Old Dec 19, 2008, 01:59 PM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
Probably it will be best to use a screw type servo connector to be able to adjust pushrod length easily, and offset the servo arm as required for differential action. If I give the differential from the bellcrank, it will be fixed and not easily adjustable.
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Old Dec 22, 2008, 04:41 AM
bmutlugil's Avatar
Turkey
Joined May 2002
I could not start assembling the fuselage, but I continued with parts cutting to get a longer kit
I first corrected the cross section of the nose block/ motor bulkhead as shown, then removed 1.2 grams of balsa from the wing roots - which will have a 1mm plywood reinforcement glued on.
After that I finished the rib cutting template by putting in all required holes and gluing two pins to hold it steady on the balsa. The brown sections in the photo are epoxy dots that hold the pins on the template - that is some Russian epoxy I had bought decades ago while at an F3B contest in Bulgaria I used a broken razor blade for cutting the ribs, in this way usually no sanding is necessary and one can get a perfect cut - still I sand the parts slightly, thinking it would do no harm. I beleive similar results can be obtained using a sharp X-Acto blade as well, and it would be safer. I did not have any trouble with the razor blades, I am accustomed to this.
The rectangular holes in some ribs are for the bellcank plate structure. These are all the ribs that can be cut using the template, others are different size due to tapering of the wing at root and tip.
Fuselage bulkheads on the back have been cut, except for stringer slots. I also cut the rudder and vertical tail posts, but there is no photo showing these.
Bulent
Old Dec 22, 2008, 09:17 AM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Bulent
When Pa got my older brother and I started in stick-n-tissue models (I was probably 9 or 10, if I remember correctly, maybe a year younger), the blade of choice was a broken double-edge razor blade! Sure, our fingers got nicks in them, but that was a part of building a model!
James
Deuce is offline Find More Posts by Deuce
Old Dec 22, 2008, 09:29 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Yes, these old techniques were all we had at the time - no laser cutting or CNC. Die cut balsa was invented but we could not buy kits here; even finding balsa sheets was a problem. I had learned these techniques when I was into F3B models around 30 years ago. I am accustomed to plug in wings from my F3B's as well.
I guess it is getting harder to find the older razor blades that were thick and brittle - at least here - so this technique may die. I have some old blades (PAL brand) and when I run out of these I may not easily find new ones. However a blade goes a long way; one may get a model finished completely Newer blades seem much thinner and quite flexible.
Bulent
Old Dec 23, 2008, 11:44 AM
Deuce is offline
Deuce's Avatar
Joined Jul 2006
Yes, these old techniques were all we had at the time - no laser cutting or CNC. Die cut balsa was invented but we could not buy kits here; even finding balsa sheets was a problem. I had learned these when I was into F3B models around 30 years ago. I am accustomed to plug in wings from my F3B's as well.
Bulent
Bulent,
A2Z Hobbies is a source for thin, double-edge blades. I've attached a pic of their listing for 100, but they sell them individually as well.
James
Old Dec 24, 2008, 06:18 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Thanks James, that is good knowledge.
If you used any, are these the brittle types that can be broken easily without distorting the blade?
Bulent
Old Dec 24, 2008, 09:30 AM
Deuce is offline
Deuce's Avatar
Joined Jul 2006
Bulent
No, I have not used them, but according to the details, they "snap easily to a point."
James
Old Dec 29, 2008, 05:20 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Some of the developments on the weekend. I constructed the LG box, and started assembling the fuselage, tested motors.
The center of the fuselage is assembled now, I have added the cross members after taking the photos, taking care of aligning them well - I hope
Th LG box will sit as shown in one of the photos. LG wires and strut holder will be pushed in from the sides and secured with the screws - the cabin is large enough to permit screwing from the inside, and doors will be functional. I guess I will use two screws to hold the wings in place as well - I can not be sure the struts alone are enough.
The long pieces are the tail structure elements around the hinge line. They are tapered because a streamlined profile is used.
Bulent
Old Dec 29, 2008, 05:29 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Here is the motor bulkhead, the thrust adjustment plate and the motor(s) to be used. If the small one is not powerful enough, I will use the larger motor.
The shaft of the motor will be reversed (and lenghtened) so it will go out of the other side. The aluminum thrust plate has 2 degrees down and 1.5 degrees right thrust built in, so the bulkhead has to be dead vertical and perpendicular to the fuselage center line. The plate was kindly machined and donated to me by Nachman Zimet of Israel. That kind of machining is beyond my capabilities. I guess this plate may help in cooling the motor as well.
