Old Nov 26, 2008, 11:15 AM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
Originally Posted by Glauco
Thanks Mark and Tom, will go for a wider center spar. Would you suggest widening the tip spars too?
The tip spars are adequately stiff for F3J.
markdrela is offline Find More Posts by markdrela
Old Nov 26, 2008, 10:03 PM
Glauco is offline
Find More Posts by Glauco
Glauco's Avatar
United States, MO, Maryland Heights
Joined Jul 2002
Thanks again Mark.
Took the day off today since the weather was about as perfect as it gets here in the Midwest for the end of November and was able to make a few tests with the bagged Supra.
First was a couple of 2 man F3J tows. With almost no wind I can say the wing took it easily. A little later we setup the F3B winch, set to 150 meters. Again at the same wind conditions there was no problems for "51".
So I'm happy to say this plane can easily take good F3J tows in light conditions. The new one with the wider spar will be used for higher wind conditions.
Glauco is offline Find More Posts by Glauco
Old Nov 26, 2008, 11:59 PM
Jim Frahm is offline
Find More Posts by Jim Frahm
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Glauco,
Thanks for all the data/testing!
No sure when I'll get started, currently I'm working on an Aegea II and a 2 meter version of the Supra but I'll continue to follow this thread.
Thanks again,
Jim
Jim Frahm is offline Find More Posts by Jim Frahm
Old Nov 28, 2008, 01:06 PM
Glauco is offline
Glauco's Avatar
Joined Jul 2002
A couple of pictures taken by photographer expert Chris Lee from our last flying day. You can read some reports about our day here
Old Nov 28, 2008, 01:57 PM
Glauco is offline
Glauco's Avatar
Joined Jul 2002
Time for some more pictures of the stab and fin. Need to add another disclaimer. The methods I use are not always the fast ones. Most of the time I'll spend a few extra hours to get that 1% better looking piece or what I think to be a more precise part, can't control myself
For most the construction it was used only MGS epoxy. The fast hardener actually cures in about 5 hours and the slow one in 24. You can't rush this type of construction.
On the stab I just wetted the rods with the least amount of epoxy I could to make sure it would stick to the foam. Also glued both top and bottom rods at once so didn't want to create a mess with the bottom ones. Transparent tape glued to the beds is your fiend to avoid all sticking up together.
Old Nov 28, 2008, 03:59 PM
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Glauco,
Thanks for the detailed build photos! If there's one thing I've learned from all the Supra build photos it's this: I need more "hold down" weight....
Keep them photos coming,
Jim
Old Nov 28, 2008, 06:58 PM
T.D. is offline
Find More Posts by T.D.
T.D.'s Avatar
Vancouver, Canada
Glauco, I'm curious why you don't use weblets instead of the carbon rods?
I find weblets to be less labour intensive and plenty strong...maybe liter as well.
T.D.
T.D. is offline Find More Posts by T.D.
Old Nov 29, 2008, 08:28 AM
mlucca is offline
Find More Posts by mlucca
Mario S. de Lucca
Brasil
Joined Oct 2005
Glauco
Very nice job..... great model
Im finishing my new 2,6m standart class (like a RES)... I`ve told to you when you stay here in Brasil.... I will post some pictures at planador@grupos....
Best regards
Mario
mlucca is offline Find More Posts by mlucca
Old Nov 29, 2008, 09:31 AM
Glauco is offline
Glauco's Avatar
Joined Jul 2002
T.D.
T.D., after many years building Dr. Drela's designs including several Supergees, an Allegro, a composite Bubble Dancer and two Supras I learned the best way to avoid problems is following exactly the plans and that is how the stab was designed, with carbon rods.
I understand many new hand launch planes are now build with weblets only and I'm planing on building one with them but for right now I'll just stick to the plans.
Hello Mario, good luck with your Standard class glider.
Old Nov 29, 2008, 05:02 PM
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Hope we can build them together. I also would like to build this new batch with the molded Supra square joiners but I'm a bit afraid of changing the plans. Does anyone know of any problems using the square joiners instead of the 3/8" round ones?
Construction would be much easier without having to build those basswood joiner boxes.
For the stab and fin I just tiled them but for the wings it was enlarged of the supra_wing.pdf file. I work in a construction company and just asked the drafters to plot to full scale. Took them a couple of tries but the result was perfect.
Glauco,
Here's the thread I found with a diagram on post 10 showing how to build boxed joiners.
http://www.rcgroups.com/forums/showthread.php?t=920053
Jim
Old Dec 03, 2008, 04:36 PM
VHO is offline
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Foam Weights
Glauco,
Been building Supras as well, nice to get them light, but I seem to be working behind the 8 ball on weight.
Weights of foam are significantly different to your posts. On vertical tail, 15g bare, 16g with glass facings only. Horizontal tail 17g with rods and balsa centre block (and no filler).. Been using foam with 50psi (350kPa) rating (called SP by Dow) for tail feathers, and also 400 kPa (called RTM in Australia, and stamped that by Dow) for wings. Templates printed by Profili and cut with 0.020" wire using Phil Barnes methods.
I seem to be able to match the covering weights, but by starting 4-5g too heavy wind up not surprisingly with weights around 27-28g rather than the target of 24g...
What do you do to get the foam 4-5g lighter? It is really to HiLoad 60 specs?
Hutton
VHO is offline Find More Posts by VHO
Old Dec 03, 2008, 07:43 PM
Glauco is offline
Glauco's Avatar
Joined Jul 2002
Hutton
I got the foam cores CNC cut from Les Horvath and I understand Dr. Drela did the same. They are Hi Load 60 but bigger parts have more variation. For example the target for the center panel foam is 165 g. The two wings I've done one was 138.7 g and the other 133.8 g.
Also the way I check the weight is when the core is absolutely only what will be bagged, meaning all the sanding, trimming and cutting are done.
I would guess the manufacturing in Australia is a bit different than here, enough to add a few grams.
Old Dec 04, 2008, 01:40 AM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Hutton
Foam densities can vary significantly. The manufacturer only has to make sure that the foam has enough density to meet the required R value and compressive strength. If it has a higher density it still meets the functional specification.
If you are really trying to build the lightest model possible you will probably have to shop around for the lightest batch of foam you can find. Kind of like looking for contest grade balsa . . .
Kiesling is online now Find More Posts by Kiesling
Old Dec 04, 2008, 04:17 AM
DrFragnasty is online now
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
fin sections
Hi All, Hutton,
I can't see the section for the top of the fin on the plans (the .pdfs from CRRC site).
Lower section is drawn but the top?
Chris.
DrFragnasty is online now Find More Posts by DrFragnasty
Discussion Molded verses Bagged Supra problems mdennis Thermal 72 Oct 07, 2007 01:59 AM
