Old Nov 25, 2008, 08:38 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
RC Bachem Natter, pusher or rocket powered...
Always wanted to do one of these, now that I figured out how to do the rocket ignition reliably, and have a bunch of E-6 aerotech reloads on the way, and since I made my X-15 electric pusher module and rocket module able to move from model to model, I decided I'd do a natter. I'll do an xform fuse/wing and a full flying tail for simplicity, with a 24mm rocket for vertical launch or pusher. It appears that I might move the wing slightly rearward based on some things I've read and on the three view, might be hard to get the CG right without a lot of extra nose weight, we'll see. I already have the thruster rocket pods built......
Frank
burkefj is offline Find More Posts by burkefj
Old Nov 25, 2008, 10:29 PM
agriebel is offline
Find More Posts by agriebel
agriebel's Avatar
Madison WI
Joined Aug 2003
You never quit do you? I'll be watching!
agriebel is offline Find More Posts by agriebel
Site Sponsor
Old Nov 26, 2008, 12:26 AM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Well, I didn't do anything for 6 months, I figure it was about time
Here are the profiles drawn on depron ready to cut out with the electric pod layed out, with the electronics, I fudged the wing back about an inch, added about 1/2" to the chord and a little to the wingspan so it still looks right, but gives a bit better chance of making cg without adding lead. Looks like it should be very similar to the X-15 in size and area/weight.
Frank
Old Nov 26, 2008, 04:58 AM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
No he doesnt...projects are like bowling pins...line them up and knock them down!!
ATIS is offline Find More Posts by ATIS
Old Nov 26, 2008, 11:11 AM
f86esabre is offline
Find More Posts by f86esabre
I'm just here to fly
f86esabre's Avatar
Sarasota,Florida
Joined Jun 2007
Well, if he build a real one it would take Frank all of a week to complete, to long, so he just keeps building models.
Steve
f86esabre is offline Find More Posts by f86esabre
Old Nov 26, 2008, 11:49 AM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
:>) Well, as I do more, I learn more and discover ways to make things work that I thought were impractical before.. they just kind of fall into place sometimes.
Couldn't sleep, so here's where I'm at, parts are cut and traced for plans, glide tests done, looks like 30% is about right for CG, and I try fit the parts together, it's looking really good so far I think, 30" long and 18.5" wingspan.
Frank
Old Nov 26, 2008, 02:46 PM
f86esabre's Avatar
Sarasota,Florida
Joined Jun 2007
Frank, are the fuselage rockets going to angled out? Also, you'll need to fill the nose up with bottle rockets to make it really realistic.
Steve
Old Nov 26, 2008, 04:03 PM
Draken1 is offline
Find More Posts by Draken1
Joined Dec 2006
Frank
your draken was awsome ,there are plenty of gripens around , what we need is a viggen
John van den Berg
Draken1 is offline Find More Posts by Draken1
Old Nov 26, 2008, 04:56 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Fuse rockets will be angled out but they are just for show and are undersized because the servo to drive each stabilator will be in the way if they were longer. Bottle rockets.......
Frank
Steve
Old Nov 26, 2008, 04:58 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Thanks, I'm bummed that my draken was killed due to a spektrum un-bind in the middle of a split ess(pointed straight down of course) during our RC airshow this summer. My radios are full, but I'll see what I can do with a Viggen in the next month or so....maybe I can design the airframe and you can do a beta build for me, that way I don't have to canibalize one of my other planes??
It only takes me a day or so to draw up plans, usually I've got most of the problems figured out, and can do test glides with a full size foam only shell...
Interested??
Frank
Originally Posted by Draken1
Frank
John van den Berg
Old Nov 27, 2008, 12:25 AM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Here it is almost finished, need to do some touchup painting, and maybe do some more detail, but good enough for a toss tomorrow before I head up to Seattle. Came out at 12 oz with electric, maybe a half ounce less with composite E-6.
Old Nov 27, 2008, 06:09 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
"Hang on to her Newt....she'll only buck for a little while!" Those are the famous words of my sim partner while I trying to handle an engine out.
Site Sponsor
Old Nov 27, 2008, 11:28 AM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Test hop....
Well, I wanted so bad for the CG to be where it was without adding nose weight, that I kind of glossed over a little pitch up tendency in glide tests....
It was one of those handlaunches where it pitched up vertical hung there, and went into a torque roll, fun if you aren't at the controls......I managed to get it down flat on a lucky oscillation. Nose now has more of a wartime finish.
I moved the CG forward 5/8" and it now flies well. Handlaunch at 60% is easy, purple peril has plenty of power. I was worried about the tailerons being above the thrust/wing axis and not having much effect, however they seem fine, it rolls like a madman to the left, but to the right is slower, only issue on a full roll to the right, it gets inverted and slows and kind of gets stuck there, if you are too slow in loops/rolls, it plops back upright, due to the battery on the bottom, I think. Landings with power on are pretty slow and docile, glide isn't floaty, as there is about 1 square foot of wing area or a little more for 13 oz rtf, just keep the nose down to keep speed so you can flare at the end. It looks great in the air.
I'll try a rocket flight on Sunday when I get back, enjoy the holiday everyone.
Frank
Old Nov 30, 2008, 02:11 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Deleted
Old Nov 30, 2008, 02:37 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
A little foggy! Great job, I thought it would be going faster, but you are launching 13oz. You are right, it doesn't glide much at all. Well done. I finally have my APC 7x4 pusher on and now I am just waiting for the weather to cooperate. It's snowing today.
Site Sponsor
Discussion RC pusher and Rocket XF-91 thunderceptor burkefj Rocketry 0 Nov 25, 2008 12:49 PM
21 ft. span B-29 Bomber with RC X-1 Rocket Jeff Meyers Giant Scale Airplanes 11 May 18, 2007 12:18 AM
vertical rc cap or katana hammerhead Foamies (Kits) 1 May 24, 2002 04:19 PM
Geared Race or Rocket 400??? dave_lilley Power Systems 5 Nov 05, 2001 08:05 AM
JATO or rocket booster on EDF?? Tom J. Electric Ducted Fan Jet Talk 4 Oct 23, 2001 04:54 PM
