Old Nov 26, 2008, 10:02 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Build Log
Superslo28" Build,Tip,Tricks thread!
Ok everyone I'm building the Superslo28 by sloper steve this was a plane that I was told about that used to be found on Steves Website.
Sloper Steve was the first Guy Using EPP for planes and I want to say started the trend for a different kind of foam in the hobby.
Sdparkflyers.com page This build starts after you have printed and cutout all the Epp foam parts
Ok so the first thing that you will need to do is Download the free plans for the Superslo28.
The free plans can be found on my website at http://www.sdparkflyers.com or in the photos below.
You will need to print the plans out on 8 1/2 x 11 sheet paper
The Foam used to build the plane is 1.3# 9mm EPP foam
a sheet 18 x 36 is required to build the kit If you need help finding EPP foam PM me...
For people wanting a complete list of parts for the build here is a updated list of parts from my friends at Hobby King
These are many of the items I use on my planes..
Motor
Stick mount
10amp esc
5g Servo for the Elevator and Rudder
9g servo Ailerons
Props 9050 type
Prop saver
7.4volt 350mah batteries
Hardware
Control Horns
tape for hinges
I do offer EPP Plane Kits from time to time PM if interested.. or send me a email.
Kits cost $40
$ contact me for ordering USA Delivery Only tallguysd@gmail.com
Shipping is about $13-15 for all items.
OK so in the pictures below I have cut out all the parts The next step I do is cut all the 45 angles on the Ailerons/Elevators and the rudder.
Then I make sure that on the wing section I want the 45 cuts on the top side of the wing so I flip the wing over and mark 2 1/4 inch down from the front tip of each wing lay out a piece of 3mm carbon and make a couple marks for a center line.
I then use my dremel to cut the slot. (this is my favorite method fast and clean)
after I cut the slot I test fit the carbon and cut to length. I don't glue the carbon until all the slots have been done this way I can do it all at once, I use Foam tac glue to build all my kits.
I then tape all the parts of the wing together and set it aside and move onto cutting the Elevator and rudder parts.
I repeat the carbon process on the elevator and set it aside
the last part I cut is the Fuselage I use a pieces of scrape foam to make sure the thickness of the wing slot and elevator are the same thickness of the foam. makes for a perfect fit.
I then repeat the Carbon process again for the Fuselage (I use 3mm for all the carbon parts) on the fuselage you can put it on either side.
NEW 7/12/2016
I have a few Kits as seen in this video Cost per kits are $40.00 plus $9.99shipping USPS (USA Only )
Superslo28 Kits whats in the box (product review) (2 min 25 sec)
For those of you looking on amazon for required hardware)
Du-Bro EZ Connectors (2) sets required http://amzn.to/2anvgSL
Du-Bro Micro Pushrod Set (1) required http://amzn.to/2aBvR
Du-Bro Control Horns (2) sets required http://amzn.to/2aowq3O
Du-Bro EZ Links (1) set required http://amzn.to/2aBwi0k
1/16” plywood for control horns (1) sheet required http://amzn.to/2aqLw9r
9050 props http://amzn.to/2aeoVcG
1300kv brushless motor http://amzn.to/2anyCoE
12 amp esc (1) http://amzn.to/2ancn8B
just connectors http://amzn.to/2aqN1UY
Prop saver http://amzn.to/2aoy6du
Prop saver rings http://amzn.to/2aqNwyv
2.0mm bullet connectors http://amzn.to/2aslekh
3mm heat shrink http://amzn.to/2aByp4e
5 gram servo (2) Required http://amzn.to/2aoAjFN
9gram servo (1) required http://amzn.to/2aeqjw1
__________________________________________________ ___________
tallflyer is offline Find More Posts by tallflyer
Old Nov 26, 2008, 10:11 PM
willhaney is offline
Find More Posts by willhaney
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
Great shots and build. How does it fly?
Will
willhaney is offline Find More Posts by willhaney
Old Nov 26, 2008, 11:21 PM
tallflyer's Avatar
Joined Jul 2002
Hd Video baby
New Slofly Superslo28 HD Movie (4 min 20 sec)
Slofly SuperSlo28 flying part 2 (5 min 48 sec)
A new Video
Taranis Plus Mixing test on my Superslo28 (2 min 36 sec)
Old Nov 26, 2008, 11:47 PM
tallflyer's Avatar
Joined Jul 2002
some pictures from the video
Here are some HD Stills
Latest blog entry: Yunnec Typhoon H Review
Old Nov 27, 2008, 10:10 AM
tallflyer's Avatar
Joined Jul 2002
Rain Flying
Here are some video still of me hovering in the rain.
Old Nov 27, 2008, 03:59 PM
rpavich is offline
Find More Posts by rpavich
Bridgeport, WV
Joined Jun 2002
Tallflyer...
Rain in San Diego?? Somebody alert the media!
I like the Superslo's, I've tried to make 2 now and they were cool, but just didn't fly correctly...I did something wrong...
Are there any "precut kits" of these babies that I could just plug my servo's, esc, motor, and battery into and fly?
bob
rpavich is offline Find More Posts by rpavich
Old Nov 27, 2008, 07:35 PM
tallflyer's Avatar
Joined Jul 2002
yeah the news crew was watching me fly on there way to the local best Buy Store to shoot video of people camping in the Parking lot for the Black friday sale. watch he video
I had to move around as I was getting rained on and I took a rain drop to my eye glasses
enjoy the Video.
