Old Nov 26, 2008, 08:59 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Steve,
We picked up on the dynamic braking characteristics straight away You are shack-on with that! That seems to be an area that needs implementation for further development in the PID for quad control. It could possible enable the use of more efficient and wider range of prop designs as well.Cheers,
Jim
Originally Posted by airbotix
To answer Rusty Simon and Jim. Will concentrate on that probably with LED drive connections external.
Just to point out this is not a re-packaged standard off the shelf Atmel 8MHz P-type and N-type FET design from my friend Feng above. It has dynamic braking aiming to allow prop spool up and down equally fast, internal PID, synchronous rectification for higher overall drive efficiency. The 20V S08 FET's used are rated somewhere around 19A but we conservatively rate the controller at 11A.
Steve
jesolins is offline Find More Posts by jesolins
Old Nov 26, 2008, 09:11 AM
airbotix is offline
Find More Posts by airbotix
Meopham, Kent UK
Joined Jul 2008
Originally Posted by jesolins
Steve,
Jim
Sorry Jim, I just thought Feng had spammed my thread a little with a large number of his pictures - so I thought I would try to separate the two designs to avoid any confusion. Yes we need to learn about what this offers us with some flight testing. It may be able to handle heavier props more effectively.
Cheers, Steve
airbotix is offline Find More Posts by airbotix
Old Nov 26, 2008, 09:44 AM
jesolins is offline
Joined Feb 2007
Peace...no need to apologize...
Press on!
Cheers,
Jim
Cheers, Steve
Old Nov 26, 2008, 01:41 PM
amir42 is offline
Find More Posts by amir42
amir42's Avatar
Switzerland
Joined Mar 2007
Hi OMM,
Originally Posted by Old Man Mike
I just hope this project ends up with a good English based website and forum. The German MK and UAVP quads have suffered from poor translation into English.
The new UAVP-NG has a full english documentation.
To be true, there is not yet any german documentation...
We (the NG team) hope to be able to release soon.
The new hardware comes one quite well...
Regards
- Amir
amir42 is offline Find More Posts by amir42
Old Nov 26, 2008, 02:06 PM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Originally Posted by amir42
Hi OMM,
Regards
- Amir
Hi Amir,
That sounds like good news. I'll be watching the new NG forum for more info, in English
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Nov 26, 2008, 02:55 PM
nikivan is offline
Find More Posts by nikivan
Joined Dec 2005
Steve
Very interesting design. My concern would be about tiny cracks developing in PCB & traces/solder points due to motor vibrations. These could propagate and eventually lead to failure. Your thoughts?
nikivan is offline Find More Posts by nikivan
Old Nov 26, 2008, 03:55 PM
amir42 is offline
amir42's Avatar
Switzerland
Joined Mar 2007
Hi Rusty!
Did you notice that we made a "English" Sub-Forum in each Topic-Forum?
We try to do everything bi-language in english and german. Where we have time only to do one of them (eg. documentation), we do it in english since it's more international known.
Best regards
- Amir
Old Nov 26, 2008, 04:07 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Hi Rusty!
Best regards
- Amir
Thanks Amir. BTW, on the subject of this thread, will the NG be capable of using pretty much any I2C controller, or will it only work with particular models? In other words, if these controllers that are being discussed are produced, would you anticipate any problems using them with the NG.
Nothing like a nearly un-answerable question
Cheers,
Rusty
Site Sponsor
Old Nov 26, 2008, 04:15 PM
ssozonoff is offline
Find More Posts by ssozonoff
ssozonoff's Avatar
GE, Switzerland
Joined Jul 2004
Hi Amir,
We can't wait to see... at the moment all I can do is drool looking at the pics of the Alpha PCB's and talk to Robert_t :-)
Serge
ssozonoff is offline Find More Posts by ssozonoff
Old Nov 26, 2008, 08:42 PM
airbotix is offline
Meopham, Kent UK
Joined Jul 2008
Yes this is definately a concern. You can see some flexing in the video.
The "music" test is pretty aggressive. I beleive the non-motor mount is preferred by everybody.
Steve
Old Nov 27, 2008, 06:42 AM
amir42 is offline
amir42's Avatar
Switzerland
Joined Mar 2007
Hi Rusty,
Now, we currently support Holger's BLC, YGE30i and China-BLCs with Quax's Software. I can't see any reason why we should not be able to use the new controllers discussed here!
Especially since the NG uses HW probing and tries to detect available HW. It then activates only those part of the software involved with these (you could call it a kind of "driver"). The whole design is built such that we could replace any sensor with another one, write a new interface to it and then support both (if they are somehow distinguishable to the software).
This means you don't even have to configure which of the above BLCs you're using. Depending on the configured HW addresses they will be detected automatically (YGE30i's have different default addresses than Holger's BLC and Quax BLCs are controlled the same as Holger's). What's different between the BLCs is that you have a special shell command to program the addresses of the YGE30i if they are detected as new (special address).
You need to find a better question... this one was easy...
@Serge: We try to finish up for the first release but there is so much to do. We are currently porting the SW to the new HW and there are so many changes that this will take some time to happen. We hope to have the first boards in the air for the CCC Congress so we can start beta testing. We hope to release soon after that point... but you should keep in mind that planing timelines is not something a bunch of hacking folks do very well...
Cheers
- Amir
Old Nov 27, 2008, 11:52 PM
feng.matrix is offline
Find More Posts by feng.matrix
Joined Nov 2008
Originally Posted by kb6mcc
I'm really like your i2c Master Controller. Can you share some more info on that?
my english is very poor , i will send a mail to you about this " i2c Master Controller", use Chinese
feng.matrix is offline Find More Posts by feng.matrix
Old Nov 28, 2008, 01:54 AM
kb6mcc is offline
Find More Posts by kb6mcc
Joined Dec 2007
Fantastic!! Perhaps I'm may able to perform some effective English translation.
hope the old man don't have any problem understanding "english me no speak" mean.
kb6mcc is offline Find More Posts by kb6mcc
Old Nov 28, 2008, 10:08 PM
brashley is offline
Find More Posts by brashley
brashley's Avatar
Joined Dec 2006
Steve
I would definatly not put the motor mount as part of the ESC. I see too many broken solder joints on cell phones at work just from opening and closing the flips to have any comfort at all that this integration would be usable in the long run. Solder fatigue can be a real problem, best to avoid it at all costs in a quad.
Defiantly very cool, the efficiency seems to be outstanding. Have you compared it to a standard ESC for the same motors?
Richard
brashley is offline Find More Posts by brashley
Old Nov 28, 2008, 11:47 PM
airbotix is offline
Meopham, Kent UK
Joined Jul 2008
Richard
Hi Richard,
We have made the design with efficiency in mind, but at risk of giving you old data here are a couple of plots. Some software changes have since been made to correct an issue with retarded timing at higher powers. We really need to re-measure for this comparison, though you can see useful gains. Good to see our prop calibration is similar to yours, we have seen some variability between EPP1045's.
Steve
Jeti brushless controller... HELP!!! Dan Chase Power Systems 6 Oct 14, 2003 11:16 AM
Jeti 70 amp brushless controller on 18 cells-- no problem Andreas Power Systems 12 Sep 25, 2001 09:58 AM
Aveox L160 Brushless Controller Steven Horney Aircraft - Electric - Airplanes (FS/W) 4 Sep 17, 2001 06:13 PM
pic based brushless controller fisher Power Systems 1 May 28, 2001 10:39 AM
Kontronik Brushless controller modes (3 or 4)? ShakyHands Electric Heli Talk 0 May 25, 2001 07:40 PM
