Old Feb 26, 2003, 06:41 PM
windsong is offline
Find More Posts by windsong
windsong's Avatar
United States, CA, San Diego
Joined Feb 2003
optimum power system for KA Models L-39
Would like your opinions on best power system for the L39 when measured by mph/cost.
windsong is offline Find More Posts by windsong
Old Feb 26, 2003, 07:39 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
You might want to look at the L-39 video to see what kind of speed & power you are aiming at...
Steve's L-39: http://aeneas.ps.uci.edu/edf/mirrors/l-39_k&a.wmv
and do a search under L-39:
http://www.rcgroups.com/forums/searc...der=descending
In general it's a low drag airframe which will fly fast on relatively low power. It's also a light fuse which won't tolerate a lot of batteries.
The Kyosho AP-29L in the MF480 costs $30 and gives 60 mph or so, so the ratio is about 2. If you go with a Hacker B40 S or Kontronic Fun 400 or Mega 15/16/2 the ratio becomes 80/200 = 0.4 or so (If you keep it hanging in the garage you get 0/0 which is indeterminate ).
Herb is offline Find More Posts by Herb
Old Feb 26, 2003, 09:29 PM
DeanW is offline
Find More Posts by DeanW
Tasmanian Tiger
DeanW's Avatar
Hobart, Tasmania, Australia
Joined Aug 2000
I considered using a brushed motor in my L39 until I saw that the fan in glued into the ducting and the bottom of the fuselage is sealed up. Basically it would have been a big pain to open it all up to check/replace brushes IMO. I went with the fairly cheap brushless combo of a Mega 22-20-2, Jeti 40A BEC ESC and a HW609 fan. I get pretty good speed and about 4 minutes of flight on 10 FAUP cells. I agree with Herb it is a low drag airframe and I can fly just fine on half throttle.
Cheers
Dean
DeanW is offline Find More Posts by DeanW
Old Feb 27, 2003, 07:39 AM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
What do you really want mph or cost? If you just divide raw mph by cost, I would guess you would end up with a kyosho fan or mf480 with apl29.
I wouldn't do this however. Because of the way the fan is mounted it is a pain to do any work on the motor, so I would go brushless as a minimum.
Not sure what Herb counts as lots cells, but I have 14 1250scr in mine and I think 16 would be no problem. If you want to step out onto the bleeding edge I think you could get acceptable performance on Li-poly and really long flights.
ScottS is offline Find More Posts by ScottS
Old Feb 27, 2003, 09:27 AM
Olivier is offline
Find More Posts by Olivier
Addicted member
Olivier's Avatar
France, RA, Yvoire
Joined Apr 2002
Hi all,
just a general question:
normal or enlarged wings on your model ?
Is there a big diffrence in flight ?
Thank's
Olivier
Olivier is offline Find More Posts by Olivier
Old Feb 27, 2003, 09:31 AM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Originally posted by Olivier
Hi all,
Thank's
Olivier
the scale wing flys very well. ............gregg
gregg f is offline Find More Posts by gregg f
Old Feb 27, 2003, 02:07 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Normal or enlarged wings on your model ? Olivier
To me the enlarged wing looks odd. Don't even understand the motivation behind it ... I would go with the scale wing, it flies just fine as gregg says. Just don't overload it with batteries, 10 CP 1700 would seem a sensible choice.
Old Feb 27, 2003, 02:11 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Steve's very nice L-39:
Old Feb 27, 2003, 09:59 PM
windsong is offline
windsong's Avatar
Joined Feb 2003
Gentlemen,
Thanks very much for your advice. I do have the enlarged wings, guess I was concerned with wing loading and figured I could but and build the scale wing later if I wanted.
Old Feb 27, 2003, 10:57 PM
ScottS is offline
ScottS's Avatar
Houston,TX
Joined Mar 2000
The sport wing is noticeably not scale, but flies fine.
Old Feb 28, 2003, 02:18 AM
Olivier is offline
Addicted member
Olivier's Avatar
France, RA, Yvoire
Joined Apr 2002
Thank's for your answers,
It looks like the scale wing is the choice
Olivier
Old Feb 28, 2003, 02:32 AM
U812 is offline
Find More Posts by U812
Joined Sep 2002
In the flight video Herb posted of my L-39, I was having trouble with the motor.
I was not at full throttle and you can see clearly how well it flies with the scale wing at slow speeds.
I think the large wing is for PSS.
You've made the only choice.
My AUW is 42 oz.
Good luck with it!
Steve
U812 is offline Find More Posts by U812
Old Mar 01, 2003, 10:40 AM
GregG is online now
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
What does everyone here think about this model in terms of high performance? Is this the closest someone can get to the El Bandido for sleekness and low drag in a fiberglass kit already in production? What other jet is this low drag? How does this compare with thier MIG kit in terms of drag. What would you choose as a performance jet scale or not?
GregG is online now Find More Posts by GregG
Old Mar 01, 2003, 11:20 AM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
between the two kits, i'd expect equal performance with the same set up. i haven't seen an L39 with 600w, but it should go 100+ like the mig.
now the el bandito, that's a ferrari in terms of performance and kit quality. although at a much higher cost, around $1500 nicely equipped. about 30% larger too..................gregg
Mark is offline
Find More Posts by Mark
My dremel tool has no fear
Mark's Avatar
Reston, VA
Joined Dec 1999
I built one a couple of years ago with the scale wing. It flew very fast considering the relatively low power (about 360 watts). I am building number two now. I ordered it with the long wing but I cut it down to 38". With this I will get a little less taper to the wing and along with the longer span (scale wing is 35) more wing area. The scale wing has only about 220 sq/in of area and if your going to load up on batteries and power that wing loading is going to be very high (in the mid 30's). My modified wing will give me about 250sq/in. and I feel this enough of a difference to carry more battery weight.
The mig has about 300 sq's and so guys have able to load it up with a lot of cells, I think Steve used 16-20! The mig has a very efficient straight through intake but also has a thicker airfoil and I think more overall drag than the L-39
So my L-39 number two will have 600-700 watts pumping throught a minfan with the exhaust necked down to 54-55mm and I will post a report when I test it
here is a picture of my original L-39, unfortunately a locked up aileron servo sealed its fate
Mark is offline Find More Posts by Mark
Question Good power system for AK Models Spit? desmobob Power Systems 0 Mar 20, 2006 06:09 PM
Sold PSS NIB KA models L-39 ALBATROS Louied Aircraft - Sailplanes (FS/W) 3 Aug 20, 2005 09:55 PM
Question Power System for World Models P-51D (57 inch wing span) @ 6 lbs. guapoman2000 Power Systems 2 Jan 24, 2005 04:09 PM
power system for CA Models Epsilon lagcisco 3D Flying 2 Apr 06, 2004 07:02 PM
which power system for Mountain Models Tantrum? flybike Power Systems 12 Jun 29, 2003 08:51 PM
