busy intersection of sticks. Busy intersection of sticks. 42.3 KB · Views: 21
  • Name: IMG_3831.jpg
Description: Access hatch for stabilizer bellcrank Access hatch for stabilizer bellcrank 90.2 KB · Views: 25
Old Oct 21, 2009, 11:42 PM   #45
Nice work Fred. Its always fun and humbling to watch the master at work!
Tom
mmartin55 is offline Find More Posts by mmartin55   Reply With Quote
Bored? Want to fight?
Join the RCGroups clan!