I have seen that I will have to use a two cell battery, so I may try an A123 setup. That will be heavier, but charging will be much faster. I get tired of waiting for batteries to get charged at the field (when I have no spares). The small motor is just short of 60W at two cell voltages, so it might be marginally sufficient - motors are directly replacable as they have the same screw holes. They can even be changed at the field, if that becomes necessary. The larger motor is the FC 28-22, I forgot to show the label. Both from Hobbyking/United Hobbies : $5.95 each (except mailing). By the way, I just noticed that both photos showing the motors are wrong, the motor and thrust plate should be on the other side. This is the view from forward and the motor should be in the back of the bulkhead
I can use a 10x4.7 SF prop with these, the larger one can even drive an 11 x 3.8 prop, which would be the scale diameter but that would be overkill and a very low pitch.
Bulent
Old Dec 30, 2008, 06:16 AM
bmutlugil's Avatar
Turkey
Joined May 2002
On weekday nights I can take only small steps, here is last night's work.
LG box was glued between two cross members, this section is nearly indestructible Other cross members of the center section are ready as well. Rubber bands corrected a slight shift, probably they are not needed any more after the LG box is in.
I also preapared the cabin floor on which the servos will sit. Reinforcing strips will be glued below. It does not look like a floor, but the holes save 0.8 grams. Probably the holes can be covered up with lighter stuff, if a scale cabin interior is desired. I have no desire for such at the moment.
I wish everyone a happy new year..
Bulent
Old Dec 30, 2008, 11:14 AM
bob_suruncle is offline
Find More Posts by bob_suruncle
I think I can glue that..
bob_suruncle's Avatar
Paris, Ontario, Canada EH
Joined Jul 2005
Bulent: how do you cut those nice round weight reduction holes? Brad point drill bits? or are you just really handy with a razor blade?
bob_suruncle is offline Find More Posts by bob_suruncle
Old Dec 30, 2008, 11:47 AM
bmutlugil's Avatar
Turkey
Joined May 2002
Hey Bob,
Good to hear from you. This project has taken precedence over the Dragon Rapide - that may come next. I wonder if you started on a Dragon.
The holes are all manual work. I drill a pilot hole, then enlarge that using tapered grinding stones on a Dremel moto tool - which I slow down so it will not burn the wood or itself A 45 degree conical stone puts a good chamfer on the edges, after the required diameter is reached - of course if the part has some thickness for that.
If the diameter is large enough, I use the Dremel sanding drum to finish the job - before chamfering. That is what I did on the last balsa part. I have found some smaller diameter sanding drums, but ordering them form the States is not very trivial.
Bulent
Old Dec 30, 2008, 12:28 PM
Joined Jul 2005
I havent gotten anywhere near the Rapide as yet. I still have multiple builds ahead of it... Driggs Skylark (another one of Pat's kits), Gypsy Moth, another heavily modded foamie beaver (I always seem to be building one of those). I plan to do a thread on the Driggs when I start on that though. For all hand cut parts you really do a very nice job!
Old Dec 31, 2008, 04:58 AM
bmutlugil's Avatar
Turkey
Joined May 2002
I drilled some more holes on the section that goes below the door sills, but no photos yet.
Maybe next year
Bulent
Old Dec 31, 2008, 09:42 AM
kpriddle is offline
Find More Posts by kpriddle
Slow 'n Steady...Grease 'r In
kpriddle's Avatar
Maine
Joined Oct 2008
Bulent,
I've still been watching your progression, but haven't had too much to say because most of what is discussed is over my head. I like your work, though! I would have to agree that, using the tools you have, you make an amazing piece of work! Can't wait for the next update .
KP
kpriddle is offline Find More Posts by kpriddle
Build Log Beechcraft Starship, Mark II flying and developing nickchud Scale Kit/Scratch Built 380 Sep 13, 2015 03:20 PM
Contest Scratch-Build-Off-3 Firecrest mrdj Scale Kit/Scratch Built 31 Apr 29, 2009 08:23 PM
Contest Scratch-Build-Off 3 - Waco 10 / GXE at 1/10 scale myplanesfearme Scale Kit/Scratch Built 43 Mar 11, 2009 08:00 PM
Build Log Scratch-Build-Off 3 "XP-40 late" xterarc Scale Kit/Scratch Built 7 Jan 20, 2009 04:09 AM
Discussion Nitikin-Shevchenko IS-1(I-220) Polymorphic Fighter for Scratch Build Off 3 CryHavoc Scale Kit/Scratch Built 26 Sep 10, 2008 09:23 AM
