Go Back   RC Groups > Aircraft - Exotic and Special Interest > VTOLs
Old Jun 26, 2009, 09:52 PM   #31
under construction
SilentHunter's Avatar
I gearing back up to start continuing work on the Pogo.
I need a machine shop to make the special shaft for the motors, anyone know of a good reliable one who doesent charge a fortune that you can recommend? it's a simple deal stepped shaft, 10mm x 5" long SS shaft turned to 6 mm in the center, so half is 10 mm and the other 6mm.
Also, I was planning on using the Zinger 3 blade systems for the props, but they are REALLY heavy built! i need 19-22" 3 blades.
They certainly dont have to be built as beefy as the Zinger hubs, since I estimate they will only turn in the 3500 rpm range..I guess i have to make my own hubs and use the zinger blades.
Any ideas on this stuff?
Im was also thinking of a sliding battery "trolley", that can make the CG extreme aft for hovering ease, then slide forward for forward flight...
SilentHunter is offline Find More Posts by SilentHunter   Reply With Quote
Old Jun 26, 2009, 10:58 PM   #32
under construction
Holy smokes, Himaxx got all the CR motors in stock and shipping!
http://www.maxxprod.com/mpi/mpi-266.html
I just emailed them, to see if the 50mm CR motors can deal with 20"x6 props.
The 50mm would be more practical, and if can turn a large low pitch prop then my problems are over, at least in that department
I think maybe the 63mm series, like i was going to make with the two motors I bought, is overkill in power... I knew that, but not enough power in a vtol is bad.
We'll see, what u think?
Old Jun 29, 2009, 08:13 AM   #33
lphan's Avatar
SilentHunter,
I just saw this thread. Very impressing plug and fuselage ! I like the rivets.
Keep up the great work ! I actually tried a simulator of the Pogo at my hobby shop on Saturday. The thing that I was not used to is the hovering part where I had to use down stick to move the plane forward.
Cheers,
Le
lphan is offline Find More Posts by lphan   Reply With Quote
Old Jun 30, 2009, 02:48 AM   #34
under construction
Hey thanks man
I hope i can get the time to do more work on it in the next few weeks.
it needs a variable CG, and gyros.
Old Jun 30, 2009, 02:49 AM   #35
Team EJF Team Hacker
bruff's Avatar
Send a message via MSN to bruff Send a message via Yahoo to bruff
Any chance of getting a fuselage?
Bob
bruff is online now Find More Posts by bruff   Reply With Quote
Old Jul 01, 2009, 09:16 AM   #36
That will not work as you think. Shifting the CG backward might help in the transition, since it will allow you to pitch up over the stall with greater ease. However, once in the hover if your CG is too close to the control surfaces you will not have enough control authority. The pendulum effect, as we have discussed several times, is an illusion (the plane does not "hang" from the prop), but the moment arm between the control surfaces and the CG is not.
Brandano is offline Find More Posts by Brandano   Reply With Quote
Old Jul 01, 2009, 01:07 PM   #37
If this THING can fly (not too bad I.M.H.O):
http://www.rcgroups.com/forums/showthread.php?t=449262
.........I suppose that your bigger POGO can fly too.
Just keep the weight as low as possible and go with a lot of WATTS
And the "sliding" battery for C.O.G. correction is a great idea.
Keep on going with this project....you're my hero!
ettore
quenda is offline Find More Posts by quenda   Reply With Quote
Old Jul 01, 2009, 09:20 PM   #38
under construction
Bob,
I have to mold it first, when I do I'll let you know and you can get one. You want to try and make a flying one? Display?
It is meant for dual purpose, display and or flying
brandano that is correct. I was not thinking of moving it that drastically. But too tail heavy for forward flight would help I think in hovering... to what extent is unknown, as with a lot of thing on this model right now
We'll find out.
Old Jul 01, 2009, 09:22 PM   #39
under construction
Thank you Ettore.
Old Jul 05, 2009, 01:00 PM   #40
1.21 gigawatts
EDDIEGIGOWATTS's Avatar
SilentHunter
hope this helps
here is a pic of a better set up ,
you can keep the shaft the same diameter
a simple spacer with bearings bolted to the front of the bell
think by reducing the shaft your going to have complications
  • Name: part2 crt motor spacer.jpg
  • Name: part2.jpg
EDDIEGIGOWATTS is offline Find More Posts by EDDIEGIGOWATTS   Reply With Quote
Old Jul 09, 2009, 06:58 PM   #41
under construction
Thanks Eddie, yep thats a good idea. I do like it better than my own, but that bearing housing is harder to machine than a simple stepped shaft. But fortunately....
Himax is actually selling their bigger CR setups, I wont be needing to make anything but the spinner, which is a big enough problem.
Old Oct 07, 2009, 11:53 PM   #42
Send a message via ICQ to degreen60 Send a message via Yahoo to degreen60
I just found this thread and thought you might like to see these pictures I took in 1961. I thought some day I might try making a flying model.
  • Name: Scan181.jpg
  • Name: Scan182.jpg
  • Name: Scan185.jpg
degreen60 is offline Find More Posts by degreen60   Reply With Quote
Old Oct 17, 2009, 05:49 PM   #43
100mph club member
turbodriven's Avatar
Mines not as pretty as yours... and it's not contra-rotating (yet) but it does fly. I'm working on the landings still though
IMGP2739 (1 min 12 sec)
  • Name: pogo311.jpg
  • Name: pogo12.jpg
  • Name: pogo13.jpg
  • Name: pogo14.jpg
  • Name: pogo15.jpg
turbodriven is offline Find More Posts by turbodriven   Reply With Quote
Old Oct 17, 2009, 06:50 PM   #44
1.21 gigawatts
waaay toooo cooolll
Turbodriven very nice
there is plenty of CTR motors out there for that size Pogo
Eddie
Old Oct 18, 2009, 06:34 PM   #45
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
Originally Posted by EDDIEGIGOWATTS
SilentHunter
hope this helps
Hi Eddie
I can vouch for that set up, but if you have the space fit the adapter from the rear, with the bearing as close to the windings as possible. This helps to reduce the length of the shaft and the amount of movement (slop) on the aft edge on the outrunner, and the danger of it hitting the stator. Caused by the flex in the shaft & float in the bearings.
click link to see some picture of how I did it
RC Groups contra rotating prop brushless
As for a spinners, the easiest & quickest way I've found is to carve them from blue foam, with ply mounting plates and then add a small vac formed plastic spinner at the front, or top in your case
I'm looking forward to seeing the finished article
  • Name: 1689s.jpg
Description: Martin Baker MB5 1/8 scale.
http://roys-rc-tv.webs.com/ Martin Baker MB5 1/8 scale. http://roys-rc-tv.webs.com/ 60.7 KB · Views: 47
Basingstoke Roy is offline Find More Posts by Basingstoke Roy   Reply With Quote
Convair Pogo indoorff 3D Flying 5 Sep 28, 2004 11:40 AM
Convair Pogo Ed Couch Parkflyers 7 Nov 16, 2003 11:26 PM
Bored? Want to fight?
Join the RCGroups clan!
