Old Nov 27, 2008, 08:40 AM
hartwig is offline
Find More Posts by hartwig
Joined Oct 2006
EzOSD with EzTelemetry, Live Google Earth, and Antenna tracking!
WOW! Have you seen this Demo-video?
EzOSD w/Telemetry and Antenna Guidance (2 min 19 sec)
hartwig is offline Find More Posts by hartwig
Old Nov 27, 2008, 08:50 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Goggle earth flight simulator superimposed on the screen while your flying? Why would you want to do that? I must be missing something.
Gary Evans is offline Find More Posts by Gary Evans
Old Nov 27, 2008, 10:03 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Gary,
Yes, you are! This is a demo video, the EzTelemetry is a real-time logging feature running on a notebook. So it simultanously captures the video to the harddisk, logs the flight to a .kml file, shows the current position of the plane on Google earth and displays the live video feed. The size of the window(s) etc. is all up to you, you can vary and overlay them to your preference as with any Windows application.
Obviously you normally won't be flying off of this screen, although you can (hint: for example at night) but you'll be wearing your goggles. This however allows you to record the flight, generate a flight log, and show the current position of your plane in real time all in one fell swoop. Or you can playback the recorded footage at a later date from your Mini-DVD recorder (or another storage medium) and replay your whole flight later on the PC using our application in the exact same way you would a real time flight.
If you have any further questions I'd be happy to answer them for you.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Nov 27, 2008, 10:08 AM
mdw21 is offline
Find More Posts by mdw21
mdw21's Avatar
Sarnia Ont. Canada
Joined Jul 2005
How much and when can we get one ?
mdw21 is offline Find More Posts by mdw21
Old Nov 27, 2008, 10:16 AM
ssassen is offline
Joined Jul 2004
The EzOSD will be priced competitively with the other offerings, although final pricing has yet to be determined. It will be available early Q1/2009 and small sample quantities to a select few users prior to that (the usual suspects), actually, there's a few beta units circulating already.
Cheers,
Sander.
Old Nov 27, 2008, 10:20 AM
ssassen is offline
Joined Jul 2004
Oh, before I forget, this is designed pending future compliance by the AMA and has a whole slew of warnings and fail safe mechanisms built in as to comply with many regulations. This includes for example call sign transmission for HAM licensed users, altitude and distance warnings, etc. etc. Also the whole design has undergone strigent RF, HF and CE/FCC compliance testing, to make sure it does not interfere with other equipment in the model.
Cheers,
Sander.
Old Nov 27, 2008, 10:28 AM
mdw21 is offline
mdw21's Avatar
Sarnia Ont. Canada
Joined Jul 2005
Sounds good
One more question, does it have true airspeed ?
Or just ground speed ?
Old Nov 27, 2008, 10:30 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
When I was running everything RS-232 (serial) I just split the serial output of the GPS. One went to my OSD, the other one went to a Maxstream back down to the ground. I was using TopoFusion at the time for the moving map. I haven't done the research on TTL output. I should look into splitting that output signal and do the same.
typicalaimster is offline Find More Posts by typicalaimster
Old Nov 27, 2008, 10:49 AM
massimo is offline
Find More Posts by massimo
massimo's Avatar
Joined Nov 2001
Hi to all ,
dear Sander, please let me know other info about the antenna guidance.
Thanks in advance.
massimo is offline Find More Posts by massimo
Old Nov 27, 2008, 11:12 AM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
That's impressive.
I don't have a laptop, is it possible to use the antenna alone?
does it have a video output so we will see directly the analogue video, or the video must pass first in the computer and we plug the goggle in the video card of the computer?
VRflyer is offline Find More Posts by VRflyer
Old Nov 27, 2008, 11:26 AM
AnthonyRC is offline
Find More Posts by AnthonyRC
AnthonyRC's Avatar
Switzerland
Joined Sep 2004
Originally Posted by VRflyer
That's impressive.
No PC required for the antenna, the hardware decoder just requires power, and a link to the receiver.
AnthonyRC is offline Find More Posts by AnthonyRC
Old Nov 27, 2008, 11:29 AM
Funjet2008 is offline
Find More Posts by Funjet2008
plus vite plus loins
Funjet2008's Avatar
Canada, QC, Trois-Rivières
Joined Jun 2008
I want one now...
Funjet2008 is offline Find More Posts by Funjet2008
Old Nov 27, 2008, 12:09 PM
pratorian is offline
Find More Posts by pratorian
No guts no glory
pratorian's Avatar
Quebec, Canada
Joined Sep 2007
Originally Posted by Funjet2008
I want one now...
me too
pratorian is offline Find More Posts by pratorian
ssassen is offline
Joined Jul 2004
The GPS data is used for calculating speed, hence ground speed.
Cheers,
Sander.
Old Nov 27, 2008, 12:15 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Would I need to buy a recent laptop if I want to use one?
If not, what would be the minimum requirement in the laptop would I need to buy?
