Old Nov 27, 2008, 04:32 PM
airplane7794 is offline
Find More Posts by airplane7794
Joined Jul 2007
Question
When does a 6 volt battery become unsafe to use?
Basically i have been hearing numerous answers to the following question: If i have a 6 volt 2000 mAh nickle metal battery being used in an avistar with a stock futuba reciver, under load what charge amount (6 volt, 6.5 volt, and so on) should I stop flying at.
airplane7794 is offline Find More Posts by airplane7794
Old Nov 27, 2008, 06:41 PM
Carlyle Harper is offline
Find More Posts by Carlyle Harper
Carlyle Harper's Avatar
Joined Feb 2007
5.8 to 5.9v
Carlyle Harper is offline Find More Posts by Carlyle Harper
Old Nov 28, 2008, 09:45 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
When you say "6 volt battery" I am assuming you mean 5 cell battery. If so, you can safely fly down to 5.5 volts with no worry. At that point you will still have about 5 to 10% of the stored energy available before the voltage takes a nose dive.
Rodney is offline Find More Posts by Rodney
Old Nov 28, 2008, 12:38 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Please note that you must read the voltage under a 200 to 250 mA load. An unloaded voltage is meaningless.
Bill
ebill3 is offline Find More Posts by ebill3
Old Nov 28, 2008, 01:39 PM
Chickenthief is offline
Find More Posts by Chickenthief
Denmark
Joined Aug 2008
I would say somewhere around 7.0 Volts.
I just made a curve of a 6-pack of mine at C and as You see it goes south at 7 and fast.
Chickenthief is offline Find More Posts by Chickenthief
Old Nov 30, 2008, 01:36 PM
Joined Feb 2007
The previous post demonstrated what a 6-cell nimh pack does. I believe the original poster said he has a 6-volt nimh pack, which most commonly refers to a 5-cell nimh pack. Nonetheless, the readings from the 6-cell pack confirm my 5.8-5.9v lower limit on a 6-volt pack. How you ask?
See if you can follow the logic.
A nimh cell has very little power left once it gets below 1.2v/cell. The nimh cells I have will bleed off to 1.2v/cell and sit there under load until they are just about drained then the voltage will start to fall off a cliff. The above graph demonstrates just this when you break it down to the cellular level (chemistry anyone?)
So a good working voltage for a 5-cell pack is 6 volts. When you get to below this with only a 250 milliamp load (not very much), the voltage falls off very rapidly, possibly resulting in a receiver failsafe especially if you have high current servos. A sudden spike in servo current would then depress the voltage even further because the cells can't handle it at the end of the charge, and then you get a failsafe or glitch followed by the mysterious crash, the cause of which eludes many people, because the battery seems to check out ok after the crash (since it had time to somewhat recover to pass the 250 milliamp load test again) and therefore they eliminate this as the cause of the crash.
Discussion When does one type of plane become two? Spinningreserve Slope 3 Aug 25, 2007 06:22 PM
Discussion Power Wheels 6 volt battery Tollytime Dock Talk 12 Jan 22, 2007 09:02 AM
Question 9.6 Volt Battery Pack Source no stick Batteries and Chargers 8 Jan 08, 2007 10:58 PM
