| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 | |
Not completely authentic I hope, since the full scale version was considered a failure by the Navy! http://en.wikipedia.org/wiki/Convair_XFY Axi has this powerplant for C/R props. |
#17 |
Cant wait to see this one go
#18 |
under construction
That motor is not a CR motor, only 2 outrunners together turning the same prop.
Himax was supposed to make a similar sized one as I have, I have yet to see it though it has been under the "to be release whenever category"
#19 | |
AXI 5330/20 Double PM5330D Model Motors AXI Gold "5330/20 Double" OUTRUNNER Motor ..... $ 975.00 AVAILABLE NOW Specs: 55 oz. weight, 2-1/2" diameter case, 5-3/4" combined case length. Motor mount is between the 2 motors (Custom mount must be fabricated for individual airplane by modeler). The two motors come ganged together to drive a single prop. Can also be used to drive 2 propellers in a counter rotating setup. For use with 2x10S Lithium Polymer packs and a 24x10" wood prop. Check out the RCU Review of 5330/20 Double on an Edge 540. Here's a link to several different Himax C/R motors. http://www.maxxprod.com/mpi/mpi-266.html |
#20 | |
#21 | |
Not my opinion, just that of the Navy!
#22 | |
under construction
Yep, it did work, and the difficulty of landing I think would have been overcome with some electronics if the project went further. DT, thanks, thats a little more power than needed, and price too. Thats interesting though, that you can do both with it. It will already be lots of power with the motors I will use, they are equal to .90 or 120 glow each motor
#23 |
I gather that you're settled on your powerplant at the moment, but here's one you may or may not know about, from Vision Hobbies-- http://visionhobbies.com/1637131.html
I've used it in a now defunct scratch build, and loved it, and can't wait to use it again in a new project. There is also a PJS currently in use in a Macchi-Castoldi MC-72 in this build thread: http://www.rcgroups.com/forums/showthread.php?t=934757 |
#24 | |
under construction
#25 |
any updates?
#26 |
If anyone needs a lighter motor that still has some power you might want to consider this motor. I purchased it and will tell you what kind of thrust it has in a week or so.
It uses aluminum windings instead of copper giving it a considerable power to weight ratio. It also has lighter mechanics. Only down side is that it does not have a prop drilling jig. I just remove the bell and use it to mark the wholes and use a drill press. http://www.hobbycity.com/hobbycity/s...idProduct=6565 I was going to make a Coaxial fun fly out of sheets of depron. I started off with a crazy looking design and coincidental as I refined it I ended up with something that more resembles the Pogo. So I decided why be different and I am just making it more like the Pogo. Ill update you as I hope to be done this week. |
#27 |
It's a really big number.
I'm using one of these in something at the moment - very good motors. I'm running 10x6x3 blade props and it handles it just fine with tons of thrust and runs cool enough to touch. Only real problem is the prop shaft up the middle is made from silly putty. It bends if you so much as look at it funny.
#28 |
Good to know going to look for a replacement asap! As I might be relying on this for a competition.
Scott |
#29 |
If you discover what diameter shaft it is let us know - I thought it had a 3.175mm (1/8") shaft, but its really a fraction smaller than that, and 3mm is too small all together
. Mine still runs, but sounds a bit rough as the shaft has been restraightened a few too many times to be happy.
#30 | |
under construction
Will be back when i get something exciting |
| Thread Tools | |
| Convair Pogo | indoorff | 3D Flying | 5 | Sep 28, 2004 11:40 AM |
| Convair Pogo | Ed Couch | Parkflyers | 7 | Nov 16, 2003 11:26 PM |
