Old Nov 29, 2008, 06:02 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Great info! All these tests are being done with EPP1045's that have been balanced I presume? There is enough varibility in prop balance to skew the results.
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Nov 29, 2008, 09:12 AM
brashley is offline
Find More Posts by brashley
brashley's Avatar
Joined Dec 2006
Funny, I use am Mdrive for my motor testing as well. I like the serial PC control and the RPM readout you get. I love the thing, I have a couple of them in my park flyers as well. I have done a fair amount of motor testing with it on my little setup. It would be great to give this one a try once it is done and compare the results. Your data is looking good...
It will be interesting to see the impact the breaking will have of the MK control and flight characteristics. I bet we will have to retune the MK PID control to get maximum benefit out of it (beyond just efficiency gains)
Richard
brashley is offline Find More Posts by brashley
Old Nov 29, 2008, 10:08 AM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
I had never even heard of the Mdrive, but it sure looks like a nifty little ESC. It's a real shame they don't include I2C interface capability. I may send them an email and ask if they've considered adding that capability.
Cheers,
Rusty (elaborate Rev2 test rig nearly ready for use)
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Nov 29, 2008, 11:49 AM
airbotix is offline
Find More Posts by airbotix
Meopham, Kent UK
Joined Jul 2008
Cheers,
Jim
Yes props fairly balanced - same specimen used for both controller tests.
I recall the Mdrive was a little slow dynamically driven by PPM signal for quadrotor flight use, but yes a nice product.
Richard - I agree the PID loops will likely need retuning, probably the differential terms will be most affected. We use our own design of flight computer, and will learn in due course to give some pointers.
Will update when we have some new data.
So if everybody prefers a standard format controller is the LED function still of interest? the options are open collector ports 3 or 4 off - the user sets the current limit externally with a resistor. We provide simply I2C addressable switches, pwm'd to achieve a brightness or flashing.
We also have 1A 5V switching regulator on board. Is that totally necessary - currently used for LED's?
Steve
airbotix is offline Find More Posts by airbotix
Old Nov 29, 2008, 11:56 AM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Hi Steve,
My vote would be no LED's, and no 5V supply.
Rusty
Site Sponsor
Old Nov 29, 2008, 04:27 PM
brashley is offline
brashley's Avatar
Joined Dec 2006
I would agree with Rusty (especially if it keeps the price down)
Richard
Old Nov 29, 2008, 05:52 PM
Maxrr is offline
Find More Posts by Maxrr
Sydney, Australia
Joined Jul 2008
Me too!
keeping it small, lower cost, simple pcb layout is the way to go.
max
Maxrr is offline Find More Posts by Maxrr
Old Nov 29, 2008, 05:56 PM
jesolins is offline
Joined Feb 2007
I agree. Keep the ESC minimum and robust. There are plenty of LED options out there and they are simple to do if you want to.
Cheers,
Jim
Originally Posted by Maxrr
Me too!
max
Old Dec 05, 2008, 07:56 PM
Fredjikrang is offline
Find More Posts by Fredjikrang
Fredjikrang's Avatar
Joined Oct 2008
Any news on this?
Fredjikrang is offline Find More Posts by Fredjikrang
Old Dec 05, 2008, 08:21 PM
airbotix is offline
Meopham, Kent UK
Joined Jul 2008
Originally Posted by Fredjikrang
Any news on this?
Sorry nothing else to say at moment, but working hard on it!
Steve
Old Jan 31, 2009, 09:06 PM
brashley is offline
brashley's Avatar
Joined Dec 2006
How is it going???? Any progress....
Old May 16, 2009, 03:29 PM
autobotix is offline
Find More Posts by autobotix
Canada, ON, Toronto
any word
Looks like a great project, but looks like it went over the cliff ---- crash!
hope not, had great possibilities
autobotix is offline Find More Posts by autobotix
Old May 18, 2009, 11:42 AM
airbotix is offline
Meopham, Kent UK
Joined Jul 2008
Sorry for a long awaited update.
We have woking samples but I am afraid it will have to stay at that for the moment. Basically we are too busy on our micro quadrotor development, and the payback for doing motor controllers requires high volume to keep the pricing appropriate.
During development of the motor controller we have found I2C is not totally reliable - partly due to our chosen processor. We prefer, and have implemented a simple PWM command method still giving 1kHz update rate.
A 1kHz PWM control signal effectively commands thrust proportional to pulsewidth. In this way no I2C interface latch-ups can occur.
We will of course make it known if the position changes.
Steve
Old May 18, 2009, 05:11 PM
Canada, ON, Toronto
Could you expand on the issie with I2c and your chasen processor.
Maybe some of us could help resolve your issue.
I am sure we would be interested in your finding at the least
Thanks in advance
Paul
Steve
Old May 19, 2009, 02:31 PM
airbotix is offline
Meopham, Kent UK
Joined Jul 2008
Paul
The processor we used was Luminary Micro LM3S811 - a fairly good and flexible processor but it seems some weakness in I2C. The issue is an infrequent I2C bus hang - likely due to noise, slave wont realease back to master. Some software can sort of correct issue, but to be honest I2C is a bit pony. Common earth for I2C and power doesn't help. It probably doesn't have a schmitt trigger front end.
The PWM sensing solution is totally robust but non-standard to requirements.
Today we use that solution to good effect.
Steve
Jeti brushless controller... HELP!!! Dan Chase Power Systems 6 Oct 14, 2003 11:16 AM
Jeti 70 amp brushless controller on 18 cells-- no problem Andreas Power Systems 12 Sep 25, 2001 09:58 AM
Aveox L160 Brushless Controller Steven Horney Aircraft - Electric - Airplanes (FS/W) 4 Sep 17, 2001 06:13 PM
pic based brushless controller fisher Power Systems 1 May 28, 2001 10:39 AM
Kontronik Brushless controller modes (3 or 4)? ShakyHands Electric Heli Talk 0 May 25, 2001 07:40 PM
