Old Feb 26, 2003, 02:07 PM
tomx is offline
Find More Posts by tomx
Joined Feb 2003
How to put li-poly battery into GWS Tiger Moth?
Guys,
I just got a 2 cell (K1020 2s) from B-p-p.
I found out that it's not very easy to put
it into my GWS TM's battery compartment.
It looks likt I can either cut the compartment
wider or make it deeper. Which way is better
to go? Thanks in advance.
All the best,
Tom
tomx is offline Find More Posts by tomx
Old Feb 26, 2003, 02:28 PM
Will-MO is offline
Find More Posts by Will-MO
Will-MO's Avatar
St. Louis, MO
Joined Jan 2003
I cut the compartment a bit wider. Also, I removed some material under the bamboo dowel. My battery is mainly in the battery compartment, but some of it enters under the landing gear opening. A bit ov velcro insures it remains in place. The cowl covers up some of the batt. too. You can cut away some of the cowling or do what I did and attach the cowling with magnets. ( Velco would work too). Make for easy battery removal.
Will
Will-MO is offline Find More Posts by Will-MO
Old Feb 26, 2003, 03:45 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
I punched a hole up into the front cockpit and put the ESC battery connector through it. My Li-Po's are velcroed into the front seat!
Darren Hintze is offline Find More Posts by Darren Hintze
Old Feb 26, 2003, 05:42 PM
tomx is offline
Joined Feb 2003
Thanks for the replies.
I'll try Will's suggestion first. If it doesn't work
for me, Melfsmite's idea is very brilliant to me.
All the best,
Tom
Old Feb 26, 2003, 06:33 PM
chargin is offline
Find More Posts by chargin
Adelaide South Australia
Joined Jan 2002
Gee melfsmite how do you get your CG right with the batts so far back? Did you build with that in mind so your sevos, rx etc are far forward?
chargin is offline Find More Posts by chargin
Old Feb 26, 2003, 06:42 PM
Ostrich is offline
Find More Posts by Ostrich
Encinitas, CA
Joined Jun 2002
I'm not sure how to post a link in a reply, but search the Parkflyer forum for the following thread:
"GWS Tiger Moth Li_Po Photos please"
There are several very detailed photos of where to place the batteries. I just installed my batteries last night and opted for the method of making the battery compartment a little wider and carving a slot the size of the battery pack through the nose above the motor wire tunnel. Pictures speak a thousand words, so try to find the thread I referenced.
Ostrich is offline Find More Posts by Ostrich
Old Feb 26, 2003, 08:13 PM
tomx is offline
Joined Feb 2003
Ostrich,
I found the post. The photos are really helpful.
I really appreciate your help!
All the best,
Tom
Discussion Best li poly for my GWS 400, Tiger Moth Sgt Rock Foamies (Kits) 0 Jun 29, 2006 12:44 AM
Tiger Moth Li-Poly battery ROG question yesbee1 Parkflyers 27 Feb 09, 2004 06:46 PM
GWS Tiger Moth Question - Battery Access? mrebman Parkflyers 25 Jul 06, 2001 09:23 AM
GWS Tiger Moth - How slow does it fly? mrebman Parkflyers 2 Jun 29, 2001 01:27 AM