I hope Everyone had a great Thanks Giving
Hovering in the Rain (3 min 33 sec)
Old Dec 01, 2008, 08:06 AM
IFO FLYER is offline
Find More Posts by IFO FLYER
IFO FLYER's Avatar
Joined Mar 2004
Do I have to put the carbon rod in the wing. Can I just glue it to the surface?
IFO FLYER is offline Find More Posts by IFO FLYER
Old Dec 01, 2008, 08:18 AM
tallflyer's Avatar
Joined Jul 2002
carbon?
You could attach the carbon to the side but for extra strength if you cut foam with a soldering iron or some people use a mini saw blade to cut a grove i use my Dremel and then use a thin coat of epoxy to install the carbon its rocks solid.
Old Dec 02, 2008, 01:36 AM
tallflyer's Avatar
Joined Jul 2002
I thought I would post a complete kit list!
Complete kit parts list.
1. sheet 18 x 36 1.3# 9mm epp white foam
2. 2- 40" x 3mm carbon rods or tubes
3. 3- 5 gram servos
1. 1300-1500kv motor
1. GWS9050 prop
1. prop saver + bands
1 set Dubro micro pushrods (20-30") version
1. motor mount
2 sets micro control horns
1. sheet of light ply 16th inch thick
1 roll strapping tape
1.10 amp brushless esc
1. box #11 x-acto blades
1. medal straight edge (18-24 inch)
sharpie pens for color
Foam tac glue or
battery used is 7.4 volt 2 cell 250-400 mah (30C) is what I use.
1 small 4 channel receiver
1 transmitter. I'm a fan of the Spektrum Dx7s
1 lipo charger
Old Dec 10, 2008, 04:13 PM
tallflyer's Avatar
Joined Jul 2002
video series
New Video Series how to build a EPP type foam airplane.
Plane being built is the Slofly Superslo28
these tips and tricks can be used to build most plans that start using a PDF type file.
Part 1 how to cut a template.
How to build a EPP foam plane part 1 (1 min 30 sec)
Part 2 how to cut foam pieces.
How to cut foam parts for your EPP plane kit. (2 min 2 sec)
in part 2 you don't have to trace the part if you just use the template like I do I just like to trace it out to make sure I don't move the template around when cutting.
Part 3 how to cut a 45 and how to make hinges with strapping tape.
Howto cut a 45 and make a hinge (4 min 27 sec)
Part 4 how to install micro control horns
How-to install a micro Control horn (3 min 52 sec)
Part 5 How to install a motor mount
How-to install a motor Mount (3 min 30 sec)
Part 6. How to Hot wire a 45 cut
how to cut a 45 using a Hand held hot wire cutting tool (3 min 4 sec)
part7 how to dremel cut a wing slot
How to Dremel a Carbon slot in EPP foam (5 min 6 sec)
Part 8 How to Epoxy a carbon rod.
How to epoxy a Carbon wing spar video (6 min 8 sec)
Ok know we all do this different but after hours of research and some trial and error this is the best basic method I came up with.
How To Make a Carbon Control Rod (4 min 52 sec)
Enjoy
(warning you will see in the video I use a heat gun there are people out there that use a lighter to shrink the tubing. CA glue will cause a fire) DO NOT USE A LIGHTER in my method.
My method while it uses heat its not a flame. (FLAME WILL CAUSE FIRE)
Hey 2 new videos
What I use to glue EPP video and weight.
http://www.youtube.com/watch?v=Zr-JR9uCqOg
How to balance a Plastic prop and why!
How to balance a plastic Prop (3 min 44 sec)
How to balance a Prop Using the Dubro Tru-Spin Balancer
Du-Bro Tru-Spin Prop Balance Quick Tip Guide -TALLGUYSD (2 min 8 sec)
Items I use and other stuff part 1
Motors Mounts prop savers & More part 1 (4 min 8 sec)
Items I use and other stuff part 2
Motors Mounts prop savers & More part 2 (4 min 10 sec)
How I shoot all my Own inflight videos
How to shoot your Own Flying Videos (2 min 57 sec)
New Cutting a groove with a Soldering iron!
Cutting a groove with a Soldering iron. (3 min 10 sec)
How to glue the wings in place
How to Glue a EPP Wing (5 min 14 sec)
How to install Servos and the Stick Mount) 2013
How to install Stick Mounts and Servos (5 min 35 sec)
Old Dec 10, 2008, 07:45 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Great stuff tallflyer
bildo baggins is offline Find More Posts by bildo baggins
Old Dec 10, 2008, 07:49 PM
tallflyer's Avatar
Joined Jul 2002
I know other videos have been made but I thought I would get in and show little stuff that people are always asking questions about. just to make what we talk about better understood.
Old Dec 10, 2008, 08:56 PM
LANMAN is offline
Find More Posts by LANMAN
Palm Harbor , FL
Joined Jan 2005
is there a PDF of this plane. looks great and your instuctions are fantastic.
LANMAN is offline Find More Posts by LANMAN
Video Slofly28 Superslo tallflyer Electric Plane Talk 2 Nov 15, 2008 10:01 AM
Sold Slofly28" Superslo kit tallflyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2008 10:33 AM
Sold 1 Slofly 28 SuperSlo kit, 1 Slofly 28 Acro, 3 GWS Pico servos - $45.00 shawn595 Aircraft - Electric - Airplanes (FS/W) 6 Jul 25, 2008 12:26 PM
