Old Jan 19, 2009, 03:47 PM
Longhorne is offline
Find More Posts by Longhorne
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Bulent,
I've been following along and I really admire your workmanship. I think its great that your mom has been a big proponent of your craft. I wish the both of you the best.
Take care,
Paul
Longhorne is offline Find More Posts by Longhorne
Old Jan 20, 2009, 05:00 AM
bmutlugil is online now
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
Thanks for your good wishes.. I could not keep my emotions at bay.. I think her destiny is in the hands of God now.
I removed the shaft of the backup motor, but did not put in the new one. It is a really tight fit, and might need some hammering again. I may have to cut reliefs for circlips on the shaft first.. This is possible using a Dremel cutoff disc on the shaft while it is rotating in the lathe, but the quality depends on the stability and dexterity of the hand holding the Dremel
I modified the thrust plate's holes, so now the motor mount setcrews are reachable from the sides. The motor will be easily replacable by removing the spinner/prop and two setscrews on the motor holder. Field replacement seems feasible.
Replacing the aileron bellcrank with a flexible pushrod seems possible, but not a very straightforward job. If the pushrod was external, it might be easier - but ugly. As it goes now, all actuating mechanisms will be hidden, including tail wheel control; only the rear ends of rudder pul pull cables will be external as on the full scale.
Bulent
bmutlugil is online now Find More Posts by bmutlugil
Old Jan 26, 2009, 06:11 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Bad news,
My mother has passed away 6 days ago. Her suffering has ended, that is our only consolation. My work was interrupted as a consequence, but I am willing to start again soon. Building keeps my mind off sad thoughts. I may go away for a few weeks, however - that will delay the process.. There is less chance that I will finish the model by the deadline, but I don't care. I will finish the model - my mother would have liked it very much.
I lightened the thrust plate, got it from 6.3 to 4.8 grams. I don't have photos yet. I am also replacing the shaft of the second (higher stack) motor.
Regards,
Bulent
Old Jan 26, 2009, 06:26 AM
michaelghammer is offline
Find More Posts by michaelghammer
michaelghammer's Avatar
Denmark
Joined Dec 2004
Sorry to hear that, Bulent. My condolences to you.
- Michael Hammer
michaelghammer is offline Find More Posts by michaelghammer
Old Jan 26, 2009, 06:40 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Thanks, Michael..
Bulent
Old Jan 26, 2009, 08:05 AM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
Dedicate this to your mother's memory. I hope it gives you some comfort.
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Jan 26, 2009, 08:46 AM
paulbw is offline
Find More Posts by paulbw
paulbw's Avatar
Gloucestershire, UK.
Joined May 2006
Hi Bulent,
My condolences to you also.
Paul W.
paulbw is offline Find More Posts by paulbw
Old Jan 26, 2009, 08:58 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Thanks Geoff, Paul,
Yes, I thought of dedicating this model to my mother, that is why I want to finish it.
Bulent
Old Jan 26, 2009, 10:26 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Bulent, Sorry to hear of your loss, our thoughts and prayers are with you.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Jan 26, 2009, 10:44 AM
TPfingston is offline
Find More Posts by TPfingston
Retired and Lovin' it!
United States, KY, Sturgis
Joined Jul 2007
Bulent, please accept my prayers for you and your mother. Please remember, she no longer suffers and has no more pain.
Tony
TPfingston is offline Find More Posts by TPfingston
Old Jan 26, 2009, 11:00 AM
W@CC0 is offline
Find More Posts by W@CC0
....When pigs can fly
W@CC0's Avatar
Duffel - Belgium
Joined Jan 2004
I am sorry to hear that Bulent.
Tom
W@CC0 is offline Find More Posts by W@CC0
Old Jan 26, 2009, 11:49 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Thanks Pat, Tony, Tom,
Yes, she is not suffering any more and must be in heaven - she was such an angel. It was hard to withstand her condition on the last days..
Bulent
Old Jan 26, 2009, 04:09 PM
kpriddle is offline
Find More Posts by kpriddle
Slow 'n Steady...Grease 'r In
kpriddle's Avatar
Maine
Joined Oct 2008
Saddened to hear that, Bulent. I hope that you do dedicate the Fairchild to her and find the will to continue.
Again, my condolences.
KP
kpriddle is offline Find More Posts by kpriddle
Old Jan 26, 2009, 07:50 PM
Float Flyer is offline
Find More Posts by Float Flyer
It actually Flies!
Float Flyer's Avatar
Salmon Arm, British Columbia, Canada
Joined Feb 2006
Bulent, I wish the best for you and your family with your great loss.
Darryl
Float Flyer is offline Find More Posts by Float Flyer
Old Jan 26, 2009, 08:15 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Bulent,
Prayers are on the wing.
James
Deuce is offline Find More Posts by Deuce
Build Log Beechcraft Starship, Mark II flying and developing nickchud Scale Kit/Scratch Built 380 Sep 13, 2015 02:20 PM
Contest Scratch-Build-Off-3 Firecrest mrdj Scale Kit/Scratch Built 31 Apr 29, 2009 07:23 PM
Contest Scratch-Build-Off 3 - Waco 10 / GXE at 1/10 scale myplanesfearme Scale Kit/Scratch Built 43 Mar 11, 2009 07:00 PM
Build Log Scratch-Build-Off 3 "XP-40 late" xterarc Scale Kit/Scratch Built 7 Jan 20, 2009 03:09 AM
Discussion Nitikin-Shevchenko IS-1(I-220) Polymorphic Fighter for Scratch Build Off 3 CryHavoc Scale Kit/Scratch Built 26 Sep 10, 2008 08:23 AM
