Old Nov 29, 2008, 02:30 AM
MattZC is offline
Find More Posts by MattZC
I just love flying
MattZC's Avatar
Traverse City ,MI
Joined Dec 2005
Subscribed.
MattZC is offline Find More Posts by MattZC
Old Nov 29, 2008, 02:35 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Rudder control horn installation.
Remove the covering (I use soldering iron for this to prevent scoring the balsa)
Glue (with gorilla glue) and align properly. Note that properly aligned, the holes should match up. You can run a ruler and it'll match up. That ensures equal throws.
BoneDoc is offline Find More Posts by BoneDoc
Old Nov 29, 2008, 02:38 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
More horn installation:
On the elevator and ailerons, you'll have to trim the control horn to use the first hole. I use either a Dremmel or pliers / nail clipper and sandpaper.
Old Nov 29, 2008, 02:41 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
4" CF Spinner available from 3DH to complete your model. Pretty freakin' cool!
Old Nov 29, 2008, 02:44 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
I use an old soldering iron to remove the covering. It makes for clean and neat install in the process.
Old Nov 29, 2008, 02:48 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Threading the servo extension through. The string included in the kit really helps and cuts down on the frustration of trying to thread the wire through all the ribs on the wing.
I predrill my servo holes with the smallest drill bit I have. It's a habit carried over from the OR .
Old Nov 29, 2008, 02:54 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
LG / Wheel Install
Note the notch on the wheel pants. It makes lining up the WP a breeze, just like installing them on the smaller models.
Tighten the collar as pictured, and then install the whole thing to the LG (just like how you'd do it with the 47" or 55" planes.
Old Nov 29, 2008, 02:56 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
This is how I tighten the screw and nut together on the LG plate.
My lovely assistant helping here . Please note how tall the LG is on the 89" Slick
Old Nov 29, 2008, 03:00 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Cannister tunnel
Note the 4 holes at the bottom of the motor box. I eventually connected those with a Dremmel to turn it into a cooling hole.
Old Nov 29, 2008, 03:03 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
GR 70 Installation
Installing the GR 70 on the Slick is a breeze. Scott has a mounting plate that templates with the DA50 template. So all you have to do is line up the DA drilling template, drill the 4 holes, and that's IT!
As for installing it, I first loosely install all of the standoff, then tighten them sequentially.
Old Nov 29, 2008, 03:06 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
I also sheeted the battery tray as to make the flow more laminar there and ensure that all the air goes through the battery. So far it's kept my batt cool and very happy.
Old Nov 29, 2008, 03:09 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Cooling slots
In addition to the hole in the bottom, I also glued a scoop together.
Before and after pics.
Old Nov 29, 2008, 03:10 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
I blazed through the radio install, so I didn't shoot any pics, but they're rather identical to the 87" SHP's install since both use the same hardware.
Old Nov 29, 2008, 03:15 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Here's the finished product. In case you guys ever wonder who "Josie & Gracie" are... they're modeling the planes here .
Old Nov 29, 2008, 03:19 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
All boxed up and ready to go.
Also the hover shot action with the noggin cam upfront.
Article 3D Hobby Shop's 51" AJ Slick ARF Review sun.flyer 3D Flying 122 Jan 23, 2010 07:15 AM
Video 3D Hobby Shop 51" AJ Slick: sun.flyer Electric Plane Talk 2 Sep 27, 2008 08:51 AM
Video 3D Hobby Shop 51" AJ Slick: sun.flyer Electric Plane Talk 6 May 30, 2008 08:01 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
